• Wartungsarbeiten am Mittwoch (23.04.): Serverumzug ab 10 Uhr - Android Hilfe nur im Lesemodus verfügbar, alle Infos.
[ROM][ICS][Sense 3.5][21 Dec]RCMix ICE v1.0, First Sense Android 4.0.1 rom!!! :D
  • 58 Antworten
Slassh
Slassh
Dauer-User
354
robocik schrieb:
RCTeam presents
First Sense rom on Ice Cream Sandwich
ANDROID 4.0.3
SCREENS FOR NOW (of the 4.0.1, will make new screens soon):
Features:
  • Base - Standard 3.24.401.2 with sense 3.6 or XE 3.12.401.102 Sensation, both are Android 4.0.3
  • Kernel - Stock HTC 1.2GHz and SebastianFMs 1.5GHz modded, nice :D
  • Optimized and zipaligned apks, zipaligned with sdk16
  • Speed optimization scripts
  • init.d support
  • HTCSync working
  • Background from gallery working fine
  • Big MMS
  • HTC Beats in XE only 3.12 base for now
  • SRS and equalizer in Standard version
  • Face unlock and most of other ICS goodies
  • EVO Latin IME (standard android keyboard)
  • Nice Custom RCMix ICE bootanimation
  • Bravia engine
  • Removed HTC logging shit
  • Added Volume to wake up as choice when flashing the rom, thx Ziggy
  • Remember that this rom has the auto install script, so putt all your apks into sdcard/RCTeam/user.app and they will all install on the first boot. ;)
Known bugs:
  • You tell me, remember that this is an early leak... still test build.
Requirements:
Note:
  • I booted it with the 3.12 firmware, but dont know how the stability is with that firmware, cause i just booted with it, then i flashed the 3.24 firmware ;)
    3.24 firmware is not compatible with previous ICE rom, so if you want to go back, you need to flash the 3.12 firmware.
  • Usefull reading
  • Remember that this is an early leak... still test build.
Tips:
Changelog:
v3.1.1
  • Added the 1.5GHz modded SebastianFM kernel as a choice when flashing the rom
  • Removed wipe DATA from the superwipe, so it can be flashed over the 3.1 without loosing data.
v3.1
  • Reworked the rom to fix the nasty com.bg FCs, fixed now ;)
  • Removed one more logger
  • Replaced browser to the one from previous base to fix the flickery loading pages issue
  • Flying now ;)
v3.0
  • Rebased to the latest ICS sense ruu 3.24.401.1 android 4.0.3 sense 3.6
  • Added all tweaks as in previous versions (init.d, SD-Card read ahead, etc.)
  • Added Sony Bravia Engine
  • Updated some market apps
  • Removed some logging shit
  • Disabled OTA
  • Remember that this rom has the auto install script, so put all your apks into sdcard/RCTeam/user.app and they will all install on the first boot. ;)
v2.0
  • Rebased to the new 4.0.3 base
  • Kernel unlocked to 1.5GHz, GPU 228MHz, by SebastianFM
  • Added superwipe script into the rom, so it will wipe everything (SDCard will be spared ;))
  • Less bugs
  • added all scripts and optimizations from the previous build
v1.2 *Added Standard Sensation based version too
  • updated kernel to sebastians modded
  • removed ciq
  • added bravia engine
  • added some more tweaks
  • added new custom RCMix ICE bootanimation, very tasty :) hehe
    v1.1
    • Optimized and zipaligned apks, zipaligned with sdk16.
    • Added some optimization scripts
    • Added init.d support
    • Added a reboot apk, to make a normal/bootloader/recovery reboot. Thats until a real APM comes.
    • Cleaned out unnecessary appks (Ota, loggers and so)
    • Added social network lockscreen
    • Fixed small MMS issue
    • HTCSync is working now!
    v1.0
    • Initial release, almost stock, just added Keyboard popup animation thx capy and some minor few things.
    Download:
    3.24 and 3.12 firmware thx Kohr-Ah for the packages :)
    Kernels:
    Radios:
    • Recommended is the one included in the newest firmware, since you need to flash the firmware to get the rom to work, you will also get the recommended radio ;)
    Extras:
    • none yet...
    To do:
    • very much, i think i will wait for a newer base with most of tweaks...
    Thank you:
    • Capychimp
    • Big T
    • LeeDroid
    • SebastianFM
    • rmk
    Hall of fame of donators: (Please tell me if your nick is wrong)
    If you like this rom, give it a star ;)
    or/and
    if you're planning to get dropbox for android,
    please be one of the first 24 that use this link,
    if you use that link both me and you will get 250mb space extra! (its free)
    Vodka shots/donations appreciated ;)
    Post under construction ;)
  • [ROM][★★ICS Sense 3.6★★][22 Jan]RCMix ICE v3.1.1, Faster Smoother Better ;)
Habe ich auch schon gesehen, naja..ich warte lieber mal ab...keine lust ständig eine neue ROm zu flashen :D
bin beim flashen....
hast du da auch nen link zur orginalseite, bitte?
Läuft gut!! Aber Sense ist einfach nicht mein Ding :p
@defuxn
quelle wurde hinzugefügt
@Thrako
Tja Sense ist Geschmackssache ^^ Finde aber das sich seit sense 2.1 sehr viel getan hat war früher auch nicht so mein drin aber seit Sense 3.0 geht das schon ^^
Reaktionen: 70117
Ja stimmt, aber alleine, dass es den gutaussehenden Lockscreen von 4.0 "überschreibt" finde ich total kacke. Auch den Drawer mit Widgets habe ich hier nicht. Geht gar nicht. Es fühlt sich immer noch an wie vorher, auch wenn Sense ein paar nette features mit sich bringt.
Kommt erstmal wieder runter. ABER es läuft :p
Slassh schrieb:
Edit2.: Also nach weiteren 15min war es dann fertig.
Kann ich nicht nachvollziehen, nach 5 Minuten war der erste Schirm zu sehen.
Als extrem gewöhnungsbedüftig finde ich, daß bei ICS alle Schaltflächen in den Dialogen seitenvrkehrt zu vorher angeordnet sind
hat das rom eigentlich root?
@Dr. Locker
Hmm kp woran das lag hab auch extra mit Superwipe und noch mal manuell gewipt aber egal läuft doch jetzt ^^
@defuxn
Ist doch ne Fun-Frage jetzt oder ??? xD darauf bekommste keine Sinnvolle Antwort von mir ;)
wars nicht
der hintergedanke dazu:
da es sich ja um ein geleaktes ruu handelt, kann es ja auch sein dass das rom nicht gerottet is.
also nicht böse sein zwecks der frage^^
mfg
Sagen wir es mal so....Robocik, Capy und das restliche RCMix Team wissen was sie tun ;)
joa, nach zerlegen des roms hab ich dann auch gesehen, dass die SU.apk drin ist.
wer lesen kann ist klar im vorteil.^^
mfg
Ich melde mich auch mal wieder zu Wort:
Ich hab ne ganze halbe Stunde gebraucht, bis endlich das "Android is upgrading..." kam. Also wenn man wirklich unter 5 Minuten booten kann: Respekt!
Sense hat diese Art Lockscreen vor Android. Warum sollte HTC jetzt die Google Kopie ihres eigenen Designs nutzen nur um die 12 Vanilla Fandroids zu beruhigen?
hat das ROM eigentliche diese daemlichen Probleme?
Ich hatte extra auf die Uhr gesehen, als ich das von den 15 Minuten las.
Okay, ich hab die ersten Bugs gefunden. Aus dem Album werden nur 500 Bilder angezeigt und Musik findet er sogar garkeine.
defuxn schrieb:
wars nicht
mfg
Um von Zip zu flashen, benötigt man allerdings root. Eine RUU wird über'n PC aufgespielt ;)
Das jetzt schon ein so weit fortgeschrittener Leak aufgetaucht ist, macht Mut. HTC scheint sich echt Mühe zu geben, uns zeitnah zu versorgen.
Ich bezweifle das im Februar das ganze auch so aussehen wird.
Zumindest glaube ich nicht das sie bei Sense 3.5 bleiben werden.
Ist aber ja auch erstmal nur ne beta :)
  • candlebox
daniel9180
O
OneGamer
O
ger_kar
Bench
Bench
