[ROM][AOSP][vorerst pausiert] Sony Open Devices Builds
  • 20 Antworten
Moin,
ich versuche gerade folgendes Setup zu installieren:
  • aosp-9.0-kugo-V9-20190905-dev-keys.zip
  • SW_BINARIES_FOR_XPERIA_ANDROID_9.0_2.3.2_V9_LOIRE.ZIP
  • twrp-3.3.1-0-kugo.img
  • open_gapps-arm64-9.0-pico-20191009.zip
Dabei tritt bei der OpenGApps Installation folgender Fehler auf:
Code:
Press ENTER once TWRP has been loaded completely.
Mounted '/system'
Done processing script file
Remounting /system as rw ...
linker: /system/etc/ld.config.txt:21: warning: property "namespace.default.search.paths +" redefinition
WARNING: linker: /system/etc/ld.config.txt:21: warning: property "namespace.default.search.paths +" redefinition
linker: /system/etc/ld.config.txt:25: warning: property "namespace.default.asan.search.paths +" redefinition
WARNING: linker: /system/etc/ld.config.txt:25: warning: property "namespace.default.asan.search.paths +" redefinition
linker: /system/etc/ld.config.txt:26: warning: property "namespace.default.asan.search.paths +" redefinition
WARNING: linker: /system/etc/ld.config.txt:26: warning: property "namespace.default.asan.search.paths +" redefinition
linker: /system/etc/ld.config.txt:27: warning: property "namespace.default.asan.search.paths +" redefinition
WARNING: linker: /system/etc/ld.config.txt:27: warning: property "namespace.default.asan.search.paths +" redefinition
linker: /system/etc/ld.config.txt:28: warning: property "namespace.default.asan.search.paths +" redefinition
WARNING: linker: /system/etc/ld.config.txt:28: warning: property "namespace.default.asan.search.paths +" redefinition
Installing Open GApps ...
serving: 'open_gapps-arm64-9.0-pico-20191009.zip'  (~57%)    adb: failed to read command: Success
Press ENTER once sideload has been disabled completely.
rm: can't remove '/persist/gapps-config.txt': No such file or directory
rm: can't remove '/persist/open_gapps_*': No such file or directory
Finished installing Open GApps! Rebooting ...
Als Resultat verharrt das System im bootloop. Wenn ich das System ohne GApps installiere, bootet es. Was tun?
Pascalsg
PurpleZ
chgiceman
chgiceman
Andi_K
