id.goPLAY
CyanogenMod 10 (JB 4.1.2) für Elf II, Aurora II, Crystal & Fire
Features
Installationsanweisungen
Vor dem Flashen der CM10 ROMs, "wipe media partition" mit Stock Recovery ausführen und dann die Anleitung befolgen:
Download
Compatibility zip (Updated 2012-11-10)
Changelog 2012-11-17
Changelog 2012-11-10
Changelog 2012-11-03
Changelog 2012-10-28
Known bugs
FAQs
Screenshot's
Features
- UbiFS (like stock roms)
- Bluetooth USB dongle Unterstützung
- USB GPS Unterstützung (cp210x and pl2303)
- Xbox 360 gamepad Unterstützung (xpad)
- PS3 USB gamepad Unterstützung (hid-sony)
- Generic/Chinese (Pantherlord/GreenAsia) gamepads Unterstützung (hid-pl and hid-gaff)
- OpenVPN Unterstützung (tun)
- Veno Regelalgorithmus
- Entpacke die CWM ZIP datei auf die externe SD card
- Kopiere CM10, GAPPS and A2-compatibility.zip auf deine externe SD card
- Gehe in CWM recovery modus (drücke Power und Volume -)
- Mache einen Wipe Data/Factory reset
- Gehe zu Install zip from SD card und instaliere erst die CM10 ROM datei
- Als zweites die GApps-JB-XXXXXXXX-signed-ubifs.zip
- Und am ende die Compatibility.zip datei
- Restart
Download
- ELF-II v1.4
- Aurora-II v2.5 (if you have troubles you can always use v1.3.1 as fallback)
- Crystal v1.5 (like Aurora's users, if you have troubles use v1.0 as fallback)
- Fire TM v1.2 - CWM v5.5.0.4
- Fire QM v1.3 - CWM v5.5.0.4
- Other minor stuff
- Updated upstream sources
- Added reboot to recovery (you must have flashed CWM to the NAND or it will boot to stock recovery)
- Aurora-II / Elf-II: new compatibility zip (fixes stuck g sensor for people that had problems)
- Other minor stuff
- Fixed Netflix 2.x compatibility
- Potential fix for the few games that were still having a choppy/stuttering audio
- Aurora-II / Elf-II: fixed unresponsive WiFi when the screen was turned off
- Other minor stuff
- Updated compatibility zips for Elf, Aurora and Crystal
- Re-inserted missing file that broke wifi
- Increased amplayer buffer; flash videos using latest apk work decently and in hw mode. Sometimes you may not hear audio but toggling fullscreen mode will fix it.
- Other minor stuff
Known bugs
- Post to report
FAQs
- I suggest you to change Trebuchet's rows/columns number to 4/5 to avoid launcher's FC.
- Install a different launcher like apex, nova etc from google play.
Screenshot's
) aber Android ist Neuland für mich. Daher brauche ich Eure Hilfe, wie in der Anleitung geschrieben muss ich erstmal Stock Recovery draufmachen, was ist das und wo bekomme ich es, Android markt? Habe alle anderen benötigen Dateien bereits auf dem PC gespeichert und war auch schon im Installationsmodus nur hat mir eben die Option Install from SD card gefehlt vermutlich weil ich das Stock recovery nicht drauf hab
