Xposed Framework for Android Lollipop is Here!
  • 3 Antworten
LocDog
LocDog
Endlich ist es da.
[OFFICIAL] Xposed for Lollipop - XDA Forums
It seems that many people have waited for this moment, and here we are:
Xposed for Lollipop is finally here!
You can find a list with Q&A on the XDA Portal. Please read it, you will find many answers there.
Note that this is still an alpha version and for Lollipop on ARMv7+ devices only.
Please install it only if you're willing to take the risk of boot loops. Just because it's working fine and stable for me doesn't mean it will work for everyone the same way.
Downloads:
xposed-arm-20150213b.zip: Must be flashed with a custom recovery to install the framework.
XposedInstaller_3.0-alpha1.apk: Must be installed to manage installed modules
No, it's not using material design yet. Yes, there are more important topics for now.
XposedBridgeApi-20150213.jar: The API for module developers, in case they want to make use of some new features. Might be changed slightly until the stable release!
Known issues:
- It seems to boot loop on Samsung stock ROMs. I have received a file which I can use to analyse this issue, but it might take some time.
Update: There's a difference in the format of *.oat files on Samsung ROMs. I'm trying to find out more.
- If you have downloaded the files within the first hour, your phone boots but the installer says that the framework is not installed, please download the updated version and flash again. XposedBridge version must be 61 afterwards.
- If everything is working fine, but the app_process version is not displayed, it's just a display error that can be ignored (will be fixed later).
Dann bitte löschen ich lese nur im S5 Forum. Und dort hat die Suche nichts gefunden mit Xposed.
War mir aber wichtig es hier zu Posten mit der Meldung das es zu Bootloops führen kann bei Stock Roms aufm S5
Thema geschlossen, da nicht Gerätespezifisch
klausandroid
RadHeiner
RadHeiner
RadHeiner
marceltalberg
