LouCipher
Ehrenmitglied
- 1.991
Die aktuelle Rom muss wieder mit Livesuite geflasht werden.
Update:
* Support for usb Bluetooth adapter to fix the Bluetooth headphone output
* Built-pl2303, dm9601, the tun module
* Improve support for wifi the direct
* Use the default charging parameters, reduce the heat
* Three point of view of the gravity-driven, on-demand choose to install
* System interface, browser run faster and smoother
* Built-in screenshot function (power plus the volume reduction)
* Potato, html5 compatibility to improve
* The notification bar is hidden code updates, and keep the official mode, the default is the official mode
* Full Google market, to support Google Maps wifi positioning
* Details of the program using the power of information
* Support for boot run the following script etc/init.d
* The user to install the program automatically aligned to optimize the
* Use the built-su, without authorization management
Description:
* Hide the notification bar modify are based newuser2012 ways, and would like to acknowledge
* This version for cwm version, into recovery mode update
* In order to avoid other problems, update the implementation of the recommendations wipe operation
* Other versions, such as v2, v3, the wizard, after updating the firmware package, update patch
Quelle: http://www.slatedroid.com/topic/294...-mod-by-feiyu/page__view__findpost__p__356499
Changelog Feiyu Mod 0405
Quelle: °¬Åµ¼«¹âV1/V2/¾«Áé 1.1°æ ·ÉÓðDIY 0405¹Ì¼þ ·¢²¼ - novo 7 - iMP3ËæÉíÓ°Òô -
Changelog 0329
Nach dem Flashen mit Live Suite unbedingt direkt das von euch benötigte Patch (FT5X-Toucscreen oder ELF-Patch) im CWM flashen!
Wer ein LG-Touchscreen (F5TX) besitzt muss nach dem Flashen der Rom den f5tx_fix1-Patch flashen. Danach neu starten und gucken ob der TS funktioniert. Falls nicht muss noch der f5tx_fix2_Patch geflasht werden.
Downloads:
aurora_v1_feiyu_mod_(0429)
aurora_v2_patch_(0429)
aurora_v3_patch_(0429)
elf_patch_(0429)
ADVANCED2 - adv2_patch_(0429)_pc.rar (needs PC with adb driver installed & run adv2-patch.bat file)
Ainol Novo 7 Update Guide (PDF)
Live Suite v1.09
Update:
Description:
Changelog (0418):
* Base on new 1.1 rom 0409
* No Bluetooth support
* Fixed some WiFi problems
* Support WiFi Direct and softAP
* UI and browser is faster than before
* HTML5 compatibility improvement
* Hard subtitles can be disabled (set 2160p subtilte gate off, 0405 is same)
* Change some default settings
* Hidebar only a patch, if you need, please install it yourself
* Full market, new busybox, etc...
Updates:
- support for usb Bluetooth adapter
- Support for dm9601 card
- Built-in pl2303 module
- Built-tun module
- further optimization of the gravity sensor sensitivity, and amendments to the horizontal tilt
- optimize the partition size to increase the built-in storage space
- Improve the busybox support, titanium backup directly available
- update to hide the notification bar code, modify the settings
- native launcher to replace the starter, change the default wallpaper
- upgrade to the built-in fast Figure browse, play stores
- default brightness to 30%
Note:
- hide the notification bar is modified based on the a newuser2012 methods, and would like to acknowledge
- Brush complete access to the system for the first time is always hide the status bar mode, go to display settings according to their needs change
- gravity induction test on my machine, the basic perfect, but does not rule out the possibility that assembly and I different versions exist, refresh this version still does not resolve, that as many 1r07 version of touch, I do not have the equipment adjustment test, I am sorry, I can not do anything
- Aurora firmware update to this version, I think have been more perfect, I had envisaged to achieve full and hope that we can properly use version of the flight feathers suspended updates, thank you for your support!
Changelog 0329
Übersetzt mit Google.This by tomx2h 2012.3.31 18:08
update content (internal brackets are divided into the description):
* Based on 1.1 version of the production
* GPU driver updates
* perfect html5 and flash support ( potatoes and other html5 the original can not be successful video effective, there may be part no; the flash Youku HD most smooth, ultra-clear part smooth )
* optional full-screen mode ( please refer to the following full-screen plug-in the original post a topic to understand the differences and setting of the three modes )
* integrated CWM the Recovery mode
* ( Urban GT, which in themselves support wifi Internet game the job )
* optimize the modified version of the touch driver ( including the driver of the wizard's touch also re-optimized compiler )
* Fixed gravity sensor sensitivity ( does not include gravity induction skew correction )
* capture function, the volume reduction without delay
* improve the charging current, repair usb charging ( off charger 1.5A, boot charger 1.2A; USB port is also a corresponding increase, but the charger when the charge current increase would be more heat is not recommended while playing edge charge )
* default starter replacement for ApexLauncher
models change to for the GT-I9100
play store to unlock the program
* Flash and some integrated software updates
* Default brightness 50%, off by default tactile feedback
Changelog aus dem chinesischen Forum übersetzt. ¡¾ÍƼö¸üС¿°¬Åµ¼«¹âV1/V2/¾«Áé 1.1°æ ·ÉÓðDIY 0330¹Ì¼þ ·¢²¼ - novo 7 - iMP3ËæÉíÓ°Òô -For those who don't understand mandarin, Feiyu's new rom is based on the Ainol 1.1 framework using the latest official firmware.
- Improved GPU performance.
- A better integrated flash and HTML 5. I tested it and found flash webpages and apps to be a lot smoother/responsive and less likely to encounter an error now.
- It has Wi-fi direct.
- Improved touch screen accuracy and performance.
- An enhanced accelerometer.
- Support for wireless location detection (eg. For google maps).
- Charging power has also been increased for both usb charging and power adapter charging. With that, it also comes with a warning that more heat will be produced now when charging so it is recommended to refrain from using the tablet while charging or it might overheat.
- Default launcher has been changed to Apex Launcher.
- Build.prop set to Samsung Galaxy S2.
- Google Play (formerly Android market) has been fully unlocked to show all apps.
- Clockwork Mod has been bundled with the rom (installing the rom will install clockwork mod).
- Full screen mode added to display settings. There are 3 modes. Normal which shows the buttons in all apps, full screen mode which hides the buttons, and smart mode which tries to automatically hide the buttons when an app is loaded.
- Default brightness has been reduced to 50% and vibration is disabled by default.
- The ability to take screen capture using the volume buttons has been disabled and this in turns makes the volume buttons a lot more responsive and fast again.
How to Check My Touchscreen
please check touchscreen version on working Device.
command adb or terminal this
Code:dmesg | busybox grep gt801 -i
Goodix Device = show your Goodix Device Version
FT5X Device = err
Downloads:
elf_patch_(0429)
Live Suite v1.09
v1 für gt801
v2 für f5tx
v3 für LG screen and another camera.
Aurora 4.03 feiyu mod(0418) CWM GT801-Version
f5tx_fix1
f5tx_fix2
(0418)_hidebar_patch
aurora_4.03_feiyu_mod_0418__cwm.zip
(0418)_hidebar_patch.zip
(0418)_ft5x_patch_v2.zip
(0418)_elf_patch.zip
(Danke an scorp182)
Aurora 4.03 feiyu mod(0405) GT801-Version
feiyu_mod_0405_elf_patch
feiyu_mod_0405_ft5x_patch
Aurora 4.03 feiyu mod(0329) GT801-Version
0329_f5tx_patch
0329_elf_patch
Aurora 4.03 feiyu mod(0313)
feiyu mod FIX
f5tx_fix1
f5tx_fix2
(Danke an scorp182)
0329_f5tx_patch
0329_elf_patch
feiyu mod FIX
