[MOD] Call Recording-N7000 ICS
  • 0 Antworten
Cpt. Future
Gast
Call Recording mode for N7000- ICS roms
Guys,
Glad to present you with call recorder mod for ICS (though checked on Indian version, should work on all official ICS) rooted stock deodexed roms. Can be flashed for odex as well but you need to delete phone.odex & phone_util.odex files manually from system/app folder.
Infact i pushed files to the concerned locations maually & changed the permissions. It's working flawless. records both ways & it's very clear. stored in internal sd card/sounds in .amr format.
I made a flashable zip for convenient. Flash it through recovery. If you have odex files, will get force close till you delete the above said files & reboot.
Download here: Call recording-N7000-ICS.zip
So flash it at your own risk. don't blame me if your note puffs smoke
Für jene User die diese Funktion in Ihren ICS Roms vermissen!
Quelle:
(mod) call recording-n7000 ics - xda-developers
Reaktionen: 149217
