Gast5050
Gast
Here is the latest Ziggy471 kernel for the Bravo, this is a sense kernel. I will be maintaining this thread on behalf of ziggy471 as I worked with him in the development of this kernel. I will be taking most questions and support within this thread.
"26 Oct 2010:
Kernel version 2.6.32.24
Overclocked 1.19GHz and stable.
BFS 357 CPU Scheduler
BFQ IO Scheduler
Swap enalbed
SLUB (Unqueued Allocator)
All CPU governors, Interactive is the default
CPU Undervolt control via /proc/undervolt built in, not a module
http://forum.xda-developers.com/show...voltage+module
Fix for slow SD card access
Fix for slow SD card speed with HTC's Froyo Kernel - xda-developers
CIFS
EXT4
TUN
A few tweaks here and there.
etc
Also included in the update:
1. For any ROM that has busyboxs run-parts enabled, I added a screen state frequency/governor switching script, located in /system/etc/init.d. This means you do not have to use setcpu to control the frequency or governor anymore. If you prefer not using this script, delete it
The defaults for the script:
AWAKE_GOVERNOR=interactive
AWAKE_GOVERNOR_FREQENCY_MAX=1113600″
AWAKE_GOVERNOR_FREQENCY_MIN=245000″
SLEEP_GOVERNOR=powersave
SLEEP_GOVERNOR_FREQENCY_MAX=460800″
SLEEP_GOVERNOR_FREQENCY_MIN=245000″
2. remount script that will be installed to /system/bin.
Valid input format:
remount [ro|rw|status]
ro = read only (default)
rw = read write (to make modifications)
status = current mount mode
3. hosts file that blocks most ads, if you find more, let me know"
Please Visit his site for download and to give him some props
Download: Here
Source: ziggy471's Profile - GitHub
Just a screen of the bench i got on my personal built rom.
Quelle:
[Kernel] Ziggy471's 2.6.32.24 Sense [BFS, BFQ, UV, OC, SD FIX, CIFS, TUN, EXT4, etc] - xda-developers
Habs noch nicht getestet
