[HowTo] [Advanced] [Advanced II] [Aurora] ROOT & Full Market by Tasselhof
  • 9 Antworten
LouCipher
LouCipher
Ehrenmitglied
1.991
Der Original-Thread ist von MrTasselhof aus dem Slatedroid.com-Forum
Hello All,
In this post is a relatively basic .BAT script.
This is a straightforward script.
It's sole purpose is to get your device rooted and provide the tools to verify it.
- Cleaned Up some extra unneeded files and added the Android Market App Upgrade from ContemptX! - Thanks!
I have added some options to Disable and Enable services to hopefully help with battery life.
**IMPORTANT PRE-CHECK LIST**
Connect your tablet using the OTG port (normal procedure)
- YOU MUST USE THE INCLUDED USB CABLE
Make sure USB Debugging is ENABLED
- Settings --> Applications --> Development --> USB debugging (Green Checkmark)
Make sure to check Device Manager to ensure that there aren't any devices with a yellow exclamation mark.
- Right Click on My Computer --> Manage Device --> Device Manager
Instructions:
Extract the folder to ANY location you wish. (it is self contained)
Run !RUN-ME-Tasselhof-RootScript.bat
You will be given the following prompt:
Make sure to enable USB Debugging on the tablet
- Settings -) Applications -) Development -) USB debugging (green checkmark)
1. Check Tablet Connection
2. Verify Tablet is ROOT Capable (with this script)
3. Run ROOT Script
***** ADDITIONAL OPTIONS - (ROOT REQUIRED) *****
4. Upgrade Android Market App
5. Disable Services to Increase Battery Life
- Phone, 3G, Bluetooth, Provision, VPN
6. Re-Enable All Services
7. Enable Only 3G Services
8. Enable Only Bluetooth Service
9. Quit
Choose Option (1 thru 9):
Option 3 Performs the actual ROOT process.
- It also installs the following programs: (don't worry if they are already installed)
* Superuser
* Root Checker
* Root Explorer
* Busybox
Option 4 attempts to replace the Android Market App with an updated version.
Option 5 Disables various service APKs to try to save battery life.
Bluetooth.apk
Mms.apk
Provision.apk
TelephonyProvider.apk
VpnServices.apk
Network3gMonitor.apk
shortcut3g.apk
Phone.apk - (Requires Immediate Hard Power Off and Reboot)
Option 6 Re-Enables all of the above services
Option 7 Re-Enables all of the above services except Bluetooth.apk
Option 8 Re-Enables only Bluetooth.apk
Watch the magic happen
Enjoy!
Tasselhof
Downloads:
Tasselhof Root-Script
USB-Treiber
Falls der richtige Treiber noch nicht dabei war: PdaNet325
Reaktionen: id.goPLAY und Bundy
Hallo LouCipher!
Ich besitze das Advanced II, noch im rohen Zustand!
Sollte oder kann ich erst nach dieser Anleitung gehen:
[ROM] Novo 7 Advanced II - ICS 4.0.3 0.9 0303 + Modded Volume Keys
Und kann dann die Schritte dieser Anleitung durchführen?
Mein Ziel ist es die aktuellste Version auf dem Tab zu haben und Root um die ganzen chinesischen Apps runterzuwerfen.
Vielen Dank für deine Mühe!
Richtig.
Wie beschrieben.
Wenn du es schaffst die Rom von Ainol runterzuladen darfst du die gerne woanders hochladen.
Das laden von diesem Hoster (115) gestaltet sich immer sehr langwierig.
Reaktionen: Alphatier2012
Habe mittlerweile die offizielle 4.03 drauf und habe Option 4 und 5 durchgeführt. Irgendwie merke ich aber keinen Unterschied...
Wieso werden im Market nicht alle Apps angezeigt? Bzw. wieso kann ich vom Computer die Apps aus dem Market nicht an das Tab schicken, nur an mein Smartphone :-/
Weil der Ainol Fingerprint offiziel nicht von google market
Unterstütz wird. Deswegen findest du mit der Orginal Fw nicht
Alle apps.
Bei den customroms sind meistens Samsung sgsII fingerprints
Eingestellt. Damit werden mehr apps angezeigt.
Greetz alt
Gesendet von meinem Milestone mit Tapatalk 2
Ah ok Danke :)
Gibt nur für das Advanced kein custom rom so viel ich weiss ^^
Naja aber als apk runterladen und vom tab aus installieren sollte ja trotzdem gehen.
Dafür brauchst du im prinzip keine custom rom.
Mußt du mal googlen wenn du root auf deinem
Tab hast den kannst du den fingerprint ändern.
Da ich aber grade mit meinem handy on bin
Kann ich das schlecht raussuchen.
Greetz alt
Ah cool, werde mich mal umschauen. Wäre eine gute Möglichkeit :)
EDIT:
Gibt ein App namens "Allwinner MOD" werde ich mal testen
steve8x8
auebanane
dajo77
