[DEVELOPMENT] - CM10 - FreeXperia Project
  • 198 Antworten
Q
quasimodo
Gast
FreeXperia Project
Port by DeveloperFXP / xda
Project Homepage
FreeXperia Project
Bin4ry, Defer, Kali, Jerpelea
Dies ist ein Inoffizieller Port!
Orignaltext Entwickler:
CyanogenMod is a free, community built distribution of Android 4.1 (Jelly Bean) which greatly extends the capabilities of your phone.
Diese Software benötigt einen UNLOCKED BOOTLODER
Unlocking the boot loader | Sony Xperia
How to - Installationsanweisungen:
Erstmals
- power off the phone:
- hold vol+ and plug usb to boot into fastboot (blu led)
- fastboot flash boot boot.img (from cm10 zip)
- fastboot reboot
- enter recovery, on boot led will be violet for 3'', during this period press vol+
- flash rom zip
- flash gapps zip
- wipe
- reboot
for update just flash rom zip from recovery
Google Apps are not included in this ROM. You'll need to find those yourself if you want them.
GENIESSEN Sie das inoffizielle CM10 RELEASE
Mit freundlicher Unterstützung vom FreeXperia Team
CM10
FXP150 CM10
Bitte keine Mirrors von unseren Rom machen. Danke!
DOWNLOAD (Latest releases)
Cyanogen Mod 10.1
Cyanogen Mod 10
Cyanogen Mod 9
Cyanogen Mod 7
BUGTRACKER
if you are unable to download use
unrestrict.li
rapid8.com
LIVEVIEWLiveView | Phone Remote - Sony Smartphones (UK)
LIVEWATCH
http://www.sonyericsson.com/cws/prod...ch?cc=gb&lc=en
PROJECT WEBPAGE
http://freexperiaproject.com
Code
#include <std_disclaimer.h> /* * Your warranty is now void. * * I am not responsible for bricked devices, dead SD cards, * thermonuclear war, or you getting fired because the alarm app failed. Please * do some research if you have any concerns about features included in this ROM * before flashing it! YOU are choosing to make these modifications, and if * you point the finger at me for messing up your device, I will laugh at you. */
Hi, FXP148 und FXP149 sind nun raus. Bekommt eigentlich Cm 10.1?
Freut euch, dass es bei euch gleich mit CM10 los geht! Beim Xperia P wird erst mal CM9 entwickelt bevor es mit Jelly Bean los geht... :(
Gesendet von meinem Xperia P
Reaktionen: solaris63
Hat das eigentlich mittlerweile jemand ausprobieren können?
Wollte es mit meinem Win8 Laptop ausprobieren. Bei mir wir beim öffnen der Datenträgerimagedatei angezeigt. ,,Die Datenträgerimagedatei ist beschädigt" Hilfe!:cursing:
Bin grad am downloaden von FXP151 fürs tipo!
quasimodo schrieb:
Erfahrungs Bericht: [Klick]
In dem Erfahrungsbericht steht "led not working", aber auf der FreeXperia-Seite (Tamsui) steht "Led notification" unter der Kategorie "working". :confused:
Ich habe auch noch nicht ganz gecheckt für welche Geräte es CM 10.1 geben wird. Man kann ja schon FXP 150 laden, aber bei den unterstützten Geräten steht jeweils höchstens CM 10.
FXP151 geht leider auch ned:ohmy:
Um welche CM Version geht hier eigentlich.
Nach Threadtitel CM10.1, nach Inhalt ersten Post Cm10.
Mod bitte anpassen
Habe beides in Post 1 gelistet, habe aber den Titel wieder geändert!
Mache wenn CM10.1 läuft, dazu einen separaten Beitrag auf. :winki:
Ist auch besser da CM10.1 andere Gapps hat
Gesendet von meinem Xperia Arc S mit Tapatalk 2
FXP 152 ist raus. Hat mittlerweile jemand positive Erfahrungen auf dem Tipo gemacht?
Nein, das gleiche wie mit FXP151:confused2::bored:
Ihr habt die mesona geladen oder?
Der ursprüngliche Beitrag von 11:27 Uhr wurde um 11:28 Uhr ergänzt:
Edit: hab hier das falsche Gerät angegeben tapioca ist die richtige ROM fürs Tipo
Ist mesona nicht für das Miro?
Bei XDA sind Tipo Miro und J im CM10 Thema zusammengefasst, dachte die sind dann auch von der Software gleich
Ich lade die ROM gerade runter dann kann ich ja nachschauen für welche Geräte die mesona ROM genau ist
Bei freexperia steht halt beim Tipo was von tapioca_ss (bzw. nur tapioca):
Qualcomm
MSM7x25/27A - Tapioca
ST23i - Miro - mesona - CM10 work in progress
LT21ss/ds - Tipo - tapioca_ss - CM10 work in progress
ST26(i/a) - J - jlo - CM10 work in progress
