ICS CM7 ~ Port des CyanogenMods 7.x mit anschließendem ICS-Theming
  • 348 Antworten
teammat3
(the reason i created a new topic, is that, this ROM has so many modifications, that I consider it as a complete different one.)
Caracteristics
- Baseado na ROM: CyanogenMod-7.2.0 -- benru89 - Android 2.3.7
- Pre-configured & optimized
- Compatible with U8510 (X3) & U8650
- Complete ICS look
- Build.prop cleaned and revised multiple times
- Android 4.0 Boot Animation
- Many Icons added, edited and revised
- 360 Launcher moddded to fit ICS LOOK
- Battery optimized (after you callibrate it, and using no-frills config that i recommend)
- ICS Animations
- FM, GPS, Bluetooth, 3G & Wi-fi working
- New Adreno200 drivers (thanks Dimon)
- Overclock stable up to 748 mhz
- ICS Ringtones
- ICS Fonts
CHANGELOG
-New Adreno200 drivers
-ZeamLauncher replaced by 360Launcher modded, modificado
-Winamp replaced by MIUI Music
-Added EMAIL, Spare Parts
-Titanium Backup Updated
- StatusBar transparency fixed
-Many icons edited
-joseph96 framework addded & edited
-Some joseph96 deodexed files added
-Some fonts changed
-Build.prop edited
-Added some scripts
-Many ICS Ringtones added
-Boot Logo changed
Screenshots
Recommended Spare-Parts config:
- Window animations e transition animations : FAST
- Font size: extra small
- Haptic feedback disabled
Benchmarks a 748mhz​
Recommended config for better battery duration
Instructions:
1- Do all backups (contact, messages, etc..)
2- Turn off phone
3- Turn phone on by pressing the VOL+ button with the energy button at the same time.
4- Mount and storage
5- Format Boot, Format Cache, Format Data e Format System.
6- Back to the Recovery Clockwork main menu and select wipe data/factory reset e wipe cache partition
7- Select Advanced & wipe dalvik cache.
8- Back to the Recovery Clockwork main menu and select Install zip from sdcard
9- Select the first choice and search for ICS CM7 [by teammat3] DE.zip on your sd card
10- Reboot system
Thank you all that helped and supported me <3​
Reaktionen: Krid86, Tetsujin, Lice und 29 andere
What do
consist of? Something a none programmer understands or is more detailed knowledge needed? :)
Oh yeah and has the tethering/hot-spot bug been fixed? I think it was something with the build.prop
greets
Download link updated.
@teammat3
why is your rom not deodexed?
Und.... schon erste Erfahrungen mit der ROM?
Mir ist bei der "alten" Version aufgefallen, dass sich die autom. Bildschirmausrichtung nicht abstellen lässt. Und irgendwie ist mein Battery-Indikator immer nur kurz an und geht von alleine wieder aus (Batterieanzeige in der Statusleiste).
Bin mal gespannt
Also diese Benchmark-Ergebnisse sind ja ganz nett, aber trotzdem läuft das "offizielle" 2.3.6-Update bei mir besser, als irgendwelche Custom-Roms...
kann ich nicht bestätigen
schonmal eine andere Anzeige ausprobiert?
(einstellungen -> cyanogenmod -> benutzeroberfläche -> statusleiste -> batteriestatusanzeige)
Erstmal die ROM ist echt der Wahnsinn aber leider gibt es wieder Probleme mit den appdrawer sobald ich z.B. sentinel3 starte und wieder beende muss der kommplette laucher neustarten dies passierte auch als ich nach Zig Sachen einstellen fertig war
First, the ROM is really madness but unfortunately there are more problems with the appdrawer as soon as I sentinel3 start again and finish must come plete Laucher restart this happened as I was set to Zig things done
Also die ROM läuft erstmal prima.
Nur diesmal bekomme ich die Superuserrechte nicht für den es-eXPLORER, um titanium runterzuschmeissen.... echt scheibe!
Jetzt ist zwar die Energiesteuerung in der Statusleiste nicht mehr transparent, aber dafür wurden die Anzeigen ebenfalls "geschwärzt", bzw. sind nun kaum noch zu lesen (dunkle Schrift auf schwarzem Hintergrund). Oh man, was soll das denn nun?
Was hast du gegen Ti²? Ich hab das App mit dieser Rom lieben gelernt ;)
Well well, i installed the Rom and i have many suggestions:
1) The weather plugin, i cannot choose any german city...
2) dark fonts on dark ground
3) on the first look i think the 360 Launcher are too overloaded, may i need time for it ;)
Thanks for your great work! I will test the Rom for a Day or two and give feedback :)
Versuche meine Kontakte aus der sim-karte zu "impotieren" aber in der Anzeigeoptionen kann ich die Sim Karte nicht finden?? Ist Bei euch auch so?
EDIT: Habs gefunden, mein Fehler!!!
Great rom, thanx!
- one thing i would change: dark font on dark background
- one thing, that doesn`t seem to work: mobile hotspot / tethering
Would be great, if you could fix these two points :thumbup:
Greetings,
silversurfer
Da es sich hier um die lite handelt, kann man kein Batch durchlaufen lassen. Ich habe aber die Pro-version die nur zu installieren ist wenn die Lite weg ist.
Hab es aber wieder geschafft. Hab nur den Pkt. im ES nicht gesehen, in dem man die Root-funktion freischaltet... :thumbup:
Folgendes Problem habe ich festgestellt, ich habe zurück zum Supertoast gewechselt aber das Logo (brauner Kuchen) ist leider erhalten geblieben. Habe auch andere Roms aufgespielt und es gehtnicht weg... Jedes mal wenn das Handy neu bootet ist es da... Hat jemand gleiches Problem oder weiss eine Lösung wie man es loswerden kann?
are these the modified adreno 200 driver files and can i overwrite those in your other rom?:
Code:
libEGL_adreno200.so
libGLES_android.so
libGLESv1_CM_adreno200.so
libGLESv2_adreno200.so
libq3dtools_adreno200.so
Welches Logo meinst du genau?
Das Logo, welches nicht animiert ist und nach dem Neustarten als erstes auftaucht?
oder das Logo, welches danach kommt und animiert ist?
oder beide?
Zum ersten, nicht animierten Logo gibt es hier eine Anleitung.
https://www.android-hilfe.de/forum/....425/how-to-splash-screen-flashen.192795.html
Möglicherweise wird das zweite animierte Logo damit auch automatisch wiederhergestellt. (?)
Ansonsten gibt es hier vielleicht Hilfe für das animierte Logo:
https://www.android-hilfe.de/forum/...ei-ideos-x3.425/bootanimation-usw.146334.html
Möglich, dass es aber auch eine einfachere Methode gibt.
Reaktionen: MindTeazer
wie schaut es bei euch mit der automatischen Bildschirmhelligkeit aus wen man sie automatisieren will ist unter Display -> Helligkeit kein Hacken für automatische Bildschirmhelligkeit die einstellung unter Cyanogen mod kan man zwar aktivieren aber sie funktioniert trotzdem nicht.
gibt es da wege diese einstellungen wieder zum Laufen zu Bringen ???
how it looks at you with automatic screen brightness from whom you want to automate it is under Display -> Enable automatic brightness no hooks for screen brightness adjustment under the Cyanogen mod but you kan but it does not work anyway.
these paths are there settings to bring up and running again?
- 360 Launcher is stylish but slow
- SMS App grey letters on black background
