matze6989
Enthusiast
- 1.257
Wenn du meinst das ist kein problem das ukw radio ein zubauen dann mach es doch bitte... Das hat schon sein grund warum es bis jetzt keiner gemacht hat
zweimalFull changelog of 2.5.0 compared to stock CM10.1:
CM10.1 sources of 05-Feb-2013
All features compared to stock kernel:
-Mackay kernel 0.242: http://forum.xda-developers.com/show....php?t=1842324
-build using jan-13 Linaro 4.7 toolchain & O3 flags (incl GPU driver)
-updated to linux kernel version 3.0.62
-XZ compression of kernel & initramfs
-396MB RAM
-SIO scheduler
-ROW scheduler (tweaked, default scheduler)
-many improvements to IO schedulers in general
-Deadline tuning (thanks to DerTeufel)
-Ondemand tuned (default governor)
-SmartassV2 governor
-Interactive governor (updated to android 3.4 code + fixes)
-Wheatley & Lulzactive governors
-Conservative tuned
-Call volume hack (using “Settings>Advanced Settings”* to set volumes)
-Reduced battery polling interval
-Fast charge (activate through “Settings>Advanced Settings”* or the QuickCharge toggle in MackayROM)
-WiFi PM_FAST mode selection (activate using “Settings>Advanced Settings”*)
-Battery life extender (set through “Settings>Advanced Settings”*)
-CustomVoltage (set using NSTools)
-USB OTG support (needs external power supply)
-1200-1400MHz OC step
-Custom kernel splash (Thanks to Malcho)
-Updated charging logo to match open charger
-Disabled swap & zram
-Unaligned CPU access
-Improve memcopy/memmove
-Improve the performance of memcpy and memmove
-Kill task closest in size to memory needed to free
-LOAD_FREQ (4*HZ+61) avoids loadavg Moire
-Entropy tweaks: Russell: Sources of Randomness for Userspace [LWN.net]
-backport CPUIDLE from 3.5
-arm/crypto: Add optimized AES and SHA1 routines
ROM comes with stock colour & stock LED. Version with voodoo colour, BLN, and VC+BLN can be downloaded from:
rootaxbox.no-ip.org - /kasper_h/kernels/JB42/
*“Settings>Advanced Settings” only available with Mackay ROM 2.4.7+
*also available through the Mackay Settings app in the launcher
bootable/recovery:
-Mackay recovery (based on CWM 6.0.2.7)
-Clear NSTools settings
-Clear init.d settings
-Show battery status in recovery
-Aroma FileManager
-Include using soft keys to navigate the menu (thanks fishears for the idea)
Added apps:
-Gapps (Reduced version of 121212 + Updated Google Keyboard)
-AngryGPS
-YouTube HD v2b (wifi, 3G, also with screen off, normal colour scheme)
-Asus email widget
Muppi schrieb:Ich hab da mal ne Frage .
Gibt es eigentlich eine ROM, die mir z.B. per BLN mitteilt ob Multiaccountler unterwegs sind ???
Ich bitte um Entschuldigung, falls die Frage schon mal gestellt wurde .
Ist auch egal ob GB, ICS, JB .
Danke.
