Heart
von jetzt auf gleich habe ich nur noch das "SD-Karte wird vorbereitet" Symbol oben in der Taskleiste
Habe sie daraufhin auch ausgebaut und per Adapter und Lesegerät an den PC gesteckt, nix... auf windows.
Dann der Versuch auf Linux, was mir folgende Logs generiert:
Code:
Apr 18 20:03:22 laptop kernel: [ 1132.304067] usb 1-2: new high speed USB device using ehci_hcd and address 2
Apr 18 20:03:22 laptop kernel: [ 1132.531207] Initializing USB Mass Storage driver...
Apr 18 20:03:22 laptop kernel: [ 1132.531337] scsi6 : usb-storage 1-2:1.0
Apr 18 20:03:22 laptop kernel: [ 1132.531510] usbcore: registered new interface driver usb-storage
Apr 18 20:03:22 laptop kernel: [ 1132.531513] USB Mass Storage support registered.
Apr 18 20:03:23 laptop kernel: [ 1133.535658] scsi 6:0:0:0: Direct-Access HTC Desire 0100 PQ: 0 ANSI: 2
Apr 18 20:03:23 laptop kernel: [ 1133.539903] sd 6:0:0:0: Attached scsi generic sg2 type 0
Apr 18 20:03:23 laptop kernel: [ 1133.561490] sd 6:0:0:0: [sdb] Attached SCSI removable disk
Apr 18 20:14:53 laptop kernel: [ 1823.120223] sd 6:0:0:0: [sdb] 14474502 512-byte logical blocks: (7.41 GB/6.90 GiB)
Apr 18 20:14:53 laptop kernel: [ 1823.128657] sdb:
Apr 18 20:15:01 laptop kernel: [ 1831.897429] sd 6:0:0:0: [sdb] Unhandled sense code
Apr 18 20:15:01 laptop kernel: [ 1831.897439] sd 6:0:0:0: [sdb] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
Apr 18 20:15:01 laptop kernel: [ 1831.897449] sd 6:0:0:0: [sdb] Sense Key : Medium Error [current]
Apr 18 20:15:01 laptop kernel: [ 1831.897460] Info fld=0x800
Apr 18 20:15:01 laptop kernel: [ 1831.897465] sd 6:0:0:0: [sdb] Add. Sense: Unrecovered read error
Apr 18 20:15:01 laptop kernel: [ 1831.897476] sd 6:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 08 00 00 00 08 00
Apr 18 20:15:01 laptop kernel: [ 1831.897509] quiet_error: 27 callbacks suppressed
Apr 18 20:15:03 laptop kernel: [ 1833.761793] sd 6:0:0:0: [sdb] Unhandled sense code
Apr 18 20:15:03 laptop kernel: [ 1833.761803] sd 6:0:0:0: [sdb] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
Apr 18 20:15:03 laptop kernel: [ 1833.761813] sd 6:0:0:0: [sdb] Sense Key : Medium Error [current]
Apr 18 20:15:03 laptop kernel: [ 1833.761825] Info fld=0x800
Apr 18 20:15:03 laptop kernel: [ 1833.761829] sd 6:0:0:0: [sdb] Add. Sense: Unrecovered read error
Apr 18 20:15:03 laptop kernel: [ 1833.761841] sd 6:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 08 00 00 00 08 00
Apr 18 20:15:05 laptop kernel: [ 1835.811288] sd 6:0:0:0: [sdb] Unhandled sense code
Apr 18 20:15:05 laptop kernel: [ 1835.811298] sd 6:0:0:0: [sdb] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
Apr 18 20:15:05 laptop kernel: [ 1835.811308] sd 6:0:0:0: [sdb] Sense Key : Medium Error [current]
Apr 18 20:15:05 laptop kernel: [ 1835.811320] Info fld=0x800
Apr 18 20:15:05 laptop kernel: [ 1835.811324] sd 6:0:0:0: [sdb] Add. Sense: Unrecovered read error
Apr 18 20:15:05 laptop kernel: [ 1835.811336] sd 6:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 08 00 00 00 08 00
Apr 18 20:15:07 laptop kernel: [ 1837.680147] sd 6:0:0:0: [sdb] Unhandled sense code
Apr 18 20:15:07 laptop kernel: [ 1837.680158] sd 6:0:0:0: [sdb] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
Apr 18 20:15:07 laptop kernel: [ 1837.680168] sd 6:0:0:0: [sdb] Sense Key : Medium Error [current]
Apr 18 20:15:07 laptop kernel: [ 1837.680179] Info fld=0x800
Apr 18 20:15:07 laptop kernel: [ 1837.680184] sd 6:0:0:0: [sdb] Add. Sense: Unrecovered read error
Apr 18 20:15:07 laptop kernel: [ 1837.680195] sd 6:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 08 00 00 00 08 00
Apr 18 20:15:07 laptop kernel: [ 1837.680227] quiet_error: 2 callbacks suppressed
Apr 18 20:15:09 laptop kernel: [ 1839.853517] sd 6:0:0:0: [sdb] Unhandled sense code
Apr 18 20:15:09 laptop kernel: [ 1839.853527] sd 6:0:0:0: [sdb] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
Apr 18 20:15:09 laptop kernel: [ 1839.853537] sd 6:0:0:0: [sdb] Sense Key : Medium Error [current]
Apr 18 20:15:09 laptop kernel: [ 1839.853548] Info fld=0x8ee
Apr 18 20:15:09 laptop kernel: [ 1839.853553] sd 6:0:0:0: [sdb] Add. Sense: Unrecovered read error
Apr 18 20:15:09 laptop kernel: [ 1839.853564] sd 6:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 08 ee 00 00 01 00
Apr 18 20:15:11 laptop kernel: [ 1841.721166] sd 6:0:0:0: [sdb] Unhandled sense code
Apr 18 20:15:11 laptop kernel: [ 1841.721176] sd 6:0:0:0: [sdb] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
Apr 18 20:15:11 laptop kernel: [ 1841.721186] sd 6:0:0:0: [sdb] Sense Key : Medium Error [current]
Apr 18 20:15:11 laptop kernel: [ 1841.721198] Info fld=0x8ee
Apr 18 20:15:11 laptop kernel: [ 1841.721202] sd 6:0:0:0: [sdb] Add. Sense: Unrecovered read error
Apr 18 20:15:11 laptop kernel: [ 1841.721214] sd 6:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 08 ee 00 00 01 00
Apr 18 20:15:13 laptop kernel: [ 1843.586979] sd 6:0:0:0: [sdb] Unhandled sense code
Apr 18 20:15:13 laptop kernel: [ 1843.586986] sd 6:0:0:0: [sdb] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
Apr 18 20:15:13 laptop kernel: [ 1843.586991] sd 6:0:0:0: [sdb] Sense Key : Medium Error [current]
Apr 18 20:15:13 laptop kernel: [ 1843.586997] Info fld=0x8ee
Apr 18 20:15:13 laptop kernel: [ 1843.586999] sd 6:0:0:0: [sdb] Add. Sense: Unrecovered read error
Apr 18 20:15:13 laptop kernel: [ 1843.587004] sd 6:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 08 ee 00 00 01 00
Apr 18 20:15:15 laptop kernel: [ 1845.451232] sd 6:0:0:0: [sdb] Unhandled sense code
Apr 18 20:15:15 laptop kernel: [ 1845.451242] sd 6:0:0:0: [sdb] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
Apr 18 20:15:15 laptop kernel: [ 1845.451252] sd 6:0:0:0: [sdb] Sense Key : Medium Error [current]
Apr 18 20:15:15 laptop kernel: [ 1845.451264] Info fld=0x8ee
Apr 18 20:15:15 laptop kernel: [ 1845.451268] sd 6:0:0:0: [sdb] Add. Sense: Unrecovered read error
Apr 18 20:15:15 laptop kernel: [ 1845.451280] sd 6:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 08 ee 00 00 01 00
Apr 18 20:15:17 laptop kernel: [ 1847.316606] sd 6:0:0:0: [sdb] Unhandled sense code
Apr 18 20:15:17 laptop kernel: [ 1847.316616] sd 6:0:0:0: [sdb] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
Apr 18 20:15:17 laptop kernel: [ 1847.316626] sd 6:0:0:0: [sdb] Sense Key : Medium Error [current]
Apr 18 20:15:17 laptop kernel: [ 1847.316637] Info fld=0x8ee
Apr 18 20:15:17 laptop kernel: [ 1847.316642] sd 6:0:0:0: [sdb] Add. Sense: Unrecovered read error
Apr 18 20:15:17 laptop kernel: [ 1847.316653] sd 6:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 08 ee 00 00 01 00
Apr 18 20:15:19 laptop kernel: [ 1849.182699] sd 6:0:0:0: [sdb] Unhandled sense code
Apr 18 20:15:19 laptop kernel: [ 1849.182706] sd 6:0:0:0: [sdb] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
Apr 18 20:15:19 laptop kernel: [ 1849.182711] sd 6:0:0:0: [sdb] Sense Key : Medium Error [current]
Apr 18 20:15:19 laptop kernel: [ 1849.182717] Info fld=0x8ee
Apr 18 20:15:19 laptop kernel: [ 1849.182719] sd 6:0:0:0: [sdb] Add. Sense: Unrecovered read error
Apr 18 20:15:19 laptop kernel: [ 1849.182724] sd 6:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 08 ee 00 00 01 00
Apr 18 20:15:20 laptop kernel: [ 1851.054340] sd 6:0:0:0: [sdb] Unhandled sense code
Apr 18 20:15:20 laptop kernel: [ 1851.054350] sd 6:0:0:0: [sdb] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
Apr 18 20:15:20 laptop kernel: [ 1851.054360] sd 6:0:0:0: [sdb] Sense Key : Medium Error [current]
Apr 18 20:15:20 laptop kernel: [ 1851.054371] Info fld=0x8ee
Apr 18 20:15:20 laptop kernel: [ 1851.054375] sd 6:0:0:0: [sdb] Add. Sense: Unrecovered read error
Apr 18 20:15:20 laptop kernel: [ 1851.054387] sd 6:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 08 ee 00 00 01 00
Apr 18 20:15:22 laptop kernel: [ 1852.920574] sd 6:0:0:0: [sdb] Unhandled sense code
Apr 18 20:15:22 laptop kernel: [ 1852.920584] sd 6:0:0:0: [sdb] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
Apr 18 20:15:22 laptop kernel: [ 1852.920594] sd 6:0:0:0: [sdb] Sense Key : Medium Error [current]
Apr 18 20:15:22 laptop kernel: [ 1852.920605] Info fld=0x8ee
Apr 18 20:15:22 laptop kernel: [ 1852.920610] sd 6:0:0:0: [sdb] Add. Sense: Unrecovered read error
Apr 18 20:15:22 laptop kernel: [ 1852.920621] sd 6:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 08 ee 00 00 01 00
Apr 18 20:15:24 laptop kernel: [ 1854.785673] sd 6:0:0:0: [sdb] Unhandled sense code
Apr 18 20:15:24 laptop kernel: [ 1854.785679] sd 6:0:0:0: [sdb] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
Apr 18 20:15:24 laptop kernel: [ 1854.785684] sd 6:0:0:0: [sdb] Sense Key : Medium Error [current]
Apr 18 20:15:24 laptop kernel: [ 1854.785690] Info fld=0x8ee
Apr 18 20:15:24 laptop kernel: [ 1854.785692] sd 6:0:0:0: [sdb] Add. Sense: Unrecovered read error
Apr 18 20:15:24 laptop kernel: [ 1854.785698] sd 6:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 08 ee 00 00 01 00
Apr 18 20:15:26 laptop kernel: [ 1856.650056] sd 6:0:0:0: [sdb] Unhandled sense code
Apr 18 20:15:26 laptop kernel: [ 1856.650066] sd 6:0:0:0: [sdb] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
Apr 18 20:15:26 laptop kernel: [ 1856.650076] sd 6:0:0:0: [sdb] Sense Key : Medium Error [current]
Apr 18 20:15:26 laptop kernel: [ 1856.650087] Info fld=0x8ee
Apr 18 20:15:26 laptop kernel: [ 1856.650092] sd 6:0:0:0: [sdb] Add. Sense: Unrecovered read error
Apr 18 20:15:26 laptop kernel: [ 1856.650110] sd 6:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 08 ee 00 00 01 00
Apr 18 20:15:28 laptop kernel: [ 1858.520427] sd 6:0:0:0: [sdb] Unhandled sense code
Apr 18 20:15:28 laptop kernel: [ 1858.520436] sd 6:0:0:0: [sdb] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
Apr 18 20:15:28 laptop kernel: [ 1858.520446] sd 6:0:0:0: [sdb] Sense Key : Medium Error [current]
Apr 18 20:15:28 laptop kernel: [ 1858.520458] Info fld=0x8ee
Apr 18 20:15:28 laptop kernel: [ 1858.520462] sd 6:0:0:0: [sdb] Add. Sense: Unrecovered read error
Apr 18 20:15:28 laptop kernel: [ 1858.520474] sd 6:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 08 ee 00 00 01 00
Apr 18 20:15:30 laptop kernel: [ 1860.390162] sd 6:0:0:0: [sdb] Unhandled sense code
Apr 18 20:15:30 laptop kernel: [ 1860.390172] sd 6:0:0:0: [sdb] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
Apr 18 20:15:30 laptop kernel: [ 1860.390182] sd 6:0:0:0: [sdb] Sense Key : Medium Error [current]
Apr 18 20:15:30 laptop kernel: [ 1860.390194] Info fld=0x8ee
Apr 18 20:15:30 laptop kernel: [ 1860.390199] sd 6:0:0:0: [sdb] Add. Sense: Unrecovered read error
Apr 18 20:15:30 laptop kernel: [ 1860.390210] sd 6:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 08 ee 00 00 01 00
Apr 18 20:15:32 laptop kernel: [ 1862.258642] sd 6:0:0:0: [sdb] Unhandled sense code
Apr 18 20:15:32 laptop kernel: [ 1862.258648] sd 6:0:0:0: [sdb] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
Apr 18 20:15:32 laptop kernel: [ 1862.258653] sd 6:0:0:0: [sdb] Sense Key : Medium Error [current]
Apr 18 20:15:32 laptop kernel: [ 1862.258659] Info fld=0x8ee
Apr 18 20:15:32 laptop kernel: [ 1862.258662] sd 6:0:0:0: [sdb] Add. Sense: Unrecovered read error
Apr 18 20:15:32 laptop kernel: [ 1862.258667] sd 6:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 08 ee 00 00 01 00
Apr 18 20:15:34 laptop kernel: [ 1864.124139] sd 6:0:0:0: [sdb] Unhandled sense code
Apr 18 20:15:34 laptop kernel: [ 1864.124149] sd 6:0:0:0: [sdb] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
Apr 18 20:15:34 laptop kernel: [ 1864.124159] sd 6:0:0:0: [sdb] Sense Key : Medium Error [current]
Apr 18 20:15:34 laptop kernel: [ 1864.124170] Info fld=0x8ee
Apr 18 20:15:34 laptop kernel: [ 1864.124175] sd 6:0:0:0: [sdb] Add. Sense: Unrecovered read error
Apr 18 20:15:34 laptop kernel: [ 1864.124186] sd 6:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 08 ee 00 00 01 00
Apr 18 20:15:35 laptop kernel: [ 1865.989131] sd 6:0:0:0: [sdb] Unhandled sense code
Apr 18 20:15:35 laptop kernel: [ 1865.989139] sd 6:0:0:0: [sdb] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
Apr 18 20:15:35 laptop kernel: [ 1865.989148] sd 6:0:0:0: [sdb] Sense Key : Medium Error [current]
Apr 18 20:15:35 laptop kernel: [ 1865.989157] Info fld=0x8ee
Apr 18 20:15:35 laptop kernel: [ 1865.989160] sd 6:0:0:0: [sdb] Add. Sense: Unrecovered read error
Apr 18 20:15:35 laptop kernel: [ 1865.989169] sd 6:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 08 ee 00 00 01 00
Apr 18 20:15:37 laptop kernel: [ 1867.854122] sd 6:0:0:0: [sdb] Unhandled sense code
Apr 18 20:15:37 laptop kernel: [ 1867.854132] sd 6:0:0:0: [sdb] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
Apr 18 20:15:37 laptop kernel: [ 1867.854142] sd 6:0:0:0: [sdb] Sense Key : Medium Error [current]
Apr 18 20:15:37 laptop kernel: [ 1867.854153] Info fld=0x8ee
Apr 18 20:15:37 laptop kernel: [ 1867.854158] sd 6:0:0:0: [sdb] Add. Sense: Unrecovered read error
Apr 18 20:15:37 laptop kernel: [ 1867.854169] sd 6:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 08 ee 00 00 01 00
Apr 18 20:15:39 laptop kernel: [ 1869.719478] sd 6:0:0:0: [sdb] Unhandled sense code
Apr 18 20:15:39 laptop kernel: [ 1869.719487] sd 6:0:0:0: [sdb] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
Apr 18 20:15:39 laptop kernel: [ 1869.719494] sd 6:0:0:0: [sdb] Sense Key : Medium Error [current]
Apr 18 20:15:39 laptop kernel: [ 1869.719503] Info fld=0x8ee
Apr 18 20:15:39 laptop kernel: [ 1869.719507] sd 6:0:0:0: [sdb] Add. Sense: Unrecovered read error
Apr 18 20:15:39 laptop kernel: [ 1869.719515] sd 6:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 08 ee 00 00 01 00
Apr 18 20:15:41 laptop kernel: [ 1871.585225] sd 6:0:0:0: [sdb] Unhandled sense code
Apr 18 20:15:41 laptop kernel: [ 1871.585235] sd 6:0:0:0: [sdb] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
Apr 18 20:15:41 laptop kernel: [ 1871.585245] sd 6:0:0:0: [sdb] Sense Key : Medium Error [current]
Apr 18 20:15:41 laptop kernel: [ 1871.585256] Info fld=0x8ee
Apr 18 20:15:41 laptop kernel: [ 1871.585261] sd 6:0:0:0: [sdb] Add. Sense: Unrecovered read error
Apr 18 20:15:41 laptop kernel: [ 1871.585272] sd 6:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 08 ee 00 00 01 00
Apr 18 20:15:43 laptop kernel: [ 1873.525734] sd 6:0:0:0: [sdb] Unhandled sense code
Apr 18 20:15:43 laptop kernel: [ 1873.525740] sd 6:0:0:0: [sdb] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
Apr 18 20:15:43 laptop kernel: [ 1873.525745] sd 6:0:0:0: [sdb] Sense Key : Medium Error [current]
Apr 18 20:15:43 laptop kernel: [ 1873.525751] Info fld=0x8ee
Apr 18 20:15:43 laptop kernel: [ 1873.525753] sd 6:0:0:0: [sdb] Add. Sense: Unrecovered read error
Apr 18 20:15:43 laptop kernel: [ 1873.525759] sd 6:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 08 ee 00 00 01 00
Apr 18 20:15:45 laptop kernel: [ 1875.429073] sd 6:0:0:0: [sdb] Unhandled sense code
Apr 18 20:15:45 laptop kernel: [ 1875.429080] sd 6:0:0:0: [sdb] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
Apr 18 20:15:45 laptop kernel: [ 1875.429085] sd 6:0:0:0: [sdb] Sense Key : Medium Error [current]
Apr 18 20:15:45 laptop kernel: [ 1875.429091] Info fld=0xb97
Apr 18 20:15:45 laptop kernel: [ 1875.429093] sd 6:0:0:0: [sdb] Add. Sense: Unrecovered read error
Apr 18 20:15:45 laptop kernel: [ 1875.429099] sd 6:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 0b 97 00 00 01 00
Apr 18 20:15:45 laptop kernel: [ 1875.434125] VFS: busy inodes on changed media or resized disk sdb
Apr 18 20:15:45 laptop kernel: [ 1875.437105] sd 6:0:0:0: [sdb] Device not ready
Apr 18 20:15:45 laptop kernel: [ 1875.437110] sd 6:0:0:0: [sdb] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
Apr 18 20:15:45 laptop kernel: [ 1875.437115] sd 6:0:0:0: [sdb] Sense Key : Not Ready [current]
Apr 18 20:15:45 laptop kernel: [ 1875.437121] sd 6:0:0:0: [sdb] Add. Sense: Medium not present
Apr 18 20:15:45 laptop kernel: [ 1875.437128] sd 6:0:0:0: [sdb] CDB: Read(10): 28 00 00 62 d2 78 00 00 01 00
Apr 18 20:15:45 laptop kernel: [ 1875.448187] VFS: busy inodes on changed media or resized disk sdb
Apr 18 20:15:45 laptop kernel: [ 1875.511398] VFS: busy inodes on changed media or resized disk sdb
Apr 18 20:15:45 laptop kernel: [ 1875.535181] VFS: busy inodes on changed media or resized disk sdb
Apr 18 20:15:45 laptop kernel: [ 1875.544340] VFS: busy inodes on changed media or resized disk sdb
