SeraphimSerapis
Enthusiast
- 1.233
Custom-Recovery Images erlauben Euch, Backups zu erstellen oder die beliebten Custom-Roms zu flashen.
Dieser Thread soll eine kleine Übersicht über bisherige Recovery Images geben.
Amon_RA - 1.7.0.1 RA-nexus Recovery Image:
http://forum.xda-developers.com/showthread.php?t=611829
Flashen:
Change-log:
v1.7.0.1
Fixed fix_permissions script to use use /sd-ext instead of /system/sd as mountpoint
Fixed unmount script to also unmount /sd-ext
Nandroid menu option now backups/restores /cache again by default
Fixed wipe script, dalvik-cache is wiped in /cache /data and /sd-ext if present
Changed selected menu-text color to black for the cyan version
ROM Manager and Clockwork Recovery Image 1.7.6
http://www.koushikdutta.com/2010/02/clockwork-recovery-image.html
Flashen: Am einfachsten über den ROM Manager selbst. Kann auf der verlinkten Website heruntergeladen werden oder im Market bezogen werden. Ansonsten per fastboot das Recovery genauso wie Amon_RA flashen.
Change-log:
1.6.9 Rewritten Nandroid that supports backup and restore status. Bug fixes.
1.6.0 ROM Manager support. Scrollable file browser.
1.4.2 Added mount USB storage and got rid of the scary Android error background! Also disabled signature checks by default when recovery is user initiated.
Flashen:
fastboot flash recovery recovery-RA-nexus-v1.7.0.1.img
Change-log:
v1.7.0.1
Change-log:
