Skrilax_CZ
- 95
- Themenstarter
- #21
And if you press Alt + Z or Alt + Y (with the .keyb_qwertz in it) - does it print 6 on Z or on Y?
E:Could not find the update-binary
Aexel schrieb:Hi,
hopefully i am on the right thread now.
I am running OpenRecovery 1.14 (TimeTurnMOD version as well as GOT version, but makes no difference - still same issue) on my Motorola Milestone with stock Android 2.1 (bugfix release).
My device was rooted with UniversalAndroot 1.6.1 and after that i flashed the vulnerable system recovery SBF so that OpenRecovery works.
Now i tried to update my old Superuser App installation with a new one. No matter i take the market version or the update zip from XDA-Thread ("[APP] Superuser 2.3.2.1 - Now on the Market [2010-08-15] - xda-developers") it is necessary to update the old su binaries with an update.zip via the recovery console.
Anyway, if i try to flash the update.zip through the OpenRecovery Console it always aborts with the following error:
The error occures with this http://bit.ly/su2321ef as well as the su-binary update.zip from by the market version.Code:E:Could not find the update-binary
Can you please tell me if this is an problem of the update or a problem of my device?
Tanks!
Skrilax_CZ schrieb:Just add there the update-binary from the test flash in updates folder. But I've got some issues with the 2.3.2.1 superuser.apk; that's why I use the 2.2.2 so far.
TimeTurn schrieb:@Aexel: Das wäre eher was für den Thread zu meinem Mod gewesen.
Du musst nur die "Superuser.apk" in OpenRecovery/root ersetzen und dann nochmal mit dem Script rooten, Du brauchst also keine update.zip ausführen.
Just replace "Superuser.apk" in "OpenRecovery/root" with the new one and root the phone again - no need to execute the "update.zip".
thanksSkrilax_CZ schrieb:color3 is three bit color in #RGB format (only use 0 or 1, so yellow would be #110, green #010 etc.)
TimeTurn schrieb:@Aexel: Replace "su" in "OpenRecovery/root" too, but remove or rename the "Superuser.apk" there. Remove and reinstall root. The script can't find the APK anymore and so it can't be copied to /system/app.
Now only the "su" command should be left un your system and you can install "Superuser" from the Market.
-FuFu- schrieb:@Skrilax
is it possible to set more then one imenu in a script?
i just test to use RES and RES2 in same script to use 2 interactive menus, but both values from RES and RES2 the same, when i select in first imenu option 3 and in second imenu option 1, the value from RES and RES2 are both 3...
both imenus have different headers and different answers
