wildwasserbahn
habe es gerade propiert, hat super funktioniert, habe nun root und die aktuelle 4.4 auf meinem Tab.
Gefunden hier:
[ROOT] 4.4.2 Tablet Z SGP321 10.5.A.0.230 - xda-developers
1. if you're in non-rooted 4.3, rooted 4.2, etc., flash SGP321 4.1.2 FTF using FlashTool and root
4.1.2 Firmware
FlashTool Guide + download
Root 4.1.2 + Guide
2. Select Debugging on from the Settings Menu
3. Select Unknown Sources under Security Menu in Settings
4. Download 4.4 .zip and stripped.ftf:
ZIP File
FTF File
MIRROR:
FTF File
ZIP File
Thanks pisti7204
5. Put 'SGP321_4.4.flashable.zip' on (the external) SDcard1;
6. Put 'SGP321_4.4.ftf' inside the Flashtool/firmwares folder;
7. Download XZDualRecovery (latest Version is TabZ-lockeddualrecovery2.7.123.beta.installer.zip), and unzip
-=- [NUT]'s XDA download page -=-
8. connect your tablet and install the XZ Dualrecovery folder Install.bat file
9. Select the Option as SuperUser (2), it will copy all the stuffs and reboot and start in Philz Recovery.
10. Flash 'SGP321_4.4.flashable.zip' in Philz,
11.. do not reboot but go back to the main menu, then go to Power->Power off
12. Flash everything in 'SGP321_4.4.stripped.ftff';
13. Reboot to system without clearing (dalvik-/)cache.
14. connect your tablet and once again install the newest XZDual recovery, Tablet will reboot into Recovery, now just click 'system reboot'
Die Anleitung von fooox1 (herzlichen Dank) funktioniert gleich für die 4.4:
https://www.android-hilfe.de/forum/...t-root-nur-fuer-sgp321-lte-sgp311.518741.html
Der Tab funktioniert bis jetzt perfekt
Gefunden hier:
4.1.2 Firmware
Root 4.1.2 + Guide
ZIP File
FTF File
MIRROR:
FTF File
ZIP File
Thanks pisti7204
