[MODEMS][CM7/MIUI/ICS]Nexus S Radios KB3, KF1, KD1 & UCKJ1 for Galaxy S
  • 17 Antworten
Welches Modem läuft bei Euch
  • KB3
    Stimmen: 1 1,7%
  • KF1
    Stimmen: 18 30,5%
  • JVU
    Stimmen: 27 45,8%
  • keines der drei Modems
    Stimmen: 16 27,1%
  • Umfrageteilnehmer
    59
Q
quasimodo
Gast
Sicher Sinnvoll Hier darüber separat zu diskutieren
[MODEMS][CM7/MIUI/ICS]Nexus S Radios KB3 and KF1 for Galaxy S by pwneman / xda
TESTED ON i897 Captivate MTD ROMS (Should work on Galaxy S MTD ROMS as well, let me know if it doesn't)
Alright, I just discovered something awesome.
So I found out that the Nexus S radios are indeed compatible with our device. I downloaded some of the hot radios for the Nexus S (KB3 and KF1) and opened them up and found that the Nexus S uses radios (similar to how the captivate/galaxy s uses modems). So I just renamed the radio.img from the Nexus S radios to modem.bin, placed it in an existing cm7 modem package and flashed it via CWM (ICS).
I reboot and get a constant 5 bars of signal. My signal hasn't dropped from this 5 bars of signal in the last 10 hours (usually it fluctuates from 5 to 3 bars). HSDPA speeds are pretty fast as well. I got speeds of 560 kb/s DL at 3 bars of signal and 140 kb/s Upload (see screenie). I've never ever gotten that high speeds.
Moreover, the call quality is just amazing. When I used it, the quality is crisp and nice, almost perfect. It seems as if the voice is exemplified over the background crap so that you can actually hear the person. Idk, it was a magical experience for me :p.
Screenie:
s0IbX1MV
The second row on that picture was the speeds I was getting with KF1 (Nexus S). Moreover, I noticed something interesting; that when I wasn't actually downloading or using data, the data indicator switched to "3G". However, when I started using my data, it automatically switched to "H". Something I thought was kinda cool.
Anyways, here are the download links for the modems (already packaged with the nexus s radios of course). Just flash in CWM with a CM7, MIUI, or ICS Rom and you should be good to go.
IMPORTANT: DONT FLASH THIS WHILE PLUGGED IN. YOU WILL NOT GET SIGNAL
Also, to avoid problems while flashing the KB3 modem, flash the KF1 modem FIRST, and then flash the KB3 after a reboot in between
Original Nexus S Radio Link
  • KB3
Download: I9020a KB3 Radio & Mirror KB3
  • KF1
Download: I9020a KF1 Radio & Mirror KF1
  • KD1
Hier reingestellt von kingoftf
Quelle: [MODEMS][CM7/MIUI/ICS]Nexus S Radios KB3 and KF1 for Galaxy S -
Download:
KD1
http://forum.xda-developers.com/atta...1&d=1331998330
  • UCKJ1
radio-cm-7-ics-nexuss_SGS-UCKJ1-signed.zip
Quelle: http://forum.xda
__________________
Reaktionen: beicuxhaven, aurel81, hannes12 und eine weitere Person
Reserve 1
Reserve 2
o.tel.o / DE:
KB3 - leider kein Empfang (geflashed von JVU > KB3 und auch von KF1 > KB3)
KF1 - 4 Balken
JVU - ~2-3 Balken
ich hab erst heute am Abend gemerkt das ich mit dem KB3 zwar super Empfang hab (3G und alles), aber nicht telefonieren kann ... die Verbindung wurde zwar aufgebaut, aber mein Telefonpartner hat mich nicht gehört und ich ihn auch nicht. hab dann zurück auf JPG geflasht und mit dem ging es dann sofort ....
bin bei drei - austria ...
hier noch ein speedtest von mir (mit dem KF1 hab ich merklich geringeren upload)
Test 08:41 Uhr - KF1
Test 08:54 Uhr - KB3
alle anderen mit dem ZSJPG ....
Bei mir hier auf Teneriffa funktionieren (anscheinend) beide, wobei ich mit dem K1 eine schnellere Verbindung zu simyo aufbauen konnte (Netz von Orange)
Ich lasse nun mal das KB 3 über nacht aktiv, ab und zu kommt dann noch mal ein neuer Eintrag bei den APN, direkt als Simyo, werde morgen mal schauen, wie der Empfang so ist.
Kf1 ist bei mir wesentlich flotter
Gerade hier zu Hause noch mal das KB3 probiert, das bekommt hier in Arona gar keinen Empfang, das KF1 dagegen sofort.
Reaktionen: rondera
Ist nun KD1 oder KF1 zu empfehlen? :)
Hab das kd1 mal vorhin geflasht und hatte danach keinen Empfang. Rom ist doc's master ics v6. Kann man eigentlauch die gjngerbread Modem bei ics nutzen?
Gesendet von meinem GT-I9000 mit Tapatalk
ich habe beide probiert und konnte damit nicht telefonieren! den ersten anruf konnte ich noch empfangen, wenn ich selbst anrufen wollte hatte ich nur sehr laute und wirre störgeräusche. danach erneut angerufen und konnte diesmal gar nichts hören. beim 3. mal wieder die störgeräusche.
habt ihr auch das problem?
quasimodo schrieb:
Quelle: xda-developers - View Single Post - [MODEMS][CM7/MIUI/ICS]Nexus S Radios KB3 and KF1 for Galaxy S
I'd say *#*#2263#*#* (e.g. -> Combi Bands -> Uncheck all but 850 MHz).
edit: Tested. Works. (gives signal). Just flashed on top of JW4.
radio-cm-7-ics-nexuss_SGS-UCKJ1-signed.zip - [Click for QR Code] (4.30 MB, 0 views)
Geht nicht zu flashen.. Datei hat nach dem DL nur 560kb bad zip
Hallo
Welches modem ist für drei in österreich am besten? Hat wer schon erfahrungen damit gemacht!?
Gesendet von meinem GT-I9000 mit der Android-Hilfe.de App
Habe die KF1 in Österreich, Innsbruck mit a1 laufen, klangqualität ist deutlich besser, zu 99% voll Empfang. Kann ich definitiv empfehlen :)
Tapatalked
Hier noch mal ein Test mit JW4 und JVT
JW4
JVT
Gleicher Standort
Reaktionen: Lambkin
welches modem funktioniert bei euch denn am besten?
gemessen am akkuverbrauch und signalstärke hsdpa/wlan?
empfang bekomme ich weder mit dem kd1 als auch mit kb3 nicht
Islaris
Islaris
wolf1425
SilvioK
  • SilvioK
SilvioK
SilvioK
