Gerne wieder auf stock Firmware
  • 4 Antworten
Sakura501
Sakura501
Habe wegen dem fehlenden Sicherheitspatch mal von der XDA Seite Android 12 installiert
[ROM][12.0][raphael] Aosp 12.0
Kleine Anleitung: von der XDA Seite
iscopan said:
Hi! I want to change my actual rom (xiaomi.eu) because it has some bugs, so I was thinking to clean flash AOSP, but I don't want to do it wrong, so I was looking for some step by step tutorial. Any of you have/know one?
Also, I've had xiaomi.eu for so long, so I don't remember which firmware was at first, so if someone know how to know what should I flash before installing AOSP it would be very helpful <3 (probably it was global, but I'm not sure)
Make sure you're rooted, download migrate from the play store. Backup all your apps and sms messages.
Update your twrp to the latest, or use orangefox recovery. Our device is known as Raphael btw.
Reboot back into recovery. Power + vol up (I think)
Wipe all partitions EXCEPT internal storage. You'll keep all your files that way.
Flash the miui vendor as attached in the first post.
Flash the gapps version of the rom.
Flash disable dm verify to avoid encrypting your files. (To avoid accidentally losing access to all your files)
Reboot to system.
Complete the setup and then reboot back into TWRP.
Flash magisk, flash the zip created earlier in the migrate folder.
Reboot back into system.
[Edit]
It really has gotten a bit more complicated over the years. But this will work for you. To fix your miui eu rom, I'd follow the same steps, except don't flash the vendor.
Habe aber leider einige fehler gemacht.
- Das Dateisystem ist über Pc nicht erreichbar, trotz debugging. Per Dateimanager app sehe ich jedoch die Vollständige Verzeichnisstruktur. Kann auch per Usb Stick in die Verzeichnisse Dateien kopieren. Hat wohl mit encryption was zu tun.
- google pay funktioniert NICHT.
- Huawei App Galary stürtzt ständig ab. (brauche ich für meine Huawei GT2)
Ansonsten ist das Betriebssystem wieselflink. Nun möchte ich wegen der Angesprochenen Punkte doch wieder auf Stock.
Habe von CUXHAVEN die Anleitung versucht: Anleitung] Original ROM im FASTBOOT Modus flashen Nach einem Refresh erscheint mein Gerät sporadisch.
Wenn ich auf Flash klicke kommt ein fehler irgendwas mit boot nicht gefunden.
Mit dieser Aussage kann man nicht viel anfangen. Welche Fehlermeldung kommt denn genau?
Hat sich erledigt. Habe jetzt eine andere custom Rom (Pixelexperience) und damit überhaupt keine Probleme mehr.
funktionieren da alle Kameras? Habe mal kurz LinageOS probiert, da hab ich aber nur eine Kamera zum Laufen gebracht.
Kameras haben alle funktioniert. Habe das mi9Tpro allerdings nicht mehr. Bin jetzt Pixel besitzer
hotrats
hotrats
hotrats
hotrats
  • hotrats
beicuxhaven
beicuxhaven
Sakura501
HerrDoctorPhone
HerrDoctorPhone
