Zero Camera Mod - Bitrates + JPG | HDR + AF | G950/G955 - 04 Juli
  • 2 Antworten
nozama
  • HDR for 4K / QHD
  • AutoFocus Tracking all modes
  • No Recording Time Limits
  • Increased Bitrates
  • Increased JPG quality for single and burst shots.
  • Installs latest Samsung Camera revision
  • Video Effects for modes 4K / QHD
  • Remove 4GB video file size limit - App
  • Choose your own custom Gallery - App
  • Remove No Flash limit at 15% battery - App
Version - 7.0.80
Check your original Camera version by going to Settings > Applications > Camera
Alternative App to change your own settings and updates Camera.
Download App - The App is independent of the flashable mod, works standalone.
If you like the mod buying my app would be welcome :)
You can confirm the bitrate of videos by using MediaInfo and JPG quality JPGSnoop
JPG quality - 96 > 98
JPG burst quality - 92 > 98
4K - 48mbps > 62mbps
1080p60 - 28mbps > 36mbps
1440p - 25mbps > 32mbps
1080p - 17mbps > 22mbps
720p - 12mbps > 16mbps
Slow Motion 240fps - 72mbps > 100mbps
4K HDR Comparison On / Off
04 Jul - App v1.09
Remove 4GB maximum video file size limit - App
24 Jun
Removed 10min Time Limit for 4K / 1080p60 recording.
Installation
Flash Mod bei TWRP oder nutze den App @Playstore App.
Manual Install
Replace /system/priv-app/SamaungCamera7/SamsungCamera7.apk
Change permissions of SamsungCamera7.apk to 644.
If using an odex rom (stock) rename /system/priv-app/SamsungCamera7/oat/arm64/SamsungCamera7.odex
Replace /system/etc/media_profiles.xml
Replace /system/cameradata/camera-feature-v7.xml
Clear Dalvik-Cache or file below.
/data/dalvik-cache/arm64/system@priv-app@SamsungCamera7@SamsungCamera7.apk@classes.art
/data/dalvik-cache/arm64/system@priv-app@SamsungCamera7@SamsungCamera7.apk@classes.dex
Reboot
Download:
zeroCameraS8_7080_v3.zip
https://forum.xda-developers.com/attachment.php?attachmentid=4201631&d=1499194939
camera_restore_S8_v3.zip
https://forum.xda-developers.com/attachment.php?attachmentid=4201632&d=1499194939
Reaktionen: dennis46419
ach man bei sowas juckt der root Gedanke immer wieder bei mir :) aber ich und meine Flash sucht wollte einmal ein Handy stock lassen ohne root und twrp.
Mal gucken wie lange ich standhaft bleiben kann. normal Boote ich die Handys nur um es unlocken und rooten zu können. dann wird die originale Firmware auch schon ersetzt ohne sie jemals benutzt zu haben :)
aber muss sagen Toi Toi Toi das s8 rennt sehr gut mit der Stock Rom
Reaktionen: rade73
@nozama
Der Opener dieses Threads entspricht nicht unseren Forenregeln.
Für Dich zum Nachlesen:
ses schrieb:
  • Themen/Beiträge in deutsch:
    Wir sind ein deutschsprachiges Forum, weshalb auch alle Beiträge und Themen in deutsch zu verfassen sind. In Ausnahmefällen (z.B. dann wenn die Übersetzung durch technische Hilfsmittel erfolgt ist und daher Fehler bzw. Missverständnisse zu erwarten sind) kann der original- bzw. englischsprachige Text beigefügt werden.
Mein Kollege hatte Dich per PN angeschrieben und gebeten, den Text zu übersetzen. Da von Dir keine Reaktion kam, schließe ich an dieser Stelle.
Danke fürs Verständis und
Gruß von hagex
PS.:
Solltest Du das Versäumnis doch noch nachholen wollen, melde bitte diesen meinen Post mit einer kurzen Erklärung.
Bearbeitet von: bandit1976 - Grund: Typo ausgebessert, bandit1976 ;)
Fire123
DBan
Daytripper
Andyowl777
I
maik005
maik005
