segler11
Gast
- Themenstarter
- #81
So hier mal meine geänderte BoardConfig.mk, vielleicht mag mal wer ein Auge drauf werfen ?
Code:
USE_CAMERA_STUB := true
# inherit from the proprietary version
-include vendor/Huawei/Mediapad/BoardConfigVendor.mk
TARGET_NO_BOOTLOADER := true
TARGET_BOARD_PLATFORM := msm8660
TARGET_CPU_ABI := armeabi-v7a
TARGET_CPU_ABI2 := armeabi
TARGET_BOOTLOADER_BOARD_NAME := Mediapad
BOARD_KERNEL_CMDLINE := console=ttyHSL0,115200,n8 androidboot.hardware=hws7300u vmalloc=578M kgsl.ptcount=16
BOARD_KERNEL_BASE := 0x40300000
BOARD_KERNEL_PAGESIZE := 00002048
BOARD_RECOVERY_HANDLES_MOUNT := true
# fix this up by examining /proc/mtd on a running device
BOARD_BOOTIMAGE_PARTITION_SIZE := 0x00520000
BOARD_RECOVERYIMAGE_PARTITION_SIZE := 0x00650000
BOARD_SYSTEMIMAGE_PARTITION_SIZE := 0x08c60000
BOARD_USERDATAIMAGE_PARTITION_SIZE := 0x105c0000
BOARD_FLASH_BLOCK_SIZE := 131072
TARGET_PREBUILT_KERNEL := device/Huawei/Mediapad/kernel
TARGET_RECOVERY_INITRC := device/Huawei/Mediapad/recovery.rc
# Indicate that the board has an Internal SD Card
# Below is a sample of how you can tweak the mount points using the board config.
BOARD_DATA_DEVICE := /dev/block/mmcblk0p27
BOARD_DATA_FILESYSTEM := ext4
BOARD_CACHE_DEVICE := /dev/block/mmcblk0p22
BOARD_CACHE_FILESYSTEM := ext4
BOARD_SDCARD_DEVICE_PRIMARY := /dev/block/mmcblk0p15
BOARD_SDCARD_DEVICE_INTERNAL := /dev/block/mmcblk0p15
BOARD_SDCARD_DEVICE_EXTERNAL := /mnt/external vfat /dev/block/mmcblk1p1 /dev/block/mmcblk1
#BOARD_HAS_NO_SELECT_BUTTON := true
# Use this flag if the board has a ext4 partition larger than 2gb
BOARD_HAS_LARGE_FILESYSTEM := true
