Infos und Fragen zur build.pro
  • 2 Antworten
Gast5050
Gast
Hier meine Erkenntnisse zur build.pro
Radio 12.54.60.25H_26.09.04.11_M2 = ro.ril.hsxpa = 1
Radio 12.54.60.25U_26.09.04.11_M2 = ro.ril.hsxpa = 2
Radio 12.54.60.25P_26.09.04.11_M2 = ro.ril.hsxpa = 3
Hier nochmal ein paar Infos dazu die ich schon gefunden habe, vielleicht hat jemand ja noch aktuellere Infos dazu.
People... the mentioned settings will only work if your network supports them!
Most important is the fact that they NEED to be set to the value that your network is currently supporting if you want to enjoy optimal speeds!!
ro.ril.hsxpa : inidcates hsxpa support of target network :
Code:
ro.ril.hsxpa=0 - UMTS r99
ro.ril.hsxpa=1 - HSDPA
ro.ril.hsxpa=2 - HSDPA/HSUPA
ro.ril.gprsclass : inidcates GPRS class of target network :
Code:
Class 2 : 3 slots : 8 - 12 kbps upload / 16 - 24 kbps download
Class 4 : 4 slots : 8 - 12 kbps upload / 24 - 36 kbps download
Class 6 : 4 slots : 24 - 36 kbps upload / 24 - 36 kbps download
Class 8 : 5 slots : 8 - 12 kbps upload / 32 - 40 kbps download
Class 10 : 5 slots : 16 - 24 kbps upload / 32 - 48 kbps download
Class 12 : 5 slots : 32 - 48 kbps upload / 32 - 48 kbps download
ro.ril.hsdpa.category :
Code:
Cat 1 = 1.2 Mbit/s
Cat 2 = 1.2 Mbit/s
Cat 3 = 1.8 Mbit/s
Cat 4 = 1.8 Mbit/s
Cat 5 = 3.6 Mbit/s
Cat 6 = 3.6 Mbit/s
Cat 7 = 7.2 Mbit/s
Cat 8 = 7.2 Mbit/s
Cat 9 = 10.1 Mbit/s
Cat 10 = 14.0 Mbit/s
Cat 11 = 0.9 Mbit/s
Cat 12 = 1.8 Mbit/s
Cat 13 = 17.6 Mbit/s
Cat 14 = 21.1 Mbit/s
Cat 15 = 23.4 Mbit/s
Cat 16 = 27.9 Mbit/s
Cat 19 = 35.3 Mbit/s
Cat 20 = 42.2 Mbit/s
Cat 21 = 23.4 Mbit/s
Cat 22 = 27.9 Mbit/s
Cat 23 = 35.3 Mbit/s
Cat 24 = 42.2 Mbit/s
Cat 25 = 46.8 Mbit/s
Cat 26 = 55.9 Mbit/s
Cat 27 = 70.6 Mbit/s
Cat 28 = 84.4 Mbit/s
ro.ril.hsupa.category :
Code:
Cat 1 = 0.73 Mbit/s
Cat 2 = 1.46 Mbit/s
Cat 3 = 1.46 Mbit/s
Cat 4 = 2.93 Mbit/s
Cat 5 = 2.00 Mbit/s
Cat 6 = 5.76 Mbit/s
Cat 7 = 11.5 Mbit/s
Not speed related, but still nice to have :
ro.ril.enable.3g.prefix : adds the 3G prefix to the operator name.
ro.ril.enable.dtm : Only set this to 1 if your network allows simultaneous transfer of Circuit switched (CS) voice and Packet switched (PS) data over the same radio channel (ARFCN).
ich war mal so frei und hab diesen post von Amon_RA von den xda-developers kopiert..
Quelle: https://www.android-hilfe.de/forum/...-edge-geschwindigkeiten-verbessern.11789.html
Nun welche Einstellungen wären z.B für Deutschland und das Vodafonenetz die besten?
Das wollte ich Dich jetzt fragen. :lol:
Wenn ich nächste Woche etwas mehr Zeit habe werde ich mal für jeweils 24h eine Einstellung testen und berichten. Bis jetzt hatte ich aber das stabilste Datennetz mit der ro.ril.hsxpa=2
Phiber2000
Lemmi
  • Lemmi
JediDevil
JediDevil
Phiber2000
