FameZ!
- 2
Guten Abend an alle,
bin gerade auf das hier gestoßen:
motorola_milestone:modes:bootloader_mode [And Developers]
würde uns eine BL mit Fastboot was bringen???
anscheinend ein DevPhone Bootloader!
Fastboot
Fastboot is protocol used to update the flash filesystem in Android devices from a host over USB. It allows flashing of unsigned partition images. It is disabled in the production G1 devices since USB support is disabled in the bootloader[1]. This can be changed if you get root on the device. See also [2]
Fastboot
