Touchscreen calibration
  • 1 Antworten
monkeydrufy
Hi guys,
I'm sorry to write in english but I can't write german.
if you try the app "touchmove" you will see that the touch sensitive is set to 2px and it is not much related to the hd resolution, usually the best value is 5px
checking into the touchscreen folder I've found the file "atmel_cmi_pro.img"
and editing it I saw:
#TOUCH_PROXIMITY_T23
17 0f 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
do you think that changing this value will change the sensibility?
if not there is a way to calibrate the touchscreen?
thanks
Reaktionen: holzwerk
Does it work?
sunset666
