ChaosWare
Fixed using CF-Root's CWM4 kernel (a kernel with a patched pm2.c, thanks to ilarrain) and add 2 lines command to init.rc to load jbd2 and ext4 modules.
For CyanogenMod 7.1 and advance user only for now!
How to flash:
- Boot your device into CWM recovery
- Push recovery-clockwork-5.0.2.3-galaxyace.img to your device using "adb push recovery-clockwork-5.0.2.3-galaxyace.img /tmp/" command
- Login to your device over "adb shell"
- Mount /system using "mount /dev/block/stl12 /system" command
- Flash CWM recovery using "flash_image recoveryonly /tmp/recovery-clockwork-5.0.2.3-galaxyace.img" command
- Umount /system using "umount /system" command
- Reboot your device using "reboot recovery" command to test your new CWM recovery
Not fully tested and have no enough space to try the backup/restore function![]()
EDIT:
Recovery flashable zip added.
EDIT2:
Please try the *-fix.zip version.
Changelog:
- mount, umount, and rm scripts taken from my CF-Root-S5830 CWM to fix mount error problem
- /etc/recovery.fstab changed to mount /sd-ext partition and to fix recovery backup problem
EmoBoiix3 and Lovetz, waiting for your report![]()
EDIT3:
The fix version almost same as clockwork-5.0.2.6 I have modified before and shared here by Grif_05, except:
- remove a garbage file
- ext4 support compiled in kernel, not as a module
- using new Samsung proprietary modules taken from DXKPD
XDA
Gruß, Chris
... aber diese fehlermeldung hatte ich (zum glück) bisher nie ... hat immer reibungslos funktioniert, sowohl in der 4rer als auch in der 5er version
