[How to]Jelly Bean 4.1 fürs SKATE
  • 321 Antworten
udo7777
udo7777
Stamm-User
372
Hier mal eine kleine Anleitung fürs Flashen von Jelly Bean.
Im Grunde genommen wie das ICS 4
Rom, Gapps auf SD-Karte kopieren
Format/System
Install Rom
Wipe Partition - Cache
Booten
5 Minuten gar kochen lassen :biggrin:
dann Reboot und die JB Gapps installieren
wieder 5 Minuten warten ( weil noch zu heiß zum Dinieren :lol: )
ein bisschen Spaß muß auch sein :D
dann am neuen Betriebssystem, soweit wie es geht, Spaß haben :thumbsup:
Download-Link CFX2 Jelly Bean 19.11.2012
Goo.im Downloads - Downloading cm-10-20121119-EXPERIMENTAL-skate-ColdFusionX2-tilal6991.zip
Download-Link Jelly Bean gapps 19.11.2012
Goo.im Downloads - Downloading gapps-jb-19112012-cfx2-stripped.zip
Download-Link gapps-jb-KonstaKang: 17.10.2012
gapps-jb-20121017-KonstaKANG.zip
siehe Changelog
Functionality:
Working:
RIL
Bluetooth
WiFi
Mobile data
Audio
USB Mass Storage
Native Apps2SD
Bluetooth Tethering
OpenGL Acceleration
Google Now - see http://www.modaco.co...n-updated-2007/
Video/Audio playback - to ICS standards
Smooth UI
Camera-Panorama
Video Recording
Paritially working:
Project Butter - if following the official definition of VSYNC and triple buffering
USB Tethering - use EasyTether
WiFi Tethering - use WiFi Tether for Root Users
Changelog:
Quote
17/07:
Initial release
18/07:
Fixed audio routing partially
Fixed audio/video playback - to ICS standards
Fully fixed RIL - no phone crashes if you don't have a SIM pin
Add SuperUser
20/07:
Fixed audio routing fully
Fixed headphones
Fully fixed RIL - no phone crashes at all - even if you have a SIM pin
Fix SuperUser remembering permissions
Fix native Apps2SD
08/08:
TON of new stuff both upstream and device specific
Synced with CM sources
Theming, Navigation Bar settings, Hardware keys customisation etc. merged
Dual build - choice between Project Butter or Video Playback
Smoother and faster throughout - especially with PB build
Lot of other misc. things
16/08:
Fix camera - video recording still doesn't work
Fix video playback/smoother UI depending on which build you were using
Merge dual builds - one build has both video playback and smooth UI
Merge CM upstream stuff - lots of new stuff there
Enable high end graphics - loads of cool effects here and there
19/09:
A ton of updates
Synced with latest CM repos:
* Quick message
* Navigation Bar settings
* Performance settings improvements
Faster and smoother - no longer using old gralloc/hwcomposer
CRT off animation fixed
Loads of misc fixes
18/10:
Load of stuff changed upstream
Android 4.1.2
10/11:
Absolute ton of upstream fixes
Panorama fixed
Video recording fixed
Rock solid stability
Released with updated 4.2 GApps
19/11:
Lot of Absolute ton of upstream fixes
Video recording made usable - records between 20-25 fps now
Fixed YouTube HQ - thanks to Ganster especially for this
Got rid of most glitches - still present when playing and recording videos
Released with updated GApps
THIS GUIDE ONLY WORKS ON JELLYBEAN BASED ROMs - ie. right now - my CFX2.
This guide will show you how to get a fully functioning version of Google Now for JellyBean working. It's a hacky method but it works
So you've installed a JB based ROM. What now?
  • Download my special GAPPs !
  • Flash this in recovery
  • Reboot into JB
  • Set up your Google account etc.
  • Install the Voice Search apk from step 1
  • Click the "Google" app in the app drawer
  • Set up Google Now
  • Got to app drawer. And click the one saying Voice Search
  • Click on the mic and say something to verify it works.
  • Go to Settings, Location Services and Enable "Google's Location Service"
  • Go back into Google Now (Google app) and click the menu button and go into settings
  • Go to privacy and accounts and enable "Location and Google Search" and "Search on Google.com"
  • And use Google Now as you please!
Gruß Udo7777 :cool2:
Reaktionen: androidseb, wemdenn, helicopeter1234 und 3 andere
Jo habe auch schon davon gelesen!
Wird aber wahrscheinlich wieder lange dauern bis es da eine fertige ROM von gibt, oder?
"None of the changes I made to compile are to do with the device config lol.
As for progress - consider this the progress thread lol.
TS now works - working on the upside down display"
So schaut zur Zeit aus. Es wird noch eine Weile dauern.
Gesendet von meinem Skate mit der Android-Hilfe.de App
Jelly Bean Status Update
Repositories for all AOSP projects have been created on our github to alleviate any potential mismatches (branch is 'jellybean').
While Jelly Bean won't require a major rewrite of all the CM features, the source has been re-arranged and re-factored enough that a simple merge isn't possible. So we will proceed with manual merging (this was to be expected really).
The plan of attack...
read more https://plus.google....sts/BMQiaHhSMte
Wie man sieht, es wird net so einfach. Neu arrangieren, neu zusammenführen usw. Wir werden aber mit Sicherheit abwarten, oder? :thumbup:
Es klingt zumindest sehr Interessant was hier geschrieben wird. Also warten wir...also ich zumindest.....neugierig auf das CM10 :cool2:
Ich frage mich ob es bei JB denn möglich ist die Dinge zum laufen zu kriegen, die bei ICS nicht laufen! :rolleyes2:
Ich bin da sehr optimistisch...dass zumindet Kameralicht und MMS auch noch funktionieren werden denn das ist das einzige was mich bei CM9 gaaaanz wenig stört ;)
zumindest ist dieser Beitrag ein kleiner Lichtblick und das ist tilals aussage
Moin :cool2:
Ich wurde heut im Modaco-Forum auf eine Aussage von Tilal aufmerksam, aber da ich dem englischen nicht mehr so mächtig bin könnte man daraus entnehmen das Tilal da was fertig hat.
Wenn ja, könnte da wohl jetzt was passieren und eine Jelly Bean Version für unser Skate erscheinen.
Könnte jemand mit guten Englisch nochmal nachlesen? Danke :)
Gruß Udo7777
Hier die Aussage von Tilal:
Project Butter / OpenGL - complete. More info when I return from out of town
Er hat es also geschafft OpenGL zum laufen zu bringen. Mehr Infos folgen, wenn er von außerhalb der Stadt zurück ist.
Ich hoffe ich habs richtig wiedergegeben, falls nicht, korrigiert mich bitte ;)
mfg maxl
Es ist so weit !!! :thumbsup::thumbup:
Lalit hat eine >>>Pre-Alpha Version<<< veröffentlicht !!!
Es sagt aber ausdrücklich, dass es sich hier noch um eine Pre-Alpha handelt und dass so gut wie nichts funktioniert.
Leider kann man sie noch nicht downloaden, da goo.im im Moment wohl down ist und er es nicht auf einen andern Hoster uploaden will.
Unter anderem sagt er auch, dass es wahrscheinlich die letzte Android OS Version ist, mit der unser Handy noch akzeptabel läuft :sad:.
Ich werde es bei Gelegenheit mal flashen.
mfg maxl
Moin ;)
Ja da hat sich was getan. Frage mich jetzt nur wann der Download frei gegeben wird. Bin echt heiß drauf :thumbup:
Wie man nachlesen kann, scheint doch einiges zu laufen was das Handy daraufhin brauchbar macht. Sieht auf jeden Fall schon mal gut aus :love:
Gruß Udo7777
Moin :biggrin:
Tilal sagt das er noch heute ein Update hoch läd
tilal6991
Posted Today, 08:00 AM
Some exciting progress in the next build. Will be released today. :thumbsup:
Dann dürfte auch diese Fehlermeldung com.android.phone has stopped weg sein.
Gooiiiilllll :flapper:
Gruß Udo7777
Reaktionen: munre
Habe ich auch gerade gelesen
tilal6991, am 18. Juli 2012 - 08.00 Uhr, sagte:
Einige spannende Fortschritte in der nächsten Build. Wird heute veröffentlicht werden.
Na denne wird es sicher auch ohne den kritischen Fehler laufen....
Gruß munre
Hallo Zusammen,
ich habe das Android 4.1.1 seit gestern installiert. Leider kommt es vor der PIN Aufforderung zu folgender Fehlermeldung.
FEHLER //
" Leider wurde der Prozeß com.android.phone beendet"
Wenn man diese FM mit ok bestätigt kommt man auch zur PIN Eingabe und das Telefon lässt sich dann ganz gewohnt bedienen.
Hat jmd. das selbe Problem?
Ja das gleiche Problem hab ich auch, jedoch taucht diese FM bei mir auch nach der PIN-Eingabe auf. Lalit sagte auch dass es eigentlich nach der PIN-Eingabe nicht mehr auftauchen dürfte....
Hallo munre,
danke für deine Info :)
da hoffen wir mal das es mit dem kommenden UPDATE behoben ist.
:D
Der ursprüngliche Beitrag von 12:45 Uhr wurde um 12:49 Uhr ergänzt:
Einstellungen/Interface/Lockscreen // System>> kann nicht geöffnet werden.
Fehlermeldung:
"Einstellung wurde leider beendet"
ich würde gern mal ein log mit dem Fehler an Lalit senden, weiß jmd. wie ich das anstellen muss?
Hallo Zusammen,
ist es bei euch auch so wenn Ihr einen Anruf bekommt, bzw. wenn Ihr selber anruft, das der hintere Lautsprecher aktiv ist?
Kann man diesen abstellen oder ist es ein BUG? Es ist schon blöd wenn jeder im Raum zuhören kann :D
Grüße
  • rainer-sh
rainer-sh
Nasemann
  • Fensterrahmen
Auro
