linuxnutzer
Enthusiast
- 177
SecurityConsiderations - cryptonite - Some important security considerations when using EncFS on Android - EncFS and TrueCrypt on Android - Google Project Hosting
If you're using a rooted phone that supports FUSE, mounting an EncFS volume is a safer and more comfortable way to access your files because they will be transparently decrypted on-the-fly without being written to disk.
Unterstützt das SGS+ (I9001) mit Gigabread+ Fuse oder muss ich dafür CM9 installieren?
