[ROM] Novo7 ELF - Android 4.0.3 Essential Clean ROM v0.6
  • 7 Antworten
LouCipher
LouCipher
Ehrenmitglied
1.991
Der Original-Thread ist von Koalnivj aus dem Slatedroid.com-Forum
All the credit goes to android-kun for making this amazing Clean ROM for the Aurora!
Please see his post for details:
[ROM] Novo 7 Essential Clean ROM v0.4 for Aurora from android-kun
This links will go to the Aurora Forum for the details and to give the credit to android-kun.
Please go at the end of this post to Download the Novo 7 Elf Version!
Here's the feature list :
Feature List (Android 4.0.3 Rom):
Remove Chinese Application
Remove Games (AngryBirds,etc)
Remove Application (ES Files,Task,FileManager)
Add Google Apps (Sync Working!)
Browser
Calendar
Contact
Gmail
Google Photo (Picasa)
Music
Market
YouTube
Superuser
WiFi Location Support
VoiceSearch
Trebuchet Launcher
SetupWizard
Default Language English
build.prop Modfication (Protect Apps Listed on Market)
Changed Default Wallpaper (Phase Beam Like)
Remove ainol boot animation
and more...
I forgot to mention (Thanks assy mcghee) :
Top rocker switch works a volume control!!!
Market works fine
Location service work
Root confirmed
Change List:
03-04-2012 - 4.0.3 v0.6 Release
Updated Base rom ICOO D80 02-29-2012 ROM + Ainol v0.9 Kernel.
-Fixed Laggy Volume
-Fuxed Camera Rotation
Better Touchscreen Response
Flash Player v11.1.115.6 & Es File Explore 1.6.1.2 Installed
Force OFF Noisy Touch Sound
Added Terminal Emulator
Fixed External SD Permission (thanks KevIW)
03-03-2012 - 4.0.3 v0.5.1 Release
I merged the Base rom 03-02-2012 v0.9 (Volume keys version) and the Software part of android-kun v0.5
Elf Logo at startup
Calendar now works correctly
Smoother touch screen
02-27-2012 - 4.0.3 v0.5 Release
Updated Base rom 02-25-2012 v0.9 Pre-Alpha
-3x Smoother than previous version.
-auto hiding navigation bar on playing video.
-Adobe Flash Full Supported.
Stock Launcher.
02-22-2012 - 4.0.3 v0.4 Release
Updated Base Rom to 02-21-2012
Less Touchscreen Shake Problem
Less Sleep Power Usage (Ainol say)
Improve Performance/Benchmark Score
Remove Status Bar Volume Keys
Updated LatinIME
Added LatinIME Dictionary Pack
Fixed Darker Camera
02-17-2012 - 4.0.3 v0.3 Release
Fixed "No Internet Connection" Issues
Added Status Bar Volume Soft Key (Volume Down so Laggy...)
Updated NovaLauncher
Updated GoogleBackupTransport, GoogleLoginService
Updated Email Application (Mark All Read Mod)
init.rc Tweak (Wi-Fi Optimization, external init.d Script Support)
put a script for system/etc/init.d directories. NOT TESTED
Added Bravia Engine (Works?)
Remove Unused Library (OpenWnn)
02-13-2012 - 4.0.3 v0.2 Release
Delete Unused Library (Fruit Ninja, The Last Defender, Flash Player and some pre-installed apps)
Full Market Access (Faked Galaxy Tab 7.0 Plus)
"No Internet Connection" Strings Deleted (English Only, problem not solved)
Default launcher to switched NovoLauncer
coming back 2160p player and File Explore Apps
Market v3.4.4 Updated
Just flash with Livesuit as you would do for the Original Ainol ones...
Note:
I did not build this ROM... It was built by android-kun!
I only repacked it for the Novo 7 Elf.
I did many tests and everything seems to work very well!
I only did the 4.0.3 (I cannot find the Original 4.0.1 Rom for the Novo 7 Elf...)
Downloads:
Android 4.0.3 Essential Clean ROM v0.6 ELF
Android 4.0.3 Essential Clean ROM v0.5.1 ELF
Android 4.0.3 Essential Clean ROM v0.4 ELF
LiveSuitPack v1.09
Ainol Novo 7 Update Guide (PDF)
USB-Treiber
USB-Treiber 2
v0.5.1 hochgeladen (siehe Post 1)
Elf Logo at startup
v0.6 hochgeladen
-Fixed Laggy Volume
LouCipher schrieb:
v0.6 wird gerade hochgeladen
Funktioniert prinzipiell gut bei mir:
+ Titanium Backup funktioniert endlich
+ Super weiche Bildschirmanimationen
- Youtube zickt rum.
- Extrem laggy Internet mit Original Browser. Dolphin HD und Opera etwas besser.
Habe ohne formatieren von 0.5 geflasht.
Ich bekomm einfach keine Verbindung mit der LiveSuit! :(
Über USB auf das Aurora zuzugreifen ist kein Problem, aber sobald ich es ausschalte und die Tastenkombination drücke, kommt zwar der "USB-Sound" von Windows, aber LiveSuit öffnet einfach kein Fenster! :(
Hat jemand eine Idee woran das liegen kann?
Windows 7 32bit
Windows 7 32bit
du öffnest also LiveSuit und Bestätigst die Meldungen "Yes, Next, Format und nochmal Yes"
dann wählst du die ROM aus und öffnest. Danach erscheint ein neues Fenster und dann erst Steckst du bei Gedrückter Menü Taste das Tablet am Rechner an. Im Anschluss bei immer noch gedrückter Menü taste drückst du zwischen 5-10 mal die Ein/Ausschalttaste. Dann müsste es funktionieren.
Wichtig das gerät muss ausgeschaltet sein.
Ich hoffe ich konnte helfen.
Grüße
h2p-mobile
Danke!
Mit der LiveSuit 1.09 hab ich es jetzt hin bekommen! :)
Allerdings wirkt die Schrift jetzt "unscharf". Kennt das jemand?
Ach ja, CleanROM v7
Äh, jetzt ist die Schrift scharf... das versteh mal jemand... ;)
steve8x8
LouCipher
LouCipher
LouCipher
gromicx
sinus61
sinus61
