DjSonix
Stamm-User
- 720
Here is the I9220 ZC LP5 repack for N7000. Includes CF-Root for LP5, CWM, etc.
This is a pretty dangerous flash. Personally, I would just skip this firmware altogether, but there is currently no way to revert. If you continue, you may be insane. I wish I never flashed this crap.
WARNINGS:
- Flash at your own risk
- This is a WIPE firmware, you will lose your data
- This firmware cannot be flashed with Mobile ODIN
- This firmware flash updates your bootloaders, and changes the identity of the phone to I9220. It is currently not possible to revert, and likely will not be until the official N7000 firmware is out. Even then, it is not sure. (This is about reverting bootloaders, you can still flash a GB firmware (mostly), but you're stuck with these bootloaders)
- Bootloaders are flashed, this always creates a chance for FULL HARD BRICK. Only JTAG or mobo replacement can fix!
- The firmware first boots in Chinese
- For N7000 only, do not flash this on I9220 !
- Boot partitions are not available to Android, this means Triangle Away does NOT work to remove triangle and/or reset flash counter
Instructions: USE AT YOUR OWN RISK
- Unpack the I9220_ZC_LP5_REPACK.zip file
- Extract ODIN (yes, use THIS version!)
- Reboot your note into download mode
- Flash:
--- Repartition enabled
--- Q1_20110914_16GB.pit as PIT
--- Q1_EUR_bridge_DDI_init_bootloader.tar as PDA
- Disconnect USB
- Exit ODIN
- Pull the battery
- Put the battery back in
- It will appear that your Note is now completely dead
- Boot into download mode (VolDown+Home+Power) (you will see only black screen)
- Count to 10
- Press VolUp
- Count to 10
- Start ODIN
- Plug in USB
- Flash:
--- Repartition NOT enabled
--- I9220LP5_ROOTED.tar as PDA
- Reboot
- Count to 10
- Recovery will complain a bit
- Press power to boot Android
- There may be some error messages during first boot, just press the popup buttons until it's done
- Yeah, it's in Chinese. I advise going to Settings and changing your language to English
- Copy gapps-6.0-IML74L.zip to /sdcard
- Open CWM app (make sure sdcard is not mounted to your computer!), and select Flash update (not any of the other options, easy to get confused!), and select the gapps file.
- Device will reboot and install gapps (Market, YouTube, etc)
- Done
Download: https://hotfile.com/dl/151802857/778...EPACK.zip.html
Mirrors, thanks to juggies:
I9220_ZC_LP5_REPACK.zip (656,54 MB) - uploaded.to
http://www.wupload.com/file/26832212...LP5_REPACK.zip
WARNINGS:
- Flash:
- Disconnect USB
- Exit ODIN
- Pull the battery
- Count to 10
- Press VolUp
- Count to 10
- Start ODIN
- Plug in USB
- Flash:
- Reboot
- Count to 10
- Done
