Android-freak 12
Was ist das?Shadow_Fighter schrieb:Alpha 4 (20120418): Goo.im Downloads - Browsing u8160
Latest Changelog:
- 20120528 [v0.5]
- md5: 3bacb6a08c447b2389d16b65dc18f8fe
- updated CyanogenMod source
- big update based on tilal6991's latest changes - codename "FrozenFissionY"
- kernel: using my latest codeaurora-kernel_huawei_u8160 kernel source with configuration changes to better suit ICS
- kernel: backported xt_quota2, xt_qtaguid, iface_stat drivers to allow proper networking stats and prevent recurring framework crashes
- libaudio: adapt Adriano Carrata's rewritten libaudio to ICS with new AudioFilter and audio attenuation enabled
- framework: fixed cpu deep sleep issue that was caused by wakelock in highspeed serial device (Bluetooth quick switch) - should drastically improve battery life (may now be similar to CM7)
- framework: optimizations to 2D rendering speed
- framework: disable UI touch sounds (was slowing down presses + increasing battery drain)
- include old Music app alongside new Apollo music player (as the latter may have problems detecting media for some people)
- add VoiceDialer, SoundRecorder, and FileManager from CM7 (as there is no CM9 version yet).
- Trebuchet: change drawer animation back to default (looks nicer, no change in performance)
- fix simple2ext compatibility issue. Note: you will need to enable the "mount as ext4" option in the app settings, as CM9 does not auto-mount /sd-ext on boot.
- increase VM heap to 32MB - should reduce ANR errors.
- camera partially working (preview works, taking picture not supported by default app)
