[Recovery] ClockWorkMod (CWM) 6 by koush
  • 313 Antworten
Vielen Dank blur! Man man man....
bmngoc schrieb:
die Veränderung der Pfade haben wir seit 4.3
Du bist nicht der Erste der verzweifelt seine Backups suchte :D
Reaktionen: djxspeedy
CWM Official 6.0.4.0 Changelog - maguro:
https://github.com/CyanogenMod/android_bootable_recovery/commits/cm-10.2
Jul 23, 2013 - 6.0.3.4 is a previous official, update zlib, SELinux warning display changes, add "headless" mode.
Jul 29, 2013 - 6.0.3.5 is a previous official, remove fix permissions, add reboot options to advanced menu, fixes to Superuser for JB4.3.
Aug 13, 2013 - 6.0.3.6 is the previous official, updated Superuser su_daemon install-recovery.sh method and related JB4.3 detection, update wipe data confirmation, add partition type to sdparted.
Sep 24, 2013 - 6.0.3.8 (build failure); build branch change to cm-10.2: enable mount external USB storage on /data/media devices, fix for Android Device Manager data wiping (+ bump to 6.0.3.7), fix free space reporting with secondary storage, suppress sd-ext missing error, setup_adb and vold are now pseudo-binary services improving adb keys and all storage filesystem mounting and formatting, USB mass storage is only run on-demand, don't automount external storage, add sdcard daemon, fixes for EMMC partition write reliability, backups are now gzip compressed by default, vold fixes, fix file_contexts warning, security improvements, support loki device images.
Sep 29, 2013 - 6.0.3.9 (build failure); add f2fs support for newer devices like ghost (Moto X).
Oct 1, 2013 - 6.0.4.0 is the most recent on ROM Manager, format external storage to custom fstype, fix refresh USB devices with key repeat, fix tgz multi-volume extraction, reintroduce Easter Egg, fix f2fs formatting from EDIFY.
(For an unofficial list of other changes between recent versions, see my previous changelog.)
Known Bugs / Notes:
- Key test does not have a confirmation, so if triggered by mistake a hard reset is required if no USB connection is available to make it exit.
- SELinux in JB4.3 changes the permissions of su on every boot, so after any boot back to Android you will get a su warning; it can be ignored.
- If you're using the SuperSU daemonsu then you may want to create /system/etc/.installed_su_daemon to suppress the CWM dialog to disable reflashing stock recovery (the install-recovery.sh it checks for is required to run the root daemon on ROMs without a native service).
Fastboot Images Download: ClockworkMod ROM Manager - Recoveries
Attached are recovery flashable zips of both the touch and non-touch versions.
  • cwm-recovery-clockwork-6.0.4.0-maguro.zip
  • cwm-recovery-clockwork-touch-6.0.4.0-maguro.zip
Reaktionen: Sherge69, MarcusBremen und blur
CWM Unofficial "Nightlies" Changelog - maguro:
Oct 1, 2013 - 6.0.4.0 is the previous official, format external storage to custom fstype, fix refresh USB devices with key repeat, fix tgz multi-volume extraction, reintroduce Easter Egg, fix f2fs formatting from EDIFY.
Oct 5, 2013 - 6.0.4.1 allow sideload to be used with other commands.
Oct 6, 2013 - 6.0.4.2 revision bump for new device support. No other changes.
Oct 6, 2013 - 6.0.4.3 is the most recent on ROM Manager, another version bump for new builds. No other changes.
Oct 7, 2013 - 6.0.4.4 fix touch events on some devices, updates to loki support.
Known Bugs / Notes:
- SELinux in JB4.3 changes the permissions of su on every boot, so after any boot back to Android you will get a su warning in CWM; it can be ignored.
  • cwm-recovery-clockwork-6.0.4.4.b41580-maguro.zip
  • cwm-recovery-clockwork-touch-6.0.4.4.b41579-maguro.zip
Reaktionen: Riefi, acwob, boreas und 6 andere
Leute, der Beitrag von djxspeedy war doch sehr sinnvoll
:thumbup:
bisher 14x wurden die zips downgeloaded,
aber noch kein Dankeschön
:confused:
Reaktionen: qu4nd, acwob und djxspeedy
Hey, habe mir gestern die aktuelle cwm geladen und sie per fastboot geflasht, als ich dann ein nandriod gemacht habe, und das phone automatisch starten wollte, kam es nur bis zum google logo.
An was kann das liegen, bzw. was kann ich dagegen tun?
Was ich schon versucht habe wipe des chaches!
Vielen dank für die Antworten.
Funktionieren die touch Versionen welche man per cwm Flasht?!
https://github.com/CyanogenMod/andro...ommits/cm-10.2
Nov 11, 2013 - 6.0.4.5 remove all extra "no" options (create .many_confirm to restore), optional swipe-based touch controls on some devices, reboot more cleanly, vold fixes, new "last path" option under install zip and menu fixes, make/clean build fixes.
Known Bugs / Notes:
cwm-recovery-clockwork-touch-6.0.4.5.b45070-maguro.zip
cwm-recovery-clockwork-6.0.4.5.b45071-maguro.zip
Der ursprüngliche Beitrag von 14:54 Uhr wurde um 15:13 Uhr ergänzt:
Also die 6.0.4.5 touch funktioniert bei mir ohne Probleme.
Reaktionen: Prof. Eibe, Riefi, owie und 2 andere
Ich benutze die Touch version, läuft einwandfrei :thumbup:
Die Zip´s sind doch auch per CWM einfach flashbar oder?
Ja, einfach flashen...
Reaktionen: Doogystyle
Ja einfach über CWM installieren.
auf die schnelle habe ich hier nichts dazu gefunden, bzw bin zu blöde dazu, aber ich würde gerne die musik, bilder etc vom handy löschen mit cwm. geht das so? Weil in der recovery sehe ich unter mount nur die option format data + sd. hatte schon einmal, dass bei einer option alles in die hose ging. daher vorher die frage. ich will alle bilder, musik, videos etc vom handy haben, aber das android system nicht kaputt machen, sprich quasi werksresett aber auf die custom rom ohne extra über toolkit factory image und dann custom rom flashen. wirklich nur die media dateien. die sollen weg.
danke schon mal
Genau das ist die Option, die das durchführt.
Danke dir. Hauptsache Android geht nicht putt haha. Ist mir schon mal abgeraucht.
Einfach nicht /system formatieren ohne danach was zu flashen, dann passiert das auch nicht. ;)
Ja alles gut gelaufen, wurde leider data mitformatiert, aber das ist nicht schlimm. apps nachinstallieren geht schnell. waren nicht sehr viele. und einstellungen sind auch fix wieder so wie ich will. danke dir für die hilfe
Jan 1, 2014 - 6.0.4.6 memory usage improvements, fix vold formatting, menu fixes, move all recovery settings to one file, code cleanups, update loki support to v2.1, revert to old Andy with earwiggle (I worked around this change in the ramdisk because it was hideous).
cwm-recovery-clockwork-touch-6.0.4.6.b50157-maguro.zip
cwm-recovery-clockwork-6.0.4.6.b50158-maguro.zip
Reaktionen: Irieginals, Rippenfreak, owie und 3 andere
Kann man eigentlich auch mit dem TWRP-Recovery den aktuellen CWM flashen oder lieber per fastboot ?
Kannst Du auch über TWRP machen.
damadama
Klarooo
Klarooo
  • kulLerkekzzZ
tibbertong
