morpheus620
Android-Guru
- 2.822
na siehst du.geht doch
es muss ja gehen.die modder bekommen das ja auch hin ^^
morpheus620 schrieb:na siehst du.geht doch
Error log: UOT-04-18-15-07-7-SHTF.txt
Decompiling framework-res.apk UOT-04-18-15-07-7
I: Loading resource table...
I: Loaded.
I: Decoding file-resources...
I: Decoding values*/* XMLs...
I: Done.
I: Copying assets and libs...
Decompiling SystemUI.apk UOT-04-18-15-07-7
I: Framework installed to: /root/apktool/framework/1.apk
I: Baksmaling...
I: Loaded.
I: Loading resource table from file: /root/apktool/framework/1.apk
I: Loaded.
W: Could not decode attr value, using undecoded value instead: ns=android, name=theme, value=0x02060002
I: Done.
Can't find framework resources for package of id: 2. You must install proper framework files, see project website for more info.
Compiling framework-res.apk UOT-04-18-15-07-7
W: Could not find sources
I: Building resources...
I: Building apk file...
Compiling SystemUI.apk UOT-04-18-15-07-7
I: Framework installed to: /home/uot/apktool/framework/1.apk
Exception in thread "main" brut.androlib.AndrolibException: brut.directory.PathNotExist: apktool.yml
at brut.androlib.Androlib.readMetaFile(Androlib.java:142)
at brut.androlib.Androlib.build(Androlib.java:159)
at brut.androlib.Androlib.build(Androlib.java:154)
at brut.apktool.Main.cmdBuild(Main.java:182)
at brut.apktool.Main.main(Main.java:67)
Caused by: brut.directory.PathNotExist: apktool.yml
at brut.directory.AbstractDirectory.getFileInput(AbstractDirectory.java:103)
at brut.androlib.Androlib.readMetaFile(Androlib.java:138)
... 4 more
In deinem Fall müsste es also das sein, ist dsa richtig?Files you need to upload:
Froyo rom: framework-res.apk
Gingerbread rom: framework-res.apk and SystemUI.apk
Gingerbread with sense rom: framework-res.apk, SystemUI.apk and com.htc.resources.apk
Cyanogenmod7 rom: Cyanbread.apk or Androidian.apk or any theme for ThemeChooser (rename as you like it to apear in theme menu)
