(Gelöst) Problem bei Installation eines ROM auf Samsung Galaxy Tab 3 8.0 (SM-T310) mittels TWRP
  • 2 Antworten
Y
yamyamR
ich bin neu hier, weil ich mich von meinen o.g. Schätzchen nicht trennen mag 😉.
Gerät: Samsung Galaxy Tab 3 8.0 (SM-T310)
Kernel: 3.0.31-2387075
Buildnr: KOT49H.T310XXSBQB2
TWRP Version: 2.6.0.0
Download ROM: lineage-14.1-20220709-UNOFFICIAL-lt01wifi.zip
Von: retiredtab - Browse /SM-T310/14.1 at SourceForge.net
(Selbes u.a. Problem auch mit verschiedenen anderen ROM von : Downloads for : Samsung Galaxy Tab III 8.0 | AndroidFileHost.com | Download GApps, Roms, Kernels, Themes, Firmware and more. Free file hosting for all Android developers. )
Rooting und Installation von TWRP wie bei: Root the Samsung Galaxy Tab 3 8.0 and Install Custom Recovery
Mein Problem:
Die Installation eines ROM gelingt nicht - Log-Datei nachstehend (s. ab Zeile 300):
Code:
Starting TWRP 2.6.0.0 on Mon Feb 27 12:56:15 2023
BOARD_HAS_NO_REAL_SDCARD := true
I:Internal path defined: '/data/media'
I:External path defined: '/external_sdcard'
I:Mount: Unable to find partition for path '/data'
SP1_NAME := efs
RECOVERY_SDCARD_ON_DATA := true
I:Lun file '/sys/devices/platform/usb_mass_storage/lun0/file' does not exist, USB storage mode disabled
Starting the UI...Pixel format: 800x1280 @ 32bpp
Pixel format: BGR_565
framebuffer: fd 4 (800 x 1280)
=> Linking mtab
=> Processing recovery.fstab
I:Processing '/efs'
I:Created '/efs' folder.
I:Processing '/boot'
I:Processing '/recovery'
I:Processing '/cache'
I:Processing '/system'
I:Processing '/data'
I:Backup folder set to '/data/media/0/TWRP/BACKUPS/3204d376731b61df'
I:Settings storage is '/data/media/0'
I:Processing '/preload'
I:Created '/preload' folder.
I:Processing '/sdcard'
E:Unknown File System: 'datamedia'
I:Processing '/external_sdcard'
I:Created '/external_sdcard' folder.
Updating partition details...
I:Data backup size is 0MB, size: 12027MB, used: 5193MB, free: 6698MB, in data/media: 5193MB.
I:Unmounting main partitions...
Partition Logs:
/efs | /dev/block/mmcblk0p3 | Size: 19MB Used: 4MB Free: 15MB Backup Size: 4MB
   Flags: Can_Be_Mounted Can_Be_Wiped Can_Be_Backed_Up IsPresent
   Primary_Block_Device: /dev/block/mmcblk0p3
   Display_Name: EFS
   Storage_Name: EFS
   Backup_Path: /efs
   Backup_Name: efs
   Backup_Display_Name: EFS
   Storage_Path: /efs
   Current_File_System: ext4
   Fstab_File_System: ext4
   Backup_Method: files
/boot | /dev/block/mmcblk0p9 | Size: 8MB
   Flags: Can_Be_Backed_Up IsPresent
   Primary_Block_Device: /dev/block/mmcblk0p9
   Display_Name: Boot
   Storage_Name: Boot
   Backup_Path: /boot
   Backup_Name: boot
   Backup_Display_Name: Boot
   Storage_Path: /boot
   Current_File_System: emmc
   Fstab_File_System: emmc
   Backup_Method: dd
/recovery | /dev/block/mmcblk0p10 | Size: 8MB
   Primary_Block_Device: /dev/block/mmcblk0p10
   Display_Name: Recovery
   Storage_Name: Recovery
   Backup_Path: /recovery
   Backup_Name: recovery
   Backup_Display_Name: Recovery
   Storage_Path: /recovery
   Backup_Method: dd
/cache | /dev/block/mmcblk0p19 | Size: 401MB Used: 6MB Free: 394MB Backup Size: 6MB
   Flags: Can_Be_Mounted Can_Be_Wiped Can_Be_Backed_Up Wipe_During_Factory_Reset Wipe_Available_in_GUI IsPresent
   Primary_Block_Device: /dev/block/mmcblk0p19
   Display_Name: Cache
   Storage_Name: Cache
   Backup_Path: /cache
   Backup_Name: cache
   Backup_Display_Name: Cache
   Storage_Path: /cache
/system | /dev/block/mmcblk0p20 | Size: 2098MB Used: 36MB Free: 2061MB Backup Size: 36MB
   Flags: Can_Be_Mounted Can_Be_Wiped Can_Be_Backed_Up Wipe_Available_in_GUI IsPresent
   Primary_Block_Device: /dev/block/mmcblk0p20
   Display_Name: System
   Storage_Name: System
   Backup_Path: /system
   Backup_Name: system
   Backup_Display_Name: System
   Storage_Path: /system
/data | /dev/block/mmcblk0p21 | Size: 12027MB Used: 5193MB Free: 6698MB Backup Size: 0MB
   Flags: Can_Be_Mounted Can_Be_Wiped Can_Be_Backed_Up Wipe_During_Factory_Reset Wipe_Available_in_GUI IsPresent Has_Data_Media Can_Encrypt_Backup Use_Userdata_Encryption Is_Storage Is_Settings_Storage
   Symlink_Path: /data/media/0
   Symlink_Mount_Point: /sdcard
   Primary_Block_Device: /dev/block/mmcblk0p21
   Length: -16384
   Display_Name: Data
   Storage_Name: Data
   Backup_Path: /data
   Backup_Name: data
   Backup_Display_Name: Data
   Storage_Path: /data/media/0
/preload | /dev/block/mmcblk0p16 | Size: 122MB Used: 63MB Free: 58MB Backup Size: 63MB
   Flags: Can_Be_Mounted Can_Be_Wiped IsPresent
   Primary_Block_Device: /dev/block/mmcblk0p16
   Display_Name: preload
   Storage_Name: preload
   Backup_Path: /preload
   Backup_Name: preload
   Backup_Display_Name: preload
   Storage_Path: /preload
/external_sdcard | /dev/block/mmcblk1p1 | Size: 30883MB Used: 8395MB Free: 22487MB Backup Size: 8395MB
   Flags: Can_Be_Mounted Can_Be_Wiped Wipe_Available_in_GUI Removable IsPresent Is_Storage
   Primary_Block_Device: /dev/block/mmcblk1p1
   Alternate_Block_Device: /dev/block/mmcblk1
   Display_Name: External SDCard
   Storage_Name: External SDCard
   Backup_Path: /external_sdcard
   Backup_Name: external_sdcard
   Backup_Display_Name: External SDCard
   Storage_Path: /external_sdcard
   Current_File_System: vfat
   Fstab_File_System: exfat
I:Loading package: TWRP (/script/ui.xml)
I:Loading package: TWRP (/data/media/0/TWRP/theme/ui.zip)
I:Loading package: TWRP (/res/ui.xml)
I:Loading resources...
I:Loading variables...
I:Loading pages...
I:Loading page main
I:Loading page main2
I:Loading page install
I:Loading page flash_confirm
I:Loading page flash_zip
I:Loading page flash_done
I:Loading page clear_vars
I:Loading page confirm_action
I:Loading page action_page
I:Loading page singleaction_page
I:Loading page action_complete
I:Loading page filecheck
I:Loading page rebootcheck
I:Loading page wipe
I:Loading page advancedwipe
I:Loading page formatdata
I:Loading page formatdata_confirm
I:Loading page backup
I:Loading page backupname1
I:Loading page backupname2
I:Loading page backupencryption
I:Loading page backupencryption2
I:Loading page checkbackuppassword
I:Loading page backup_run
I:Loading page restore
I:Unable to open '/data/media/0/TWRP/BACKUPS/3204d376731b61df'
I:Loading page restore_read
I:Loading page restore_decrypt
I:Loading page try_restore_decrypt
I:Loading page restore_select
I:Loading page renamebackup
I:Loading page restore_run
I:Loading page selectstorage
I:Loading page mount
I:Loading page usb_mount
I:Loading page usb_umount
I:Loading page settings
I:Loading page timezone
I:Loading page screen
I:Loading page partsdcard
I:Loading page htcdumlock
I:Loading page lock
I:Loading page filemanagerlist
I:Loading page filemanageroptions
I:Loading page choosedestinationfolder
I:Loading page filemanagerrenamefile
I:Loading page filemanagerrenamefolder
I:Loading page filemanagerchmod
I:Loading page filemanagerconfirm
I:Loading page filemanageracction
I:Loading page decrypt
I:Loading page trydecrypt
I:Loading page terminalfolder
I:Loading page terminalcommand
I:Loading page sideload
I:Loading page installsu
I:Loading page fixsu
I:Set page: 'clear_vars'
I:Set page: 'main2'
I:Switching packages (TWRP)
E:Cannot load volume /misc!
Startup Commands: ro.boot.debug_level=0x4f4c
ro.boot.emmc_checksum=3
ro.boot.odin_download=1
ro.boot.bootloader=T310XXSBQB2
ro.boot.selinux=enforcing
ro.boot.warranty_bit=0
ro.boot.sec_atd.tty=/dev/ttySAC2
ro.boot.serialno=3204d376731b61df
ro.serialno=3204d376731b61df
ro.bootmode=unknown
ro.baseband=unknown
ro.bootloader=T310XXSBQB2
ro.hardware=smdk4x12
ro.revision=6
ro.emmc=0
ro.boot.emmc=0
ro.factorytest=0
ro.secure=1
ro.allow.mock.location=0
ro.debuggable=1
persist.sys.usb.config=adb
ro.build.id=JZO54K
ro.build.display.id=cm_tab8wifi-userdebug 4.1.2 JZO54K eng.aashir.20130803.144742 test-keys
ro.build.version.incremental=eng.aashir.20130803.144742
ro.build.version.sdk=16
ro.build.version.codename=REL
ro.build.version.release=4.1.2
ro.build.date=Sat Aug  3 14:48:59 PKT 2013
ro.build.date.utc=0
ro.build.type=userdebug
ro.build.user=aashir
ro.build.host=Satellite
ro.build.tags=test-keys
ro.product.model=tab8wifi
ro.product.brand=samsung
ro.product.name=cm_tab8wifi
ro.product.device=tab8wifi
ro.product.board=tab8wifi
ro.product.cpu.abi=armeabi-v7a
ro.product.cpu.abi2=armeabi
ro.product.manufacturer=samsung
ro.product.locale.language=en
ro.product.locale.region=US
ro.wifi.channels=
ro.board.platform=unknown
ro.build.product=tab8wifi
ro.build.description=cm_tab8wifi-userdebug 4.1.2 JZO54K eng.aashir.20130803.144742 test-keys
ro.build.fingerprint=samsung/cm_tab8wifi/tab8wifi:4.1.2/JZO54K/eng.aashir.20130803.144742:userdebug/test-keys
ro.build.characteristics=tablet
ro.cm.device=tab8wifi
ro.rommanager.developerid=cyanogenmod
keyguard.no_require_sim=true
ro.url.legal=http://www.google.com/intl/%s/mobile/android/basic/phone-legal.html
ro.url.legal.android_privacy=http://www.google.com/intl/%s/mobile/android/basic/privacy.html
ro.com.google.clientidbase=android-google
ro.com.android.wifi-watchlist=GoogleGuest
ro.setupwizard.enterprise_mode=1
ro.com.android.dateformat=MM-dd-yyyy
ro.com.android.dataroaming=false
ro.cm.version=10-20130803-UNOFFICIAL-tab8wifi
ro.modversion=10-20130803-UNOFFICIAL-tab8wifi
ro.config.ringtone=Orion.ogg
ro.config.notification_sound=Deneb.ogg
ro.config.alarm_alert=Hassium.ogg
ro.carrier=unknown
ro.ril.hsxpa=1
ro.ril.gprsclass=10
ro.adb.qemud=1
dalvik.vm.lockprof.threshold=500
net.bt.name=Android
net.change=net.bt.name
dalvik.vm.stack-trace-file=/data/anr/traces.txt
init.svc.ueventd=running
init.svc.recovery=running
service.adb.root=1
init.svc.adbd=running
I:Copying file /cache/recovery/log to /cache/recovery/last_log
I:Attempt to load settings from settings file...
I:Loading settings from '/data/media/0/TWRP/.twrps'.
I:Version number saved to '/cache/recovery/.version'
I:Set page: 'install'
I:Set page: 'flash_confirm'
I:Set page: 'flash_zip'
Installing '/external_sdcard/lineage-14.1-20220709-UNOFFICIAL-lt01wifi.zip'...
Checking for MD5 file...
I:Cannot find file /external_sdcard/lineage-14.1-20220709-UNOFFICIAL-lt01wifi.zip.md5
Skipping MD5 check: no MD5 file found.
script aborted: E3004: This package is for device: lt01wifi,lt01wifixx,lt01wifiue,SM-T310; this device is tab8wifi.
Warning: No file_contextsE3004: This package is for device: lt01wifi,lt01wifixx,lt01wifiue,SM-T310; this device is tab8wifi.
E:unknown command [log]
E:Error executing updater binary in zip '/external_sdcard/lineage-14.1-20220709-UNOFFICIAL-lt01wifi.zip'
Error flashing zip '/external_sdcard/lineage-14.1-20220709-UNOFFICIAL-lt01wifi.zip'
I:Set page: 'flash_done'
I:Set page: 'main2'
I:Set page: 'advanced'
I:Set page: 'confirm_action'
I:Set page: 'action_page'
I:Copying file /tmp/recovery.log to /data/media/0/recovery.log
1. Warum wird festgestellt: "this device is tab8wifi", obwohl es das o.g. ist.
2. Zu: "Cannot find file /external_sdcard/lineage-14.1-20220709-UNOFFICIAL-lt01wifi.zip.md5
Skipping MD5 check: no MD5 file found"
Ich habe die MD5-Verifizierung deaktiviert. Bei den Downloadlinks wird immer die MD5 angegeben - muss ich da irgendwas mit machen?
Vielen Dank vorab für Eure Hilfe!
Ich hatte parallel auf xda-developers gepostet - Problem with installing a ROM on Samsung Galaxy Tab 3 8.0 (SM-T310) using TWRP .
Das beschriebene Problem konnte durch ein Update von TWRP gelöst werden. Anschließend scheint auch die Instalation des ROM 20220709 gelungen zu sein. Danach habe ich "Wipe Dalvik-Cache" gemacht und das System neu gestartet. Nun allerdings hängt der Boot-Vorgang anscheinend fest. Seit 30 min. läuft ein Symbol - Kreis, der auf einem Kreisbogen läuft.
Was tun?
Nun ist alles in Ordnung. Ich habe das Gerät ausgeschaltet, Factory-Reset gemacht, nochmal den Cache gelöscht und ROM neu installiert. Das Gerät ist wie neu, läuft wunderbar unter Android 7.1 .
