ChaosWare
Der user PabloPL von den XDA Developers hat eine unofizielle version des ClockworkMod Recovery rausgebracht.
Link
Originalbeitrag von PabloPL:
Hi
Today i managed to run the newest Clockwork Recovery on my Galaxy Ace. It has some problem with graphics (as you can see on screenshots).
I've tested following options (and for me they are working):
- wipe Data/Factory reset
- wipe cache partition
- some options under advanced menu (to wipe)
- install zip from SDCard (tested on some file from UOT kitchen)
- reboot recovery
- mount USB storage (and other mount options) Better not try to format partitions from recovery yet - it could format them to ext4 for which we probably not have yet support in kernel.
Know bugs:
- poweroff sems to reboot phone
- problem with graphics (probably framebuffer is set to 24 or 32 bpp mode. There is also missing double buffer support in framebuffer - thats why we have 2 recovery screens)
I've also managed to create nandroid backup of all partitions (boot,recovery,data and system) but not tried yet to restore them.
Phone info
In recovery mode (sorry for terrible image quality)
I've attached packed recovery.img. it's based on KPH firmware + root in adb (in both boot and recovery mode) + su binary.
Remember, I am not reponsible if you brick your phone. You're flashing this on your own risk.Not all options are tested!!!.
For now don't try to backup/restore!.
How to flash:
1. take KPH firmware
2. extract CODE_S5830XXKPH_CL260130_REV03_user_low_true.tar.m d5
- tar xvf CODE_S5830XXKPH_CL260130_REV03_user_low_true.tar.m d5
3. replace recovery.img with attached file
4. pack it back
- tar -H ustar -c boot.img recovery.img data.rfs system.rfs >ODIN_FILE.tar
- md5sum -t ODIN_FILE.tar >>ODIN_FILE.tar
- mv ODIN_FILE.tar ODIN_FILE.tar.md5
5. flash it with odin
To move in recovery:
- Volume up/down to move.
- Home (center key) to select item.
- Back to move back.
Gruß, Chris
Link
Hi
- reboot recovery
Know bugs:
Phone info
How to flash:
4. pack it back
Gruß, Chris
