[KERNEL] LeeDrOiD modified Kernel [2016 MHz OC, VERY BETA] [GB, Sense]
  • 3 Antworten
Gast5050
Gast
What I have here is a VERY BETA kernel built from the latest LeeDrOiD git with some ondemand tweaks to make it a bit more responsive, as well as AXI Scaling, an undervolted bottom end at 122mhz, and with a topend of 2016mhz.
Many phones may not run at the full upper-end, but vddsys is implemented as in the LeeDrOiD kernel, so you may increase or lower the VDD by 25 for 20160000mhz to attempt to get it working.
Currently working on getting a github page up with this source. I'm running it on the Unity rom at the moment without issue. 2016mhz should only be used for benchmarks, and not 24/7.
Two way call recording is also included, as well as a startup script to run at 1843mhz ondemand at startup.
Changelog:
June24-Initial Release...Working on Cleanup.
Quelle:
[KERNEL][GBSense] 2016Mhz OC LeeDrOiD Modified Kernel-VERY BETA - xda-developers
Oha, 2GHZ...
Ich würde das meinem DHD nicht antun ^^
mfg darky
Deswegen ja auch diie Aussage
Aber mal zum Test schon interessant :)
