[ROM] DarkElf Custom ROM for Ainol NOVO7 Elf II
  • 6 Antworten
dicker99
dicker99
Stamm-User
180
Ein neues Custom Rom für das Elf2. Vergesst vor dem flashen das wipen nicht.
http://www.apad.tv/apadforum/showth...ROM-DarkElf-Custom-ROM-for-Ainol-NOVO7-Elf-II
DarkElf v0.2 Features:
Based on the 20120607 official Ainol Elf II firmware Google Apps added SetupWizard starts on first startup Rooted default language is English, default location is US build.prop edit:
Device model set to Samsung Galaxy Note for Gameloft games compatibility
WiFi scan interval = 180
Sleep policy enabled
GPS enabled (the Elf II does not have internal GPS, this update is for external GPS device support only)
HDMI supports 480p output
Camera's pictures are stored on SD first
adb enabled by default
CPU modes set to: power saving=600MHz, normal=1200MHz, performance=1500MHz (official firmware had this lowered to 1320MHz)
How to install:
1. Copy the DarkElf_v0.2.zip to your SDcard
2. Power off the Elf II and remove the charger
3. Press and hold the Power button and the Volume-button at the same time. When the green droid appears you can release the buttons.
4. In the recovery you can move with the Volume-button, you can select with Power or Volume+
5. Select apply update from sdcard
6. Select DarkElf_v0.2.zip
7. Wait for the update to finish
8. Select reboot system now
Version 0.5 ist draußen
V0.5 http://www.apad.tv/apadforum/showth...ROM-DarkElf-Custom-ROM-for-Ainol-NOVO7-Elf-II
Features:
•Based on the 20120607 official Ainol Elf II firmware
•Google Play (Market) added
•Google Play Store compatibility fix
•Other Google Apps added
•SetupWizard starts on first startup
•Face Unlock added
•Rooted
•default language is English, default location is US
•Themed bootanimation
•Deodexed
•Option to auto-hide/always hide status bar
•Preinstalled apps on /data partition (you are able to update or uninstall them): Youtube, ES file explorer
•build.prop mods:
Device model set to Samsung GT-I9100 for Gameloft games compatibility
HDMI supports 480p output (720x480 progressive)
Camera's pictures are stored on external SD first
Version 1.0 ist draußen, basiert auf der aktuellen stock rom 0626, ich werde es diese Tage mal testen und berichten.
Original Forum
[Elf II][ROM] DarkElf Custom ROM for Ainol NOVO7 Elf II
DarkElf v1.0 (Download1, Download2)
Changes:
  • Based on 0626 official firmware (less heat)
  • Google Play updated to 3.7.13
  • Gmail updated to 4.0.5
  • Flash Player from the 0626 official firmware
  • Lower max CPU speed (0626 kernel limitation)
Features:
  • Based on the 20120626 firmware
  • The rom does not wipe data. Wipe the data partition manually if you have Force Close issues or app errors.
  • Google Play (Market) installed
  • Google Play Store compatibility fix
  • Other Google Apps installed
  • SetupWizard starts on first startup
  • Face Unlock added
  • Rooted
  • You can select your language on the first screen of the SetupWizard, default location is US
  • Themed bootanimation
  • Deodexed
  • Option to auto-hide/always hide status bar, in other words full screen mode (The default is auto-hide, you can go to Settings->Display->Hide status bar to change it)
  • Physical Home button works as Back button, the long press of the Home button works as Home
  • The microSD is mounted as /sdcard/ and the internalSD is mounted as /sdcard/external_sdcard.
    In Settings->Storage the internalSD and externalSD are switched so what you can see at Internal SDcard is in fact the microSD card and what you see at External SDcard is really the internal flash memory of the Elf. For formatting the internalSD use Settings->format sdcard or recovery->wipe media partition, for formatting the microSD use a PC (card reader or connect the tablet via usb).
  • Apps can be installed on the SD without problems.
    For those who still want to use the internalSD as sdcard here is a revert patch: Download1, Download2
  • Additional languages (language list: Arabic, Bulgarian, Catalan, Czech, Danish, German, Greek, English, Spanish, Finnish, French, Croatian, Hungarian, Italian, Japanese, Korean, Lithuanian, Latvian, Lettish, Dutch, Polish, Portuguese, Romanian, Russian, Slovak, Slovenian, Serbian, Swedish, Thai, Tagalog, Turkish, Ukrainian, Vietnamese, Chinese).
  • Upgrade application for easier update installs
  • Preinstalled Flash Player
  • Ability to change the touch input in HDMI mode (Settings->HDMI): Dualdisplay(absolute - the touch is recognized where you actually touch on the display, good for games), Normal(relative - just like a notebook touchpad. The original firmwares and the previous DarkElfs had this as default.)
    Ainol Novo 7 Elf II HDMI out Monster Shooter - YouTube
    (note: the Elf II cannot display image on the panel and on HDMI at the same time. When in Dualdisplay mode there is no image on the Elf itself, so you have to guess where to place your finger.)
  • Trebuchet launcher
  • build.prop mods:
    Device model set to Samsung GT-I9100 for Gameloft games compatibility​
    WiFi scan interval = 180​
    Sleep policy enabled​
    GPS enabled (the Elf II does not have internal GPS, this update is for external GPS device support only. Use TetherGPS application to share your phone's GPS signal with your Elf II)​
    HDMI supports 480p output (720x480 progressive)​
    Camera's pictures are stored on SD first​
    adb enabled by default​
    CPU modes set to: power saving=600MHz, normal=1000MHz, performance=1320MHz​
Ich habe das DarkElf V1.0 gestern doch gleich mal ausprobiert und noch ausgiebig getestet. Unterschiede im Handling bzw. Performance zum Aggro0626-B kann ich jetzt nicht feststellen.
Ein Vorteil des DarkElf gegenüber StockRom bzw. Aggro:
Die Micro-SD Karte wird als interner Speicher eingerichtet, der interne Speicher ist dann als extern geführt. Vorteil durch diese Umstellung: da beim internen Speicher des 8GB ELF2 im StockRom nur noch ca. 5 GB für Apps und Daten übrig bleiben, kann man nicht viele Spiele installieren, die noch große Datenpakete haben. Bei Fifa12 sind das z.B. ca. 1GB. Hat man eine Micro-SD mit 16GB oder 32 GB, sieht das dann beim DarkElf schon anders aus. Dieser Wechsel kann aber per Tool im Recovery auch wieder rückgängig gemacht werden, falls das einer nicht möchte.
Nachteile des DarkElf gegenüber Aggro0626-B:
-Das Aggro hat unten in der Statusleiste eine Prozentanzeige der Restkapazität des Akku`s. Das DarkElf nicht. Das kann aber bei Bedarf per Tool aus dem PlayStore kostenlos ergänzt werden.
-Die Bootanimation wurde ausgetauscht, wem das nicht gefällt kann diese aber auch wieder ersetzen.
Sind also nur minimale Nachteile, habe sie aber dennoch dokumentiert, falls es jemand interessiert.
Somit für Hardcore Gamer auf jedenfall die bessere Alternative, wer Aggro schon drauf hat und den Speicher nicht braucht, kann dabei bleiben.
Die Rom gefällt mir soweit ganz gut. Hab nur ein paar kleinere Problemchen.
Die Wlan Reichweite scheint nicht sehr gut zu sein. Neben meinem Netbook hat das Elf ein schlechteres Wlan Signal. Nach dem Aufwachen dauert es auch manchmal etwas länger bis die Verbindung hergestellt werden kann.
Außerdem hab ich ein Akku Problem. Sobald die Akku- Warnung kommt (15%) ist das Ding innerhalb von maximal 5 Minuten leer. Bis dahin hält der Akku aber recht lang finde ich. Wie lang hält bei euch der Akku? Z.B beim Spielen oder Filme schauen, im Ruhezustand verbraucht das ja so gut wie keinen Akku.
Insgesamt bin ich sehr zufrieden mit dem Elf II, bis auf die Tatsache, dass ein paar Spiele leider nicht laufen wollen, aber für 140€ kann man damit leben ;)
Der schlechte WLAN Empfang soll angeblich an den Treibern liegen. Dieser soll bei einem update von Ainol aktualisiert werden. Mal sehen ob und wann das vonstatten geht.
Das mit dem Akku ist leider so. Am Anfang fällt die Anzeige langsam, zum Schluss relativ schnell. Am besten ab 20% eine Steckdose suchen.
steve8x8
blubenow
blubenow
blubenow
dajo77
