Custom ROM Übersicht
  • 19 Antworten
inFECT
inFECT
Stamm-User
242
1.) MoDaCo Custom ROM (download)
Features:
- Rooted with 'adb remount' permission and superuser APK
- Custom kernel based on Samsung source with swap enabled (install 'swapper' from the market, I recommend a SD swap partition), netfilter enabled (working on wifi tether fix), cramfs + squashfs and much much more
- Latest build of busybox included with relevant links, also other utils such as sqlite and parted in ROM.
- Added terminfo and settings to boot.img
- Added JBed Java
- Removed files wasting space in system directory
more info & download
2.) Galaxo / GalaxHero V1 (download)
Features :
- Based on I5
- Root (with superuser)
- ADB root whith personnalised bash prompt
- All applications optimised with zipalign
- Compressed modules and binary into squashfs images to save space
- Busybox 1.15.1 with full applets
- Moving all app to internal memory to keep space on /system for the future
- Tweaked CPU freq rules, improved responsiveness (sampling can be managed in GalaxoConf)
Optimized Kernel 2.6.27.35 with :
- Compcache 5.4
- Patched kernel with BFS
- Patched kernel with SQUASHFS 3.4 + LZMAcompression
- Full Netfilter support
- Swap support
- Build whith Cgroups (for the future ?)
- Tunneling support (tun.ko)
- New HW modules
- Tuned CPU Freq : 245Mhz/528Mhz
- Lot of another kernel modules : CRAMFS,EXT4,NFS Client, NFS Server,CIFS,NTFS, IPV6, VFAT, CPUFREQ*, TUN, and a lot of another (see in /system/libmodules)​
3.) mustymod ROM (Android 2.0) (download)
Features:
ROM Base: Eclair 2.1
Version: 2.1.00
GPS: working
WiFi: working
Audio: working (fixed stereo headset bug)
Sensors: working
SDCards: both sdcards (internal and external) working
OpenGL: software renderer
H/W Audio Codecs: ToDo (MP3, AAC, AMR)
H/W Video Codecs: ToDo (H264, H263/Mpeg4)
Market: working
Languages: German, English, Spanish, French, Italian, Turkish, Russian
4.) GAOSP (download)
Port of the Android Open Source Project on Samsung Galaxy
Features:
  • Clean vendor
  • RIL (telephony/data)
  • Original galaxy keys
  • Internal/External SD
  • Sound (need fix for stereo and some other few bugs)
  • LiveWallpaper (remains slow because of 3D)
  • GPS
  • Sensors (except proximity sensor)
  • Bluetooth (first release, need lot of fix)
Other:
  • Easy-to-build system by Linuzel
  • Custom Kernel 2.6.27 (waiting for Samsung's 2.6.29 sources)
  • FLAC audio support from Kenny Root (from CyanogenMod)
  • Perform zipalign-on-install of applications (merge with CyanogenMod)
  • OpenVPN integration thanks to James Bottomley (from CyanogenMod)
  • Full ssh server with real authentication (dropbear)
  • Root & Superuser
  • Full busybox with symlink
5.) Italy Custom ROM (based on IK5 Firmware) (download)
Features:
- Custom Kernel 2.6.27-44
- Superuser
- SWAP (Configuration via GUI)
- Busybox
- Tethering
- Default Root for ADB
- Supports moving Apps from System to Data.
- Available System Memory 98,048MB
6.) GALAXO VERSION V1.6.3.3 (Download)
Features:
- Based on last 1.6 (Donut) update from Samsung
- Most Europian languages
- Wifi Tethering
- Full market
- 2.6.29 custom kernel (netfilter, Compcache 6.2, BFS, Swap, Cgroups, VPN(tun.ko), CPU Freq : 19Mhz/710Mhz)
Applications :
- New Superuser from ChainDD on XDA – Superuser 2.1 - Fun for all! [2010-05-16] - xda-developers (thanks to Spria from frandroid for this info)
- MMS app from rgv151 on XDA(Modified Mms.apk-Discontinued till I have free time [Discontinued: 08/21] - xda-developers)
- Loccy's BetterBrowser (Loccy's BetterBrowser - now in Donut edition (v1.5: 8th Oct 11am/BST) - xda-developers)
- Donut Advanced Launcher (rogro82/irrenhaus on XDA (Advanced Launcher - Now with more sweets [Version 2.1 - 25.09] - xda-developers) :
- New applications Galaxo : GalaxoParameters & GalaxoApps :
- GalaxoParameters : enable/disable camera button, remount fs in rw/ro, shown hidden menu (does not work because samsung apps are removed)
- GalaxoConf : manage galaxo (vnc, sshd..)
System :
- Overclocking to 614Mhz/710Mhz (GalaxoConf)
- Default min freq fixed at 19Mhz (preserves battery in sleep mode)
- Audio Volume hack
- rc with configuration (GalaxoConf)
- Full SSHD/SCP support (/etc/passwd, /etc/shadow..). Changing the root passwd : adb shell, then "changepasswd"
- Script to activate/deactivate the camera button (camenable/camdisable with adb)
- Script to remount in rw/ro the filesystems in both recovery/system (remountro, remountrw). Already exist with adb (adb remount) but usefull in recovery to remount correct partition, and with connectbot.
- VNC server on port 5901 (can be activated in GalaxoConf).
- Moving all app to internal memory to keep space on /system (like app2sd)
- New adbd where replacing default shell from sh to bash with custom bashrc
- Recompile some tools for android-arm : zsh, nano, vim, inadyn
- Lot of tools in xbin/
- Telnetd
- Debug tools
- Access phone, contacts, market and other without sim cards (wifi)
Other tweak/improvment :
- Dialer theme from Eclair
- Mount rw device with noatime option
- Disable some services (NPS service, debug devel binary)
- Remove all samsung apps
- Home app is now locked in memory to avoid reloading of it
Download and how to :
Related Article: How to install Galaxo
Related Article: How to upgrade Galaxo
todo:
- Übersicht ein wenig kompatker gestalten
- Galaxo Versionen zusammenfügen.
- Direkt Download Links+ Mirror hinzufügen
Danke an Alvar Hanso & Archer für die Italy ROM Informationen.
EOF
Reaktionen: Ternalo, Buffy, Stöpsel und 9 andere
Anzeige
  • Gerade eben
  • Neu
Ich denke Du hast da noch etwas Wesentliches vergessen. Das ITALY Custom ROM. Ich habe schon sämtliche Custom ROM Varianten durch und bin immer wieder beim ITALY gelandet. Das MoDaCo ist auch sehr zuverlässig aber eher träge. Aber was Stabilität, Geschwindigkeit, Fehlerfreiheit und Akkulaufzeit angeht ist das ITALY ROM unschlagbar. Gut, es basiert auf 1.5. Das interessiert mich aber nicht weiter denn die einzigen Dinge auf die ich verzichten muss sind Google Maps 4.x, Google Goggles, Google SmartSearch. Das ist für mich aber kein Problem denn die genannten Programme sind meiner Meinung nach noch nicht ausgereift (Ausnahme SmartSearch) und ich verwende lieber ein perfekt funktionierendes 1.5er ROM anstatt einer aktuellen Version die dauernd Probleme macht und sinnlos meine Lebenszeit frisst. Meine persönliche Meinung.
Aber noch mal zurück zum Anfang.
Das ITALY Custom ROM sollte an dieser Stelle auf keinen Fall fehlen
LG
Alvar
P.S. Trotzdem freue ich mich darauf in den nächsten Monaten ein neues Gerät zu besorgen und dann einfach auf einen Rutsch auf Froyo umzusteigen.
"Never change a running system!"
Guter Einwand. Hab ich wirklich vergessen. Allerdings auch nur weil es das einzige ist welches ich nie selber getetstet habe.
Ich könnte ne kurze features liste gebrauchen. Oder anders gefragt, wird alles was in der umfrage von dem thread des roms zu sehen ist auch vom Italy unterstuetzt? Dann brauch ich nur die keywords rausnehmen ;-)
vote 4 sticky
schöne Übersicht!
klasse übersicht
super arbeit :)
Tut richtig gut mal ein Überblick. Dennoch für mich etwas schwierig zu vergleichen.
Ich vermisse am meisten den Abgleich mit Outlook. Ist da Mustymod also für mich die einzige Wahl?
Galaxy 1.6.3.3 ist herausen falls du das updaten willst.
sehr schön, dass sich jemand die Mühe gemacht hat.
Könnte man vielleicht das Datum der letzten Version noch dazu packen, damit man sehen kann, in wie weit die Versionen noch gepflegt werden?
Mhh könnte das vielleicht nochmal aktualisiert werden z.B. Galaxo 1.6.3.4 und Gaosp und die Features von denen auch?
das Galaxy von einem Freund will nicht mehr und wenn ich mir hier so das Datum vom letzten ändern anschaue frage ich mich, ob es überhaupt noch Custom roms fürs galaxy gibt? Und wenn nein, auf welcher version es stehen geblieben ist.
thx Andy
Ja das Projekt ist mehr oder weniger stillgelegt...letzte Version ist Gaosp 3 welches Anroid 2.3.4 beinhaltet! Bin sehr zufrieden damit! ;-)
Reaktionen: Andy6325
Sorry, dass ich in dieses Thread hier schreibe, aber welches ist denn nun die "beste" Rom? :) Bzw welche läuft stabil und bietet die meisten sinnvollen Funktionen? Kann man nicht entscheiden und benutze noch eine alte GAOP Version, die eher Probleme macht als zu laufen! :p
Liebe Grüße
Moin zusammen!
Ich habe meinem bei Ebay gekauften I7500 gerade mit Odin FW 1.6 verpasst und lese mich gerade durch`s Forum. Mittlerweile habe ich herausgefunden, daß BT-Filetransfer unter 1.6 nicht funzt. Jetzt denke ich über ein Update auf Android 2 nach und habe mir die obige Auflistung angeschaut. Jetzt bin ich aber ehrlicherweise nicht schlauer geworden und bitte deshalb um Hilfe:
Welches Rom sollte ich nehmen? Ich möchte den Bluetooth benutzen, aber auch alle anderen Funktionen (vor allem die Kamera) sollen normal arbeiten.
Bitte lichtet mir den Dschungel doch mal!
Danke im voraus!
mfg Ludger
Wenn du Android 2.x nutzen möchtest, hast du nur die Wahl zwischen GAOSP 2 (2.2.1 = Froyo) oder GAOSP 3 (2.3.4 = Gingerbread).
Funktionieren tut bei beiden im Großen und Ganzen alles, bei GAOSP 3 kann ich die Nutzung allerdings persönlich nur mit Swap empfehlen, wofür du eine schnelle MicroSD(HC)-Karte (ab Klasse 6, besser 10) benötigst (und entsprechend formatieren werden musst). Dies ist bei GAOSP 2 natürlich auch möglich und würde ich auch empfehlen, durch Übertakten kann man GAOSP 2 mMn jedoch auch ohne Swap benutzen.
Lies dich am besten in beide Themen ein und entscheide dann für dich.
lG
Reaktionen: ludibubi
Danke für die Info - ich werde mich mal durcharbeiten.
mfg Ludger
Hab in Bezug auf Android-2 jetzt so einiges rauf- und runtergelesen und auch schon ausprobiert, aber die optimale Lösung habe ich noch nicht. Am besten hat mir GAOSP-2 gefallen. Läuft super, alle Funktionen sind da, aber leider kann man über BT nicht im Auto telefonieren, obwohl die Verbindung klappt.
Gibt's denn nun eine Android-2-ROM, in der Kamera, GPS, WLAN, 3-G und BT funktionieren bzw. was für eine Möglichkeit gibt es BT in GAOSP-2 zum Laufen zu bringen? Schade, das die 2er nicht zu Ende gebracht wurde und statt dessen GB begonnen wurde. Und das stagniert jetzt...
Kann sich einer der GAOSP-Macher nicht erbarmen und das BT zum Laufen bringen?
Nein, leider lässt sich das Problem mit BT nicht lösen. Außer du bettelst bei Samsung nach 2.x Kernel. Da es keinen gibt, wirst du auch keinen Erfolg haben.
Bei gaosp3 funktioniert übrigens BT und auch Kamera. Nur das Vorschaubild flackert.
Also bei mir tut sich bei BT nichts. Ich kann zwar verbinden, aber ich höre nur ein Knirschen im Headset. Also genau wie bei GAOSP 2.....
Kann man nicht einfach aus Galaxo die BT-Treiber da rein packen. Kenne mich mit Android/Linux nicht aus, aber bei Windows ist doch durchaus möglich, z.B. auf XP einen Treiber aus Win98 oder Me zu installieren. Würde das ja mal ausprobieren, ich weiß aber nicht was ich da nehmen muss und wie man das installiert...
Wäre es so einfach, dann wär die Kamera z.B. für Android 2.x kein so großes Problem gewesen.
Ich hab nur Halbwissen, das ich aus anderen Beiträgen zusammengelesen habe. Wenn ich mich aber richtig erinnere, dann sind die Treiber bereits in den Kernel kompiliert. Und anders als bei Nachfolgemodellen, hat Samsung den Code dafür nie freigegeben. Und dekompilieren geht nicht, um einen Treiber zu haben, auf den man hätte aufbauen können.
Den Treiber für die Kamera z.B. hat ein User selbstgeschrieben (ob nun von Grund auf selbst oder durch Reverse Engineering). Und für BT hats in dem Sinne halt nicht geklappt.
Und da es auch kein Interesse mehr an dem Projekt gibt, muss man sich damit wohl begnügen. Also eben entweder Galaxo und auf die Funktionen von Android 2.x verzichten oder Android 2.x nehmen und mit den Nachteilen leben. Sofern man eben ans I7500 gebunden ist.
Schade, wärre auch zu einfach gewesen. Kann man eigentlich ein ROM vom Nachfolgemodell Galaxy Lite/Spica (i5700) mal versuchen? Äußerlich sehen die sich ja ziemlich ähnlich - auch von den Tasten her.
