Gast5050
Gast
- Kernel 2.6.32 (Overclocked & Undervolted)
- Read ahead 128Kb
- Max 1113Mhz (for now)
- minimum voltage@950mV
- maximum voltage@1300mV
- BFS (Brain F*ck Scheduler).
- CFQ Scheduler
- Pershoot's audiomod (loudness).
- EXT4
- tun.ko module
- CIFS (+utf8)
- NFS
Current acpu table:
Code:
struct clkctl_acpu_speed acpu_freq_tbl[] = {
{ 19200, CCTL(CLK_TCXO, 1), SRC_RAW, 0, 0, 950, 14000 },
{ 128000, CCTL(CLK_TCXO, 1), SRC_AXI, 0, 0, 950, 14000 },
{ 245000, CCTL(CLK_MODEM_PLL, 1), SRC_RAW, 0, 0, 950, 29000 },
/* Work arround for acpu resume hung, GPLL is turn off by arm9 */
/*{ 256000, CCTL(CLK_GLOBAL_PLL, 3), SRC_RAW, 0, 0, 1050, 29000 },*/
{ 384000, CCTL(CLK_TCXO, 1), SRC_SCPLL, 0x0A, 0, 975, 58000 },
{ 422400, CCTL(CLK_TCXO, 1), SRC_SCPLL, 0x0B, 0, 975, 117000 },
{ 460800, CCTL(CLK_TCXO, 1), SRC_SCPLL, 0x0C, 0, 1000, 117000 },
{ 499200, CCTL(CLK_TCXO, 1), SRC_SCPLL, 0x0D, 0, 1025, 117000 },
{ 537600, CCTL(CLK_TCXO, 1), SRC_SCPLL, 0x0E, 0, 1025, 117000 },
{ 576000, CCTL(CLK_TCXO, 1), SRC_SCPLL, 0x0F, 0, 1050, 117000 },
{ 614400, CCTL(CLK_TCXO, 1), SRC_SCPLL, 0x10, 0, 1075, 117000 },
{ 652800, CCTL(CLK_TCXO, 1), SRC_SCPLL, 0x11, 0, 1100, 117000 },
{ 691200, CCTL(CLK_TCXO, 1), SRC_SCPLL, 0x12, 0, 1125, 117000 },
{ 729600, CCTL(CLK_TCXO, 1), SRC_SCPLL, 0x13, 0, 1150, 117000 },
{ 768000, CCTL(CLK_TCXO, 1), SRC_SCPLL, 0x14, 0, 1175, 128000 },
{ 806400, CCTL(CLK_TCXO, 1), SRC_SCPLL, 0x15, 0, 1200, 128000 },
{ 844800, CCTL(CLK_TCXO, 1), SRC_SCPLL, 0x16, 0, 1200, 128000 },
{ 883200, CCTL(CLK_TCXO, 1), SRC_SCPLL, 0x17, 0, 1225, 128000 },
{ 921600, CCTL(CLK_TCXO, 1), SRC_SCPLL, 0x18, 0, 1225, 128000 },
{ 960000, CCTL(CLK_TCXO, 1), SRC_SCPLL, 0x19, 0, 1250, 128000 },
{ 998400, CCTL(CLK_TCXO, 1), SRC_SCPLL, 0x1A, 0, 1250, 128000 },
{ 1036800, CCTL(CLK_TCXO, 1), SRC_SCPLL, 0x1B, 0, 1275, 128000 },
{ 1075200, CCTL(CLK_TCXO, 1), SRC_SCPLL, 0x1C, 0, 1275, 128000 },
{ 1113600, CCTL(CLK_TCXO, 1), SRC_SCPLL, 0x1D, 0, 1300, 128000 },
{ 0 },
Personal github: http://github.com/richardtrip/bravo-2.6.32
Pershoot github (audiomod): http://github.com/pershoot/
Original HTC kernel: http://member.america.htc.com/downlo...d96f2c0.tar.gz
Only use this if you have a Sense ROM (no defrost/cyanogenmod/AOSPDesire/opendesire/)
Download:
Froyo Kernel V5f_HAVS@925mV min
Froyo Kernel V5f_HAVS@875mV min
Froyo Kernel V5f 1190Mhz max
Froyo Kernel V5f 1113Mhz max
No Audiomod versions:
Froyo Kernel V5f_HAVS@925mV min No Audiomod version
Froyo Kernel V5f_HAVS@875mV min No Audiomod version
Froyo Kernel V5f 1190Mhz max No Audiomod version
Froyo Kernel V5f 1113Mhz max No Audiomod version
Older kernels:
Froyo Kernel V5e_HAVS@925mV min
Froyo Kernel V5e_HAVS@875mV min
Froyo Kernel V5e 1190Mhz max
Froyo Kernel V5e 1113Mhz max
Froyo Kernel V5e_HAVS@925mV min No Audiomod version
Froyo Kernel V5e_HAVS@875mV min No Audiomod version
Froyo Kernel V5e 1190Mhz max No Audiomod version
Froyo Kernel V5e 1113Mhz max No Audiomod version
WiFi N-mode module:
WiFi N-mode V5 module
WiFi PM FAST module: WiFi PM Fast V5 module
Older version you can find here:
http://xda.richardtrip.org/kernels/Sense_kernels/
Flash with recovery or ROM Manager.
Changelog:
V5f:
- Add BFS (Brain F*CK Scheduler).
V5e SVS + HAVS kernels audiomod & noaudiomod version:
- Modded gpu driver (Thanks to snq-)
V5d HAVS kernels:
- Changed the avs table to scale less on the higher frequencies. Could be more stable if you have problems on the V5c havs kernels.
V5c HAVS kernels:
- HAVS 1113Mhz@925mV minimum
- HAVS 1113Mhz@875mV minimum
V5b Test havs kernel
V5a 1190Mhz kernel (smartass governor is in but not default).
V5a (Smartass only):
- changed default_ramp_up_step and max_ramp_down to 384000
- set smartass as default governor
V5:
- Add lzma compression for kernel images backported by snq-
- Read ahead to 128Kb
V4:
- Higher voltages (more stable, some phones had reboot problems)
V3:
WiFi PM FAST module posted (nmode also) (see this thread)
V3:
- Added interactive scheduler
V2:
- disabled debugging options
- fixed ext2/3
- added Performance and Conservative scheduler
Quelle:
[KERNEL] uv/oc 2.6.32 for Sense Roms (CFQ/UV950mV/OC1113Mhz/EXT4/Audiomod/CIFS+utf8) - xda-developers
