TimeTurn
Inventar
- 5.557
Does it work with the old versions of mkyaffs2image and unyaffs? Should so i think? So why not using the old versions of that commands - problem solved
TimeTurn schrieb:Does it work with the old versions of mkyaffs2image and unyaffs? Should so i think? So why not using the old versions of that commands - problem solved![]()
-FuFu- schrieb:i will test later again with a clean system and only root, maybe it works...
but its a little bug, for me its not a problem to root again after restore
nadlabak schrieb:Skrilax_CZ: when you put dumb (from your linux dist) in /etc/terminfo/d/ and export TERM=dumb and TERMINFO=/etc/terminfo, it suppresses the use of color codes in nano. So I guess that "only" the implementation of the cursor and CTRL keys divides us from the working nano editor in OpenRecovery console. We might also create a terminfo specific for the OR console...
nano for android: Nano editor for Android - Android @ MoDaCo
