Root für 23.1.A.1.28
  • 1 Antworten
DaKill3r185
Hallo Gemeinde,
heute ist mein gebraucht erworbenes Xperia Z2 Tab (SGP521 16GB LTE) angekommen. Auf dem Gerät läuft das 23.1.A.1.28_R6C ROM von Vodafone.
Die Methode Easy Root und TowelRoot Methode 4 funktionieren leider nicht.
Bei Easy Root kommt:
Code:
=  Easy Root Tool v12  =
=  Supports various Xperia devices  =
=  created by zxz0O0  =
=  http://forum.xda-developers.com/  =
=  showthread.php?p=53448680  =
=  Many thanks to:  =
=  - [NUT]  =
=  - geohot  =
=  - MohammadAG  =
=  - cubeundcube  =
=  - nhnt11  =
=  - xsacha  =
* daemon not running. starting it now on port 5037 *
* daemon started successfully *
Waiting for Device, connect USB cable now...
Make sure that you authorize the connection
if you get any message on the phone
Device found
Getting device variables
Device model is SGP521
Firmware is 23.1.A.1.28
Sending files
239 KB/s (1593 bytes in 0.006s)
3587 KB/s (657704 bytes in 0.179s)
219 KB/s (1575 bytes in 0.007s)
1236 KB/s (9496 bytes in 0.007s)
1907 KB/s (13672 bytes in 0.007s)
Copying kernel module...
2040 KB/s (34473 bytes in 0.016s)
133 KB/s (823 bytes in 0.006s)
1658 KB/s (13592 bytes in 0.008s)
Kernel version is 3.4.0-perf-g4d6e88e
Version does not match 3.4.0-perf-ge4322cd, needs patching...
dd: conv option disabled
Kernel module patched.
error: only position independent executables (PIE) are supported.
Loading towelzxperia
2413 KB/s (13592 bytes in 0.005s)
4056 KB/s (197320 bytes in 0.047s)
Waiting for towelzxperia to exploit...
done
Checking if device is rooted...
Error: device not rooted
Drücken Sie eine beliebige Taste . . .
Bei NUT kommt
Code:
=  PhilZ Touch, CWM and TWRP Dual Recovery  =
=  Maintained by [NUT]  =
=  For Many Sony Xperia Devices!  =
1. Installation on ROM rooted with SuperSU
2. Installation on ROM rooted with SuperUser
3. Installation on unrooted ROM using the TowelRoot method
4. Install ADB drivers to windows
5. Exit
Please choose install action.
[1,2,3,4,5]?3
Device found!
Getting ro.build.product
Step2 : Sending the recovery files.
1 KB/s (31 bytes in 0.017s)
1989 KB/s (18340 bytes in 0.009s)
108 KB/s (501 bytes in 0.004s)
1323 KB/s (12198 bytes in 0.009s)
2385 KB/s (65965 bytes in 0.027s)
1203 KB/s (3082 bytes in 0.002s)
2193 KB/s (29204 bytes in 0.013s)
662 KB/s (1357 bytes in 0.002s)
4488 KB/s (34473 bytes in 0.007s)
469 KB/s (1202 bytes in 0.002s)
3442 KB/s (96956 bytes in 0.027s)
3886 KB/s (1410852 bytes in 0.354s)
3437 KB/s (3560530 bytes in 1.011s)
3869 KB/s (2423212 bytes in 0.611s)
4299 KB/s (1935417 bytes in 0.439s)
1043 KB/s (11760 bytes in 0.011s)
Step3 : Setup of dual recovery.
Attempting to get root access for installation using TowelRoot now.
NOTE: this only works on certain ROM/Kernel versions!
If it fails, please check the development thread (Post #2) on XDA for more detai
ls.
REMEMBER THIS:
XZDualRecovery does NOT install any superuser app!!
You can use one of the recoveries to root your device.
Sending files
247 KB/s (1776 bytes in 0.007s)
1264 KB/s (13592 bytes in 0.010s)
2897 KB/s (197320 bytes in 0.066s)
1090 KB/s (9496 bytes in 0.008s)
1483 KB/s (13672 bytes in 0.009s)
1869 KB/s (34473 bytes in 0.018s)
114 KB/s (765 bytes in 0.006s)
2427 KB/s (96956 bytes in 0.039s)
modulecrcpatch (by zxz0O0)
module_layout: patched to 0x8D25670A
__aeabi_unwind_cpp_pr1: match
kallsyms_lookup_name: not found
printk: not found
mem_text_write_kernel_word: not found
__aeabi_unwind_cpp_pr0: match
Installing using zxz0O0's towelzxperia
(using geohot's towelroot library)
Installation finished. Enjoy the recoveries!
Die TA-Partition ist (mangels root) noch nicht gesichert.
Frage A: Welche möglichkeiten gibt es noch das System zu rooten (ohne die TA zu beschädigen)?
Frage B: Kann ich die "SGP521_Customized DE_1282-2019_23.1.A.1.28_R3C" mit dem FlashTool flashen, ohne die TA zu beschädigen? So wie ich das verstehe bei Wipe --> Exclude den Hacken bei TA setzen oder?
Bin für jede Hilfe dankbar.
Edit 1:
Mit Kingroot 4.5.0 gelang es mir das Gerät zu rooten. Der erste durchlauf meldete einen fehler und dauerte ewig. Direkt noch mal auf root geklick und siehe da: läuft.
Die Sicherung der TA-Partition erfolgte mit Backup-TA-9.11. Raus gekommen ist eine TA-backup-20150723.164209.zip mit TA.blk, TA.img, TA.md5, TA.serial, TA.timestamp, TA.version. Ist das vollständig?
Anschließend habe ich die Install.bat vom Nuts Dual Recovery 2.8.21 drüber laufen lassen (Option 1 - rooted with SuperSU). Das Gerät ist nun im TWRP 2.8.7.0. und ich fertige gerade meine erste Sicherung des original ROMs an.
Edit 2:
Habe gestern abend noch die Customized DE_1282-2019_23.1.A.1.28_R3C per FlashTool aufs Tab gebracht, Anschließend wieder mit Kingroot gerooted und die Nuts Dual Recovery 2.8.21 (TWRP) installiert.
Anschließend mit dem PRFCreator eine ROM mit Nuts under SuperSU erstellt und per TWRP geflasht.
Fertig!
Reaktionen: name3rF, Bluesforyou und cantax
Anzeige
  • Gerade eben
  • Neu
Da diesem Thread kein Mehrwert zu entnehmen ist, alles sowieso im Forum zu finden ist und der User sich selbst helfen konnte, ist hier zu.
