[RECOVERY]Custom-Recoverys für das GT-P51XX
  • 216 Antworten
PhilZ Touch lässt sich nun von Source kompillieren
- das habe ich natürlich gleich gemacht
Das "Blackhawk"-Repack bietet im Zusammenspiel mit dem NEXT Kernel Dual-Boot-Support.
P5100
GT-P5100_PhilZ-Touch-Recovery_6.17.8.zip
GT-P5100_PhilZ-Touch-Recovery_6.17.8-blackhawk.zip
P5110
GT-P5110_PhilZ-Touch-Recovery_6.17.8.zip
GT-P5110_PhilZ-Touch-Recovery_6.17.8-blackhawk.zip
PhilZ Touch Recovery 6.19.6
fIZ2PPLh
Der ursprüngliche Beitrag von 23:28 Uhr wurde um 23:29 Uhr ergänzt:
TWRP 2.7.0.0
P5100
gt-p5100_twrp_2.7.0.0.zip
odin flashable:
gt-p5100_twrp_2.7.0.0.tar.md5
P5110
gt-p5110_twrp_2.7.0.0.zip
odin flashable:
gt-p5110_twrp_2.7.0.0.tar.md5
changelog:
https://gerrit.omnirom.org/#/q/status:merged+project:android_bootable_recovery,n,z
  • fix "\n\n" string in gui_print(), remove unused gui_print_overwrite()
  • 2.7.0.0 (merged)
  • change qcom time error messages to info (merged)
  • restore capabilities to run-as binary (merged)
  • tweak 240x240 theme (merged)
  • fix wordwrap in console eating last char if str.size() == max_line_len (merged)
  • add word wrap to console output and fix scrolling in console (merged)
  • check crypto footer before offering to decrypt (merged)
  • check auto generated backup names for invalid characters (merged)
  • allow sideloading from /tmp (merged)
  • remove unneeded logging (merged)
  • remove some unneeded code (merged)
  • add capslock support to keyboard (merged)
  • look also for buttons when checking if input device is mouse (merged)
  • fix slash between directories add fixing contexts of android directory for apps that store stuff here, fix data/data contexts to be recursive
  • improve ors scanning of storage locations (merged)
  • cache results of guiobject::isconditiontrue() (merged)
  • properly delete all guiobjects and pages on theme reload (merged)
cherry-pick-marathon
...um die alte "update-binary" lauffähig zu bekommen (damit sich ältere dateien ohne modifikation flashen lassen):
https://gerrit.omnirom.org/3389
https://gerrit.omnirom.org/3390
https://gerrit.omnirom.org/5543
https://gerrit.omnirom.org/5544
https://gerrit.omnirom.org/5545
https://gerrit.omnirom.org/5935
https://gerrit.omnirom.org/5929
Hab eine Frage zur neuen Version von Phils touch, wenn ich das Zip über install zip from sd Card installieren will (Phils touch 6.0..... ist drauf), sagst er dass das zip nicht passt fehler 7...
was mache ich falsch??
Danke für eine Info!
Haengt mit der update-binary in der zip und den assert lines im updater-script zusammen - sofern du das richtige Recovery fuer dein Geraet hast.
Lad dir mein recovery-p51XX.zip herunter.
Dann nimm 7-ZIP und kopier das recovery.img aus der PhilZ.zip dort rein - das umgeht das lesen der assert lines ;) (und somit auch die Geraete-Pruefung). Haengt alles mit KitKat zusammen (als Source fuer die recoverys verwendet)... :p :D
Das "recovey-p51XX.zip" NICHT auf anderen Geraeten verwenden als auf dem P5100, P5110 oder P5113! Damit wuerdet ihr euer anderes Geraet bricken, da dort das Partitions-Layout anders aussieht!
Reaktionen: helat
Danke Andi,
Wie immer schnelle und perfekte Hilfe von dir......
Merci
PhilZ Touch Recovery 6.20.6 - blackhawk
P5100
GT-P5100_PhilZ-Touch-Recovery_6.20.6.zip - 7.95 MB
GT-P5100_PhilZ-Touch-Recovery_6.20.6-blackhawk.zip - 7.17 MB
Odin
GT-P5100_PhilZ-Touch-Recovery_6.20.6.tar.md5 - 7.84 MB
P5110
GT-P5110_PhilZ-Touch-Recovery_6.20.6.zip - 7.87 MB
GT-P5110_PhilZ-Touch-Recovery_6.20.6-blackhawk.zip - 7.10 MB
Odin
GT-P5110_PhilZ-Touch-Recovery_6.20.6.tar.md5 - 7.76 MB
Beim Blackhwak-Repack ist nun das NEXT Tool integriert ;) Findet ihr unter "Advanced" (wenn ihr im Dual-Boot seit, dann nur im primary-recovery ;) )
TWRP 2.7.0.1
Bietet nun die Möglichkeit Screenshots per Tasten-Kombi (Vol+Power) wie in Android. Diese landen in /sdcard/Pictures/Screenshots
P5100
GT-P5100_TWRP_2.7.0.1.zip
Odin:
GT-P5100_TWRP_2.7.0.1.tar.md5
P5110
GT-P5110_TWRP_2.7.0.1.zip
Odin:
GT-P5110_TWRP_2.7.0.1.tar.md5
Habe die Screenshot Funktion bei TWRP 2.7.0.1 versucht zu testen, funktioniert aber nicht. Muss die noch wo aktiviert werden?
@tilo140380 der Bildschirm leuchtet ganz ganz kurz auf wenn es das Bild aufgenommen hat (kleiner "Blitz") - Benachrichtigung dafür gibt es nicht, betrachten lässt es sich im Recovery auch nicht. Danach findest du die Bilder auf dem internen Speicher unter Pictures/Screenshots
Hatte mit volume+ und Power taste probiert, nix passierte, außer das der lockscreen kam
TWRP 2.7.0.1
RE-UPLOADED
Changes
  • Implement "take a screenshot" feature (Commit in Review)
    • Like in android - press power+volume down, screenshots are saved
      in /sdcard/Pictures/Screenshots (if /sdcard is mounted) or /tmp
  • Add support for actions triggered by key combination (Commit in Review)
  • Improve handling of settings storage and android secure (Merged)
  • Fix skipping of relative paths and lost+found in twrpDU (Merged)
  • Run TWFunc::Fixup_Time_On_Boot() before OpenRecoveryScript (Merged)
  • Check to ensure that selinux_handle is populated before using (Merged)
  • Fix incorrect alignment of Restore Defaults button in some themes (Merged)
  • Support pre-KitKat properties for update-binary (Merged)
P5100
GT-P5100_TWRP_2.7.0.1.zip - 7.71 MB
Odin:
GT-P5100_TWRP_2.7.0.1.tar.md5 - 7.59 MB
P5110
GT-P5110_TWRP_2.7.0.1.zip - 7.64 MB
Odin:
GT-P5110_TWRP_2.7.0.1.tar.md5 - 7.51 MB
PhilZ Touch Recovery 6.22.1
P5100
LATER
GT-P5100_PhilZ-Touch-Recovery_6.22.1.zip - 7.98 MB
Odin:
GT-P5100_PhilZ-Touch-Recovery_6.22.1.tar.md5 - 7.84 MB
P5110
GT-P5110_PhilZ-Touch-Recovery_6.22.1.zip - 7.91 MB
Odin:
GT-P5110_PhilZ-Touch-Recovery_6.22.1.tar.md5 - 7.77 MB
PhilZ Touch Recovery 6.22.1-Blackhawk
P5100
GT-P5100_PhilZ-Touch-Recovery_6.22.1-blackhawk.zip - 5.73 MB
P5110
GT-P5110_PhilZ-Touch-Recovery_6.22.1-blackhawk.zip - 5.70 MB
Reaktionen: Badwater
habe den Fehler mit der Screenshotfunktion bei TWRP gefunden, hängt mit mein Theme zusammen, entweder funktioniert es nicht wenn ein Theme verwendet wird, oder das Theme muss angepasst sein.
Muss ich mir mal ansehen :D
Hey Danke, werde ich mal ansehen :-D
Verwende derzeit TWRP. Unter Backup kann man einen
Haken setzen bei:
“Skip MD 5 generation during Backup”
Was bswirkt dieser Befehl?
Dies bewirkt das während des Backup keine Md 5 Prüfsumme erzeugt wird
Reaktionen: achvio
Kurze Frage: Habe grade versucht mit Odin TWRP auf mein p5100 zu spielen. Laut Odin läuft auch alles durch, nur wenn ich dann ins Recocery-Menü boote habe ich immer noch die das Stock-Menü?!
Habe ich irgendwas vergessen ... Root oder so?
Edit: Lesen hilft :)
