[Download] DSI Fix
  • 6 Antworten
Soxes
Gast
ab sofort wird hier der Download für die neuste Version des DSI-Fixes von nadlabak gepostet.
Zur Diskussion des Fixes (auf Deutsch) geht es hier: https://www.android-hilfe.de/forum/...ne.60/diskussion-dsi-fix-nadlabak.134279.html
Hier werden als NUR die neusten Versionen gepostet und keine Diskussionen gemacht...
@Mods: Bitte anpinnen.
AKTUELLE VERSION: 2.32
Current release for testing: v2.32 (2011/08/11) - Multiupload.com - upload your files to multiple file hosting sites!
Put it to /system/lib/modules.
Please attach /data/dontpanic/apanic_console [in case of reboot] or dmesg [in case of temporary freeze] to your report.
Neuer Fix von Kabaldan. Hab ihm meinen dmesg & apanic_console geschickt. Hoffe das hilft ihm weiter.
Current release for testing: v2.4 (2011/08/13) - Multiupload.com - upload your files to multiple file hosting sites!
Sein Zitat:
I've decided to return back to error recovery scheduling variant (used in DSI-fix v1) and to try to solve the dss power domain not entering target state when suspending after error recovery happened.
As I see "Successfully put all powerdomains to target state" in dmesg even after "DSI-fix: scheduling error recovery / DSI-fix: recovering from error", I guess that I succeeded :D.
Reaktionen: papadawg
DSI-FIX v2.51 Nadla hatte mit v2.5 einige Probleme mit Freezes. Deswegen das Mini-Update
Changelog: DSI-fix module v2.52 - force hw reset in case of framedone timeout
Download: DSI-FIX v2.52
Credits to nadlabak!
Changelog:
nadlabak: As I've experienced about 20s freeze when running DSI-fix v2.51 in the end after several days of flawless use, I've made new DSI-fix v2.52.
In 2.52, dsi hw reset is always forced when framedone timeout appears (previously it was sw reset + communication test, and hw reset afterwards only when the test failed).
As I'm experiencing the common OMAP SD card issue pointed out by HinotoriBR here: http://forum.xda-developers.com/show...postcount=5563
I've added omap hsmmc set_data_timeout kernel function replacement to DSI-fix v2.6.
Therefore DSI-fix becomes DSI/MMC-fix now.
Download: DSI/MMC-fix v2.6
Reaktionen: christian7301
