[RAM Script] Tweaking Juwe11's RAM script for O2X, good for all ROM support init.d
  • 3 Antworten
Magiya
Magiya
Preface
The script is actually Base on Juwe11's RAM script
which you can found here... http://forum.xda-developers.com/show....php?t=1111145
Main Content
The adj value of his script is a bit too tight for Our O2X...
so the Launcher is killed quite often if many apps opened in the background.
Here's the adj value changes I made, originally, Juwe11's values are..
"0,1,2,4,6,15" and I change it to, "0,1,2,7,8,9"
the forth value is for HIDDEN_APP_MIN_ADJ, which including the Launcher (I'm using LauncherPro) belongs to this category when you open some foreground application.
the default android value for this is also 7, and I find the OOM value for Launcher is 6 usually... so Juwe11's "4" will lead to our Launcher being Killed, keep it at 7, never tried to have mine killed yet.
The last 2 vaule just make sure the last category EMPTY_APP_ADJ is kill earlier than the previous..
About the minfree vaule...
I change it to "1536,3072,4096,7680,8960,10240" which actually the same values of "Moderate preset" of autokiller which is enough to ensure most RAM being use before killing for fasting task switching...
Credit
!! Credit goes to Juwe11 for his mighty RAM script~ !!
Backup your RAMscript and remove it to somewhere before install this...
install via CWM, it will put the script into your /etc/inti.d/ that's it, boot and try
Quelle:
[RAM Script] Tweaking Juwe11's RAM script for O2X, good for all ROM support init.d - xda-developers
ich hab das Script jetzt einen Tag lang in Benutzung. Ich kann keinen Unterschied zu vorher (ohne das script) feststellen. Bei mir lief und läuft alles flüssig. Hat jemand andere Erfahrungen gemacht?
CM7-176
Was sollte das ganze denn bewirken?
