deeka1984
Naja gibt ja diverse apps die das aber aus dem homescreen können: -)
Changelog
Beta4, 2010-09-14
A few new features and bugfixes, the lagfix part is now extremely close to it’s final state !
Changes:
Improvements:
Only in RFS mode, when lagfix is disabled: A limited compatibility layer has been added to allow ClockWorkMod recovery and Rom Manager to work as usual. I hope this will help people to backup and restore easier, but this solution don’t satisfy me much. Still no news from Koush.
Automatic brightness adjustment has been optimized to improve the accuracy of dark conditions detection.
Ext4 formatting process is now a bit slower but don’t use not-very-well-implemented mode anymore. Ext4 partition is now just stronger again.
Added tun.ko module for Cisco VPN.
Bugfixes :
The battery life issue introduced in beta3 is resolved. CPU was locked at 1GHz, which some people saw as a feature (snappier Phone!) but in reality this was a bug, sorry guys![]()
What was called “Kies Bug” was present because i forced adb to run to help people debug their configuration.
Now adb is only force-enabled at boot if a file named /sdcard/Voodoo/enable-debug is detected during boot.
You should not have trouble to see your phone with your computer anymore.
Rare bug corrected when a broken temporary backup used in migration was wrongly reused if it was still present on the internal SD.
Fixed thanks to the report of kodealap2 on IRC, thank you !
Potential security hole closed about the same topic.
Lowered a bit the sensor level when the new low brightness mode is activated.
CMcRae schrieb:und wie soll man den fix disablen damit man ein nandroid backup erstellen kann??? Gibts da ein Schalter für?
Installation ging bei mir ebenfalls sehr sehr schnell.... wo sehe ich eigentlich dass sich jetzt die cpu wieder runtertaktet....habt ihr ein Proggi für?
Bierfreund schrieb:Lagfix disablen dürfte aber heißen, man geht wieder auf RFS zurück. Wenn man die Datei löscht, wird der Fix dann wieder enabled, sprich nach ext4 "konvertiert", oder?
Hoffentlich kommt noch ne bessere Lösung, wenn sich der ClockwordMod Macher meldet...
Bei mir ist es auch bei 800 mhzwenn ich auch systeminfo gehe im quadrant dann zeigt er mir auch taktung aktuell 800 mhz
