Incoe
Okeee ich kapier das nicht so richtig
aber das soll ja nichts heißen^^ bin beim deven ja keine könner
The Ape schrieb:"inside .tar is the mot_boot_mode script, that actually makes all this possible without a custom kernel."
weil es einiges an arbeit ist, bis es funktioniert, da man wie in dem betrag beschrieben wird, libs und co ausgetauscht und von unserem 2.1 übernommen werden müßen, damit es auch wirklich funktioniert....ironslaya schrieb:Hm.. und wieso probierts da niemand aus?
Ich würds testen aber mein Milestone hat gerade mein Vater![]()
!!THIS PART IS IMPORTANT!!
7. remember to update your build.prop , so it does not load the libril-moto.so , but uses the libril-moto-umts-1.so from the milestone 2.1 image.
if you do not do this, you might brick the milestone radio, as mine simply never got a radio working again.. but i hope that this was the reason and nothing else.
if you brick your radio, and cannot make calls out, its on your own responsibility, but i hope im right on the libril drivers making it all messed up.
so doing it like explained here, you should be good to go on debugging this and see if works for you.
cardex schrieb:könnte auch daran liegen
wenn er sich also irrt, ist essig mit deinem telefon
he_stheone64 schrieb:I would recommend a closed beta with some of the more experienced users, this will help you getting more feedback and limit the possible risks. These guys will make a nandroid anyway, before they install your ROM.
eybee1970 schrieb:yes, but who could previously assure, that you are still able to start recovery after custom rom...maybe you have a 'full' brick
The Ape schrieb:someone has to take the risk, like the devs did...but, mea culpa, i will not be the one to do it...
just trow in some video & photo proofs and the community will throw some response back...
