adb in recovery
  • 51 Antworten
wenn mir jemand ein Nandroid Backup, vorzugsweise o2 FW 2.0 zur Verfügung stellt, spiele ich es von meiner HK 2.01 Version ein.
also ich war mal so mutig und habe mich mit Backups und Restore versucht, und es hat alles problemlos geklappt. :D
Hier nun ein sauberes deutsches nicht gerootetes 2.0 Backup.
Firmware-Konfiguration: GAS_EMEA_USASHLS00RTDACH_P001
Hier nun der Downloadlink :
UPDATE 02.02.2010 adbrecovery V5 backup
http://alldroid.org/viewtopic.php?f=259&t=1808
Code:
# begin build properties
# autogenerated by buildinfo.sh
ro.build.id=SHOLS_U2_01.03.1
ro.build.display.id=SHOLS_U2_01.03.1.1257641482
ro.build.version.incremental=1257641482
ro.build.version.sdk=5
ro.build.version.codename=REL
ro.build.version.release=2.0
ro.build.date=Thu Nov 5 17:33:01 PST 2009
ro.build.date.utc=1257471181
ro.build.type=user
ro.build.user=a21146
ro.build.host=ca25rhe76
ro.build.tags=rel-keys
ro.product.model=Milestone
ro.product.brand=MOTO_O2DE
ro.product.name=umts_sholes
ro.product.device=umts_sholes
ro.product.board=sholes
ro.product.cpu.abi=armeabi
ro.product.manufacturer=motorola
ro.product.locale.language=de
ro.product.locale.region=DE
ro.wifi.channels=
ro.board.platform=omap3
# ro.build.product is obsolete; use ro.product.device
ro.build.product=umts_sholes
# Do not try to parse ro.build.description or .fingerprint
ro.build.description=umts_sholes-user 2.0 SHOLS_U2_01.03.1 1257641482 rel-keys
ro.build.fingerprint=MOTO_O2DE/umts_sholes/umts_sholes/sholes:2.0/SHOLS_U2_01.03.1/1257641482:user/rel-keys
# end build properties
# system.prop for UMTS Sholes
rild.libpath=/system/lib/libril-moto-umts-1.so
rild.libargs=-d /dev/ttyS0
ro.sf.lcd_density=240
# Default network type.
# 3 -> GSM/WCDMA (auto mode, according to PRL)
# AVAILABLE Application Settings menu
ro.telephony.default_network=3
wifi.interface = tiwlan0
# Time between scans in seconds. Keep it high to minimize battery drain.
# This only affects the case in which there are remembered access points,
# but none are in range.
wifi.supplicant_scan_interval = 15
# The OpenGL ES API level that is natively supported by this device.
# This is a 16.16 fixed point number
ro.opengles.version = 131072
# This is a high density device with more memory, so larger vm heaps for it.
dalvik.vm.heapsize=24m
# ADDITIONAL_BUILD_PROPERTIES
ro.product.multi_touch_enabled=true
ro.product.max_num_touch=2
ro.product.tfdt_string=com.motorola.android.app.tfdt.START
dalvik.vm.jniopts=warnonly
ro.com.motorola.smartsensor=true
ro.config.notification_sound=F1_New_SMS.ogg
ro.config.alarm_alert=Alarm_Classic.ogg
ro.telephony.call_ring.multiple=false
ro.telephony.call_ring.delay=3000
ro.url.safetylegal=http://www.motorola.com/staticfiles/Support/legal/?model=A855
ro.setupwizard.enable_bypass=1
ro.media.enc.hprof.file.format=mp4
ro.media.enc.hprof.codec.vid=h264
ro.media.enc.hprof.codec.aud=aac
ro.media.enc.hprof.vid.width=720
ro.media.enc.hprof.vid.height=480
ro.media.enc.hprof.vid.fps=25
ro.media.enc.hprof.vid.bps=3000000
ro.media.enc.hprof.aud.bps=96000
ro.media.enc.hprof.aud.hz=16000
ro.media.enc.hprof.aud.ch=1
ro.media.enc.hprof.duration=60
ro.media.enc.lprof.file.format=mp4
ro.media.enc.lprof.codec.vid=m4v
ro.media.enc.lprof.codec.aud=amrnb
ro.media.enc.lprof.vid.width=320
ro.media.enc.lprof.vid.height=240
ro.media.enc.lprof.vid.fps=15
ro.media.enc.lprof.vid.bps=200000
ro.media.enc.lprof.aud.bps=12200
ro.media.enc.lprof.aud.hz=8000
ro.media.enc.lprof.aud.ch=1
ro.media.enc.lprof.duration=30
ro.media.enc.file.format=3gp,mp4
ro.media.enc.vid.codec=h264,m4v,h263
ro.media.enc.aud.codec=aac,amrnb
ro.media.enc.vid.h264.width=176,720
ro.media.enc.vid.h264.height=144,480
ro.media.enc.vid.h264.bps=64000,8000000
ro.media.enc.vid.h264.fps=1,30
ro.media.enc.vid.h263.width=176,720
ro.media.enc.vid.h263.height=144,480
ro.media.enc.vid.h263.bps=64000,8000000
ro.media.enc.vid.h263.fps=1,30
ro.media.enc.vid.m4v.width=176,720
ro.media.enc.vid.m4v.height=144,480
ro.media.enc.vid.m4v.bps=64000,8000000
ro.media.enc.vid.m4v.fps=1,30
ro.media.enc.aud.amrnb.bps=5525,12200
ro.media.enc.aud.amrnb.hz=8000,8000
ro.media.enc.aud.amrnb.ch=1,1
ro.media.enc.aud.aac.bps=8192,96000
ro.media.enc.aud.aac.hz=16000,16000
ro.media.enc.aud.aac.ch=1,1
ro.media.dec.aud.wma.enabled=1
ro.media.dec.vid.wmv.enabled=1
ro.media.cam.preview.fps=0
ro.com.google.clientid=android-motorola
ro.url.legal=http://www.google.com/intl/%s/mobile/android/basic/phone-legal.html
ro.url.legal.android_privacy=http://www.google.com/intl/%s/mobile/android/basic/privacy.html
ro.config.sync=yes
dalvik.vm.dexopt-flags=m=y
net.bt.name=Android
dalvik.vm.stack-trace-file=/data/anr/traces.txt
ro.config.ringtone=Red_Beats.ogg
ro.com.google.clientidbase=android-motorola
ro.setupwizard.mode=OPTIONAL
und jetzt wäre es noch nett, wenn du erklären könntest, wie du das gemacht hast, und wie das restoren funktioniert ;)
vor allem würde mich interessieren, wie ich nur einzelne img´s restoren kann. wenn ich z.b. nur system oder data wiederherstellen möchte..
ich bin im übrigen grad auch damit am experimentieren, aber dei "Dumping misc" hängt der jetzt schon ein paar minuten. ist das normal?
EDIT:
okay, auf alldroid ist jetzt eine anleitung online http://alldroid.org/viewtopic.php?f=259&t=1808
werde heute abend (wenn mein akku wieder voll ist) ein backup meines o2-gerätes ohne root online stellen.
Reaktionen: b.pwned
Unter obigen Link werden auch backups gesammelt. Dort finden alle, die unbedingt von der HK-Version weg wollen die DACH-Version von Android 2.0.
Hab jetzt mal aus dem alldroid board das deutsche update genommen... also adb zugang aus der recovery bekomm ich und kann auch den restore befehl ausführen nur irgendwie erkennt er das backup nicht wie genau muss ich das denn auf die sd card packen? und was muss ich in der adb für nen suchstring eingeben
habs jetzt auf die sd card unter nandroid/backups/2.0-DACH-BRS-20100130-1647 gepackt
EDIT:
okay, auf alldroid ist jetzt eine anleitung online AllDroid - View topic - Nandroid Backups wanted
Also wenn du z.B. nur system wiederherstellen möchtest gibts du folgendes ein :
nandroid-mobile.sh --restore --nodata --nocache --nomisc --noboot --norecovery
Könntest du das vielleicht noch auf megaupload oder so tun? Rapidshare geht als Free-User irgendwie fast gar nicht mehr.
@ sandimann,
vielen Dank für Dein Nandroid Backup. Ich bin gerade von meiner HK 2.0.1 Firmware runter. Allerdings musste ich 2x wipen; einmal vor dem Flashen und nachdem ich Dein Nandroid Backup eingespielt habe.
Jetzt geht es wieder zurück zur HK, bis das deutsche Update released wird.
Cu Puky70
Kann mir mal bitte einer Erklären wie ich das Backup auf mein Stein kriege
Wenn ich in der ADB Shell den Befehl eingebe kommt folgendes:
Allerdings weiß ich nicht ob ich da was eingeben muss...
Die Zip wo der Ordner mit dem Recovery drin ist hab ich einfach auf die SD-Karte in nandroid/backups kopiert...
du musst die zip schon etpacken ;)
Jaa kla entpackt hab ich sie ;) Und den Ordner hab ich in das wie schon beschreiben nandroid/backup directory gepackt....
Ich habe als erstes ein Backup angelegt, welches in dem automatisch angelegten Verzeichnis /nandroid/console=ttyS2,115200n8/ gespeichert wurde.
Von diesem Pfad aus habe auch heruntergeladene backups eingespielt.
danke so hats geklappt
Mhh jetzt stürzen Reiheweise Prozesse ab wenn ich das Handy starte und wenn ich in den Recovery Mode möchte (Kamera+Power) komm ich in den Bootloader...
mache mal einen Wipe; war bei mir genauso. Beim nächsten Reboot sollte alles laufen ;):D
Hatte ich weiter oben schon geschrieben....
Recovery Mode:
Einschalten + Kamera Taste
Anschließend Lauter Taste + Kamera
Und wie mach ich ein Wipe wenn ich nicht ins Recovery Menü komme?
siehe oben; ins Recovery musst kommen.
coolzero3389
coolzero3389
coolzero3389
  • Gesperrt
  • tuxinator09
Cua
Cua
Thoxx
  • Thoxx
Thoxx
Thoxx
