Problem flashing ROMs. Need your help.
  • 0 Antworten
burkaygenc
I have been flashing many ROMs recently to my Ideos X3. I have tried the following ROMs:
* Fire X3: flashes but goes into CWM recovery on reboot
* Fire X3: flashes but stuck on boot animation
* LuckyICSGSM 4.0.4: flashes but goes into CWM recovery on reboot
* LewaOS: flashes and starts, however many functions such as WiFi doesn't work
* Lightweight X3: flashes and works fine.
The reason I am writing these is because other people note that they can flash and use the first four ROMs above. I can only flash "lightweight". What am I doing wrong that I cannot have what other can?
Is there something special I need to do before flashing the above ROMs? A special partitioning scheme? Is an sd-ext partition required? If you have successfully installed one of the above ROMs, can you please tell me your sd card partitions and their types, such as ext-2, ext-4 etc.
thank you all for the help.
