[ROM] Novo7 Aurora - Android 4.0.3 Essential Clean ROM v1.0a Livesuite
  • 18 Antworten
LouCipher
LouCipher
Ehrenmitglied
1.991
Der Original-Thread ist von android-kun aus dem Slatedroid.com-Forum
Es gibt 2 Versionen der v1.0 für Live Suite - Unbedingt Hinweise (Changelog) beachten-
Hello SLD Users.
my personal customized rom released. based ainol official release 01-19-2012 firmware.
does not touch the kernel, performance is the same. but optimize apps and add gapps.
and some changes. please visit more details to list.
Base ROM:
Android 4.0.3 - 01-19-2012 Official Firmware.
Android 4.0.1 - Stock Firmware
Feature List (Android 4.0.3 Rom):
Remove Chinese Application
Remove Games (AngryBirds,etc)
Remove Application (ES Files,Task,FileManager)
Add Google Apps (Sync Working!)
Browser
Calendar
Contact
Gmail
Google Photo (Picasa)
Music
Market (Full Maket Access. Faked Galaxy Tab 7.0 Plus)
YouTube​
Superuser
WiFi Location Support
VoiceSearch
Nova Launcher (Recommend Setting)
SetupWizard
Default Language English
build.prop Modfication (Protect Apps Listed on Market)
Changed Default Wallpaper (Phase Beam Like)
Remove ainol boot animation
and more...
Feature List (Android 4.0.1 Rom)
Remove Games (AngryBirds,FruitNinja,TheLastDefender)
Remove Application (ES Files,Task)
Goolge Apps
Market (Full Market Access)
Gmail
Calendar (Sync Working)
YouTube
Superuser
Wi-Fi Location Support
VoiceSearch
build.prop Tweak
and some change...
Change List:
Essential Crean Rom v1.0a LiveSuite
-Same Features CWM Version.
-Integrated Clockwork Mod (Created by fun_. Thank You!)
FT5X Version Not Tested...
How to Check My Touchscreen
please check touchscreen version on working Device.
command adb or terminal this
Code:
dmesg | busybox grep gt801 -i
Goodix Device = show your Goodix Device Version
FT5X Device = err
At You Own Risk. :rofl:
03-07-2012 - 4.0.3 v0.7 Release
Updated Base rom Ainol Official 03-01-2012 v0.9 ROM (reseased 03-07 version)
Updated Flash Player v11.1.115.7
Updated Google Play Apps (Store, Music, Books)
Added Google Apps (Currents, Maps, Movie Studio)
Changed Wallpaper
Touch Screen files (build.prop, gt80x.idc) NOT EDITED
Not Included v0.6 Features (except Terminal Emulator, SD Permission)
03-04-2012 - 4.0.3 v0.6 Release
Updated Base rom ICOO D80 02-29-2012 ROM + Ainol v0.9 Kernel.
-Fixed Laggy Volume
-Fuxed Camera Rotation
Better Touchscreen Response
Flash Player v11.1.115.6 & Es File Explore 1.6.1.2 Installed
Force OFF Noisy Touch Sound
Added Terminal Emulator
Fixed External SD Permission (thanks KevIW)
02-27-2012 - 4.0.3 v0.5 Release
Updated Base rom 02-25-2012 v0.9 Pre-Alpha
-3x Smoother than previous version.
-auto hiding navigation bar on playing video.
-Adobe Flash Full Supported.
Stock Launcher.
02-23-2012 - Plus Package v0.3 Release
Updated 3G Enabler / Disabler
Status bar Volume Key Mod included
Included Driver
02-22-2012 - 4.0.3 v0.4 Release
Updated Base Rom to 02-21-2012
Less Touchscreen Shake Problem
Less Sleep Power Usage (Ainol say)
Improve Performance/Benchmark Score
Remove Status Bar Volume Keys
Updated LatinIME
Added LatinIME Dictionary Pack
Fixed Darker Camera
02-14-2012 - Plus Package v0.2 Release
Fix Typo (Thanks Knyazev)
02-13-2012 - Plus Package v0.1 Release
Flash Support Package (Opera Only)
3G Service Enabler
Wipe Dalvik Cache
02-13-2012 - 4.0.3 v0.2 Release
Delete Unused Library (Fruit Ninja, The Last Defender, Flash Player and some pre-installed apps)
Full Market Access (Faked Galaxy Tab 7.0 Plus)
"No Internet Connection" Strings Deleted (English Only, problem not solved)
Default launcher to switched NovoLauncer
coming back 2160p player and File Explore Apps
Market v3.4.4 Updated
3G Services are Stopped. (Enabler Include)
02-10-2012 - 4.0.1 Rom First Release
Issues:
same issues official rom.
Installation:
You can install using the Live Suit. Upgrade Guide (PDF, Thanks GadgetFreakz)
Support Device:
Ainol Novo 7 Aurora (Tested)
special thanks
Roman2025
ainolmodder
FezzFest
and all developers
Downloads:
Android 4.0.3 Essential Clean ROM-FT5XTS-v1.0a
Android 4.0.3 Essential Clean ROM-GoodixTS-v1.0a
Android 4.0.3 Essential Clean ROM v0.7 Aurora
Android 4.0.3 Essential Clean ROM v0.6 Aurora
Android 4.0.3 Essential Clean ROM v0.5 Aurora
Android 4.0.3 Essential Clean ROM v0.4 Aurora
Plus Package v0.3
Plus Package v0.2
LiveSuitPack v1.09
Ainol Novo 7 Update Guide (PDF)
Reaktionen: gromicx
Oh, da war jemand schneller als ich. ;-)
funktioniert das 1:1 mit dem ELF ??
edit: hab es selber raus gefunden (in der nähe de original-thread, gibt es das selbe auf fürs ELF)
Genau die FW habe ich drauf und so sieht das aus:
Ainol Novo7 Aurora Android ICS Tablet Review - Allwinner A10 - Best 7"- Fastcardtech - ColonelZap - YouTube
Reaktionen: sinus61
v0.5 hochgeladen
02-27-2012 - 4.0.3 v0.5 Releasee
Stock Launcher.
Included Driver
leider ist in v5 das touch problem zurück :-/
v0.6 hochgeladen (siehe Post 1)
-Fixed Laggy Volume
Reaktionen: gromicx
Bin jetzt bei diesem ROM 0.6 mit dem 0.3 Script und mir ist aufgefallen, dass die touch.screen.scale auf 10 steht. Das hab ich nach folgender Anleitung auf 1 geändert. Der Digitizer-Bug ist so um einiges besser.
1. Open root explorer.
2. Goto system>usr>idc (folders)
3. Press hold gt80x.idc (file) till you see Options
4. Select Open in Text Editor
5. Look for this line: touch.size.scale = 10
6. Change the value 10 to 1 (touch.size.scale = 1)
7. Save and exit (top right corner ...)
8. Restart the tablet.
v0.7 hochgeladen
Es gibt einen Bug:
Das Display wird dunkler, wenn es länger im Standby war.
Wenn ich jedoch dann direkt wieder in den Standby und direkt wieder raus gehe, ist das Display wieder normal hell.
Changed Wallpaper
Beide Versionen hochgeladen.
Uploaded v1.0a LiveSuite Version.
Code:
FT5X Device = err
Leider hängt sich die Tablet Verschlüsselung mindestens seit der aktuellen 1.0a auf!
Ausprobiert auf frisch formatiert- und geflashtem Gerät...
Ansonsten spitzen ROM!!!
Was meinst du mit Verschlüsselung?
Mahlzeit,
die Tablet Nutzerdaten Verschlüsselung in ICS (Konten, Einstellungen, heruntergeladene Apps, Daten Medien, etc.), zu finden in den Einstellungen unter "Sicherheit" => "Tablet verschlüsseln".
Ich versuche es genauso wie vorgeschlagen, Akku voll aufgeladen, PIN/Passwort gesetzt... Ich kann die verschlüsselung auch starten, allerdings passiert dann nichts weiter für ettliche Stunden, bis auf das Anzeigen des Android Roboters im Zahnrad-Outfit...
Wenn ich dann das Gerät neustarte ist auch alles wieder wie vorher, d.h. der hat nichtmal angefangen irgendwelche Bereiche zu verschlüsseln und startet als wäre nie etwas gewesen.
Wie das vor der aktuellen Version war kann ich nicht sagen, da ich es jetzt erst nach dem neuflashen ausprobiert habe...
Moin,
wollte mich mal erkundigen ob das Problem mit der Verschlüsselung der Nutzerdaten noch jemand anderem aufgefallen ist und ob mit dem am Wochenende erschienenen 1.1a Hoffnung auf Besserung besteht?
Ich behaupte einfach mal, dass es keiner benutzt und deshalb keiner was sagt. :rolleyes:
Kann ja nur durch einen Wipe entfernt werden. Das will wohl keiner.
Ja schade... habe gehofft, dass es einfach an mir liegt und es doch irgendwie zu fixen ist...
Habe inzwischen auch diesen etwas älteren Thread gefunden indem das Problem anhand eines Asus Transformers erörtert und durch ein Update seitens Asus gelöst wurde.
Naja, vielleicht kommt da ja nochmal was, ansonsten bin ich natürlich für jeden hilfreichen Vorschlag offen :winki:
Wie oben schon erwähnt vielleicht mal die neue Rom probieren.
auebanane
gromicx
sinus61
sinus61
LouCipher
LouCipher
LouCipher
