MarciWoi
Dauer-User
- 191
Hey Leute,
Es gibt einen neuen JB Rom fürs XOOM! Habe ihn gerade am laufen und er fühlt sich schneller und smoother an als JB von Team Eos. Aber versucht selbst ;- ) .
Hier mal die Feature Liste:
* Based off of Clean Android 4.1.1 Rev4 (JRO03L)
* File Manager Included
* T-mobile Theme Manager (tmobile, CyanogenMod, xoomdev)
* T9 Dialer/Landscape/Dialpad Settings (CyanogenMod)
* Trebuchet Custom Launcher (CyanogenMod)
* Ability to set custom ringtone delay (in phone settings - Netboy)
* Framework: added support for caller name display (kenshin)
* Framework: added HSPA+ support (shows H+ icon on status bar when connected to hspa+ - Bajee11)
* Framework: ability to set custom carrier label (Netboy)
* Browser: option open tab in incognito mode (Arham Jamal)
* Browser: option to close all other tabs (Arham Jamal)
* Browser: unhid the user agent settings
* DeskClock: added stopwatch and countdown timer (Jorge Ruesga)
* DeskClock: added settings to do nothing/snooze/dismiss and alarm by flipping the device (maurodec)
* DeskClock: you can set an alarm to switch your profile (jorge ruesga)
* Email: added meeting time to email invitation tab (erezak)
* Email: added option to enable/disable LED notifications per email account (apohl79)
* Keyboard: ability to use the volume buttons to move the cursor (romanbb)
* Bluetooth: AVRCP 1.3 (Trey Briggs)
* Settings: ADB over Network (enable TCP/IP debugging over Network interfaces (WiFi, Usb networks)
* Settings: Added option to disable volume adjustment sound (Settings -> Sound - StevenHarper)
* Settings: Option to change the devices hostname
* Settings: Hardware info in about phone (romanbb)
* Settings: Added nfc poling (sethyx)
* Custom Camera App: (CyanogenMod)
- Continuos focus
- Iso Support
- Support for red eye reduction
- Ability to use the power button to take pictures
* Customizable Messaging App:
- Added the ability to display a pop-up QuickMessage when an Sms message is received (DvTonder)
- Added call sender and quick reply notification actions (DvTonder)
- Added Emoji patch from CM MMS app (Robert Burns)
- SMS Templates (rciovati)
- Custom Vibrations (mssmison)
- Timestamp Options (aravance)
* Customizable Phone App (CM)
- Advanced Phone settings (optional vib on outgoing or incoming call or every 45 seconds)
* Customizable Power Menu (codenamedroid)
- Reboot Menu
- Profile Switcher
- Screenshot
- Airplane Mode
- Navigation bar toggle
- Silent toggle
* Customizable Status Bar: (Miui, CyanogenMod, romanbb, sethyx, kejar, syaoran12 ,romanbb, Stevespear426, Kyle Teague, Whitehawkx)
- Battery Icon style
- Battery Icon in notification bar
- Miui style battery bar
- Clock style
- Customizable Clock Color
- Clock Am/Pm style
- Clock Day of the Week
- Customizable Signal Text
- Customizable WiFi Signal Text
- Ability to slide your finger across the status bar to control brightness
- Notification counter
* Customizable Notification bar:
- Notification bar Power Widget (Cvcps, DvTonder – CyanogenMod)
- Notification bar Toogles (AOKP - romanbb)
* Customizable Navigation Bar: (Zaphod-Beeblebrox, KhasMek, romanbb, akellar)
- Ability to enable/disable the navigation bar (enable toggle in power menu settings)
- Customizable navigation button actions
- Custom navigation bar ring targets (Team Eos, modified by Codenamedroid)
- customizable navigation bar color (Team Eos, modified by Codenamedroid)
- Customizable navigation button and button glow color
- Menu button visibility and location
- Number of navigation buttons
- Order of navigation buttons
- Navigation bar size
- Navigation bar transparency
* Customizable Lockscreen:
- Up to eight configurable lockscreen targets (Codenamedroid)
- Added optional centered lockscreen layout (Codenamedroid)
- Optional centered lockscreen clock
- Option to disable vibration on the lockscreen (StevenHarper)
- Customizable number of lockscreen targets (CyanogenMod)
- Configurable lockscreen wallpaper (Danesh M)
- Option to always show lockscreen battery (Blunden)
- Add weather to the lockscreen (DvTonder, Danesh M, Marius Volkhart, Rick C, Aokp)
- Add calendar reminders to the lockscreen (David Morgan)
- Lockscreen before secure unlock (Danesh M)
- Ability to unlock with menu (CyanogenMod)
- Quick pin unlock (unlock with pin/password without pressing ok – CyanogenMod)
* Customizable Sound Settings:
- Customizable volume panel (Stevespear426)
- Configurable ascending ringtone (Danny Baumann)
- Safe headset volume (CyanogenMod)
- Volume rocker music controls (CyanogenMod)
- Ability to customize action taken when connecting a headset (syaoran12)
- Face down actions (syaoran12)
* Customizable Display Settings: (CyanogenMod)
- Customizable Rotation Modes
- Customizable LED Pulse (Duration and Color)
- Volume wake (tap either the up or down volume key to wake your phone from sleep)
- Volume music controls (long press volume buttons to skip tracks)
* Custom Profiles (CyanogenMod)
- assign different profiles to change the behavior of your phone to your liking
* Quiet Hours (CyanogenMod)
- the ability to set when notification sounds, haptic feedback, vibration and notification light will function[/color]
* Performance Settings:
- Start-up tweaks (kejar, Jrummy)
- Processor Speed (xoomdev)
- Voltage controls (xoomdev)
- Kernel controls (kejar, Jrummy)
* Developer Options:
- Propmodder (Jdkoreclipse)
- Spare Parts
- Development app
- Testing Settings
CODENAME ANDROID WEBSITE
CODENAME ANDROID TWITTER
DOWNLOAD ROM
DOWNLOAD GAPPS
XDA Seite
Codename Android 3.5.0 – 3.6.0 Changelog
[Phones added] (Stable):
Galaxy S3 International - i9300
[Phones added] (Beta):
Galaxy S3 Att
Galaxy S3 Sprint
Galaxy S3 T-Mobile
Galaxy S3 US Cellular
Galaxy S3 Verizon
[improvements]
* updated AOSP base to 4.1.1_r6 (JRO03R)
* seperated the ability to center the lock screen widgets and the lock screen targets widget
* better performing wifi connection
* wifi will no longer avoid poor connections if not connected to a mobile network
* HTML 5 video user experience and stability fixes and network optimizations
* better text rendering
* enabled fdatasync for SQLite
[additions]
* added 720p recording support to the nexus 7 (Mark Kennard)
* added theme, smiley, emoji, strip unicode and date support for Mms Quick Message
* added sms over bluetooth (i.e. ability to read sms via car stereo)
* added feature to configure wifi idle timeout (Entropy512)
* added the ability to have up to 5 customizable ring targets (Steve Spear)
* lockscreen widgets can now be on the right, centered, or on the left (FaultException)
* added timer snapshot support to the camera (Jonathan Steadman)
* added burst mode to the camera (Jared Caliendo - up to 20 pictures at a time)
* added jpeg quality settings to the camera (Jared Caliendo)
* added settings for enabling and disabling WebGL in the browser
* added option for preloading media in the browser
[general]
* better multilanguage support
* moved ring targets feature into the navigation bar settings
* re-organized all phone settings
* power widget no longer shows data options if they arent supported
* added landscape layout for the color picker
[kernel]
* Updated Galaxy Nexus Kernel - Faux 21 Mainline Series
* Updated Nexus S Kernel - Air Kernel 211
[fixes]
* fixed navigation bar settings force closing on the xoom
* fixed weird black line about Mms text feild
* fixed small down arrow when keyboard is up and phone is in landscape
* fixed wi-max power widget toggle
* fixed export-to-storage function in contacts
* bluetooth audio streaming should be fixed across all music apps and hardware
* fixed tethering issue that was occurring on some devices
* reverted to previous CPU Settings while preserving the new voltage settings (more universal, should fix weird issues on Nexus S)
* automatic lock screen weather refresh will no longer cause freezes
WEDER ICH ODER ANDROID-HILFE ÜBERNEHMEN DIE VERANTWORTUNG FÜR DAS WAS IHR TUT. BENUTZUNG AUF EIGENER GEFAHR!
Grüße Marcel
- Continuos focus
- Iso Support
- Reboot Menu
- Profile Switcher
- Screenshot
- Airplane Mode
- Silent toggle
- Clock style
- Clock Am/Pm style
- Spare Parts
- Development app
- Testing Settings
DOWNLOAD ROM
DOWNLOAD GAPPS
XDA Seite
Galaxy S3 Att
Galaxy S3 Sprint
Galaxy S3 T-Mobile
Galaxy S3 Verizon
[improvements]
[additions]
[general]
[kernel]
[fixes]
Grüße Marcel
