FAILED (remote: Command not allowed) Unlock the boot loader schlägt fehl
  • 9 Antworten
GT725
Stamm-User
82
Hallo habe es über CMD versucht wo ich folgende Meldung bekomme:
finished. total time: 0.024s
über Flashtool bekomme ich folgende Fehlermeldung:
07/037/2016 22:37:05 - INFO - Device connected in fastboot mode
07/037/2016 22:37:14 - INFO - List of connected devices (Device Id) :
07/037/2016 22:37:14 - INFO - - USB\VID_0FCE&PID_0DDE\ABC123456789 Driver installed : true
07/037/2016 22:37:14 - INFO - List of ADB devices :
07/037/2016 22:37:14 - INFO - - none
07/037/2016 22:37:14 - INFO - List of fastboot devices :
07/037/2016 22:37:15 - INFO - - ABC123456789
07/037/2016 22:37:32 - INFO - Please connect your device into flashmode.
07/037/2016 22:37:36 - INFO - Bootloader unlock canceled
07/046/2016 22:46:09 - INFO - Please connect your device into flashmode.
07/046/2016 22:46:14 - INFO - Device disconnected
07/046/2016 22:46:21 - INFO - Device connected in flash mode
07/046/2016 22:46:22 - INFO - Opening device for R/W
07/046/2016 22:46:22 - INFO - Reading device information
07/046/2016 22:46:22 - INFO - Phone ready for flashmode operations.
07/046/2016 22:46:22 - INFO - Opening TA partition 2
07/046/2016 22:46:23 - INFO - Current device : SGP712 - ABC123456789 - 1295-4711_R6A - 1292-0997_28.0.A.8.260 - GENERIC_28.0.A.8.260
07/046/2016 22:46:23 - INFO - Closing TA partition
07/046/2016 22:46:23 - INFO - Processing loader.sin
07/046/2016 22:46:23 - INFO - Checking header
07/046/2016 22:46:23 - INFO - Flashing data
07/046/2016 22:46:23 - INFO - Loader : S1_Root_f936 - Version : MSM8994_41 / Boot version : S1_Boot_MSM8094_LA1.2_110 / Bootloader status : NOT_ROOTABLE
07/046/2016 22:46:23 - INFO - Max packet size set to 4096K
07/046/2016 22:46:23 - INFO - Opening TA partition 2
07/046/2016 22:46:24 - INFO - Start Reading unit 000008B2
07/046/2016 22:46:24 - INFO - Reading TA finished.
07/046/2016 22:46:24 - INFO - Closing TA partition
07/046/2016 22:46:24 - INFO - Ending flash session
07/046/2016 22:46:24 - INFO - Your phone bootloader cannot be officially unlocked
07/046/2016 22:46:24 - INFO - You can now unplug and restart your phone
Ich habe im Ordner Flashtool\mydevices schon ein Ordner mit der Seriennummer erstellt und eine Textdatei darin mit dem Unlockocde doch auch das bringt nichts.
Weiß jemand rat?
Möchte es mit root versehen, habe 2 Profile da das eine aber nur Apk aus unbekannter Quelle installieren kann und nutzen kann, brauche ich root um es auch den anderen Benutzer zu ermöglichen durch Freigabe der Anwendungen
Habe mir Grade den verlinkten Beitrag durchgelesen, leider hilft mir das nicht wirklich da flashtool zb sagt wäre nicht möglich wird nicht unterstützt. Hat sonst noch jemand Ideen bzw braucht ihr noch Infos?
die Fehlermeldung klingt so, als ob Du in den Entwickleroptionen vergessen hast, die OEM-Entsperrung zuzulassen.
Viele Grüße
Handymeister
Reaktionen: Faustus77
Diesen Punkt gibt es leider beim Z4 Tablet SGP712 nicht
Reaktionen: Handymeister
Ok, kann es evtl. an der Sicherheitsfunktion "myXperia" liegen, bzw. hast Du die im Menü "Sicherheit" aktiviert?
Reaktionen: residentcj und GT72501
Die war Standard gemäß aktiviert habe ich Grade gesehen, deaktiviere es Grade und teste es gleich nochmal
Danke das war es
@Handymeister
extra registriert um mich für den Tipp bedanken zu können. :)
Der hat mein Problem gelöst!!
Mr. Droid
Mr. Droid
Mr. Droid
Mister Papillon
Mister Papillon
Mister Papillon
spreewaelder
