[Recovery][I9505] *06.08.2018* TWRP Recovery v3.2.3-0
  • 618 Antworten
beicuxhaven
beicuxhaven
Ehrenmitglied
10.437
An dieser Stelle ein Thread zur TeamWin-Recovery
Beachtet, dass ihr alleine für euer Handeln verantwortlich seid.
Im schlimmsten Fall können falsche Firmware-Versionen oder unsachgemäße Installation euer Gerät dauerhaft unbrauchbar machen.
Bei Unklarheiten fragen und immer genau lesen!
ACHTUNG!
Dieser Thread bezieht sich ausschließlich auf das
I9505 (Snapdragon)
TEAM-Win Recovery
Changelog v3.2.3-0:
  • Fix automatic installing of OTA zips on encrypted devices
  • Remove SuperSU from TWRP
  • Support both md5 and md5sum file extensions when doing MD5 checking for zip files
Ältere Changelogs
Changelog v3.2.1-2:
  • Refactor USB configurations (fixes ADB)
  • Remove /cpefs from filesystem table (fixes /cpefs warning/error)
  • Rebase Kernel to ARCC. (fixes I/O performance issues)
  • Use correct OTG mount path
  • Enable software encryption support (general AOSP only, Samsung method remain unsupported)
Changelog v3.2.1-1:
  • Add system_image, vendor_image
    Rename display name of /odm to "Carrier Configs"
Changelog v3.2.1-0:
  • USB connection fixes
2.8.4
  • Add flashing of boot and recovery images via the TWRP GUI (Find the Images button on the Install page)
  • Fix some MTP related crashes and bugs
  • Eliminate TWRP toggling USB IDs during boot if MTP is enabled
  • Fix various adb sideload issues
  • Improve threading of actions
  • Eliminate separate thread for screen timeout
  • Update libblkid to 2.25.0
  • Use power button as back button on watch themes for easier navigation
  • Add mutex locking to data manager
  • Improve custom theme handling on encrypted devices
  • Allow the stock theme to be offset by build flags so we can center a lower res theme on a higher res screen especially for watches with round screens
2.8.3.0
-MTP will now tell the host PC that storage is removed instead of disabling MTP completely
-MTP will now report the correct max file size based on the file system in use to the host PC (may fix transfer of large files)
-Update and improve fix permissions and make fixing contexts optional
-Update SuperSU in TWRP to 2.40 and update install process
-Make TWRP work properly on AArch64 (Nexus 9 is now built in true 64-bit binaries and libraries)
-Attempt to set correct permissions and contexts on all files placed in storage so backups will show in Android
-Fix kernel panic during MTP start on some devices
-Support unicode fonts on devices with True Type Font support
-Fix slider value not showing sometimes (vibration settings page)
-Toggle MTP off during adb sideload to set correct USB IDs
-Reduce library requirements for 5.0 L decrypt
-Other minor fixes and improvements
2.8.1.0
  • MTP fixes and improvements - you can now copy zips to the root of storage - thanks to _that
  • TrueType Font support - optional as it takes up a decent amount of space so may not be available on all devices - thanks to Tassadar
  • Temperature support - thanks to bigbiff
  • Various other bugfixes and tweaks
2.8.0.1:
-Fix a bug that causes weird graphics glitches and touch issues
2.8.0.0:
-Add MTP support to recovery thanks mostly to bigbiff with a little help from Dees_Troy
-Add command line capabilities - you can now execute various TWRP features via adb instead of the touchscreen
-Add support for color in the console and give error, warning, and highlight lines different colors
-Track backup and restore progress based on file sizes to provide a much more accurate indication of progress
-Improve handling of /misc thanks to mdmower
-Improve setting of time on Qualcomm devices thanks to [NUT]
-Allow using images on slidervalue GUI objects thanks to Tassadar
-Allow using variables and addition and subtraction in variables for easier theming
-Add support for 1440x2560, 280x280, and 320x320 resolutions and update 240x240
-Allow ui.xml file to include additional xml files to help break up the theme and make TWRP easier to maintain
2.7.1.0:
  • Add GUI option to change or repair file systems on individual partitions. The change is destructive so backup your data including internal sdcard first. This option should make it a little easier to migrate a device from ext4 -> f2fs, for instance. You will find this option under Wipe -> Advanced Wipe, then select only one partition and then press the Repair or Change File System button. If a developer has added f2fs support for your device and we don't have it in TWRP, please contact me via PM to arrange for it to be added.
  • Various bugfixes to backup and restore
  • Improvements to USB storage handling
  • Added a class to search for files to make finding the correct brightness file automatic in most cases
What's new in 2.7.0.0:
  • Faster graphics rendering by disabling alpha blending on fully opaque objects thanks to Tassadar
  • Allow sideloading from /tmp on encrypted devices
  • Check for a crypto footer before asking for a password to prevent user confusion
  • Additional checks for validity to auto generated backup names
  • Text wrap in the console output
  • Proper caps lock support in the keyboard
  • Mouse support via USB OTG for devices with a broken digitizer
  • Improve scanning of storage locations for OpenRecoveryScript
  • Haptic feedback for buttons, keyboard, and vibration at the end of longer running actions
  • Fixed ext4 wiping when no selinux contexts are defined for that partition (e.g. sd-ext)
  • Update SuperSU to 1.93 and improve installation process
  • Added selinux contexts restoration to fix permissions
  • Load RTC offset on Qualcomm devices to fix the date/time in recovery
  • USB Mass Storage fixes Add SELinux support checking
  • Add Disk Usage class to better handle excluded folders (e.g. Google Music cache)
  • Add 4.4 decrypt support
  • Add some toolbox utilities to TWRP (namely to support SELinux functions not supported in busybox)
  • Various SELinux fixes and bug fixes
Note: 2.7 marks the first time that we are dropping support for older devices. We are doing this because of the SELinux support needed to install 4.4 Kit Kat ROMs. The non-TWRP parts of the recovery image have to be built in at least a 4.1 tree and the kernel that is included in the recovery image has to support writing SELinux contexts. We don't own most of the devices that we support so we depend on outside testers and developers to help us update devices. In many cases we can't find someone readily. Come to #twrp on Freenode if you want to help bring your device up to date. You can tell right away if your device will support 4.4 ROMs in 2.7. Boot TWRP and press the console button (the square-ish button either in the bottom middle or upper right) to view the console output. If it doesn't say "Full SELinux support" in the console, then your device still needs some work. Help us help you.
Download ODIN Version
zur flashbaren Version von Market Link
[*]Direct Download
[/LIST]Install the app and open it. Tap menu then hit Install OpenRecoveryScript. Tap Yes. Verify that the filename displays your device's code name and hit Yes. The file will download and your device will install the recovery automatically.
Hier noch der Link zum
OpenRecoveryScript was ja nun unterstützt wird.
Installation:
Die Recovery wird über Odin geflasht.
-Hierzu das S4 in den Download-Modus versetzen
-die .tar-Datei in Odin unter PDA einsetzen
-Flashvorgang starten
Die .zip-Datei im Anhang enthält Odin 1.85.
XDA
DIE NEUE!!!!!!!!!!!!!!!!! Team Win Recovery Project Seite
Bis auf weiteres habe ich diesen Thread von Martin übernommen. Danke an dieser Stelle für die super Vorarbeit.​
  • Odin1.85.zip
Bearbeitet von: hanspampel - Grund: Auf neueste TWRP Version geupdatet - "hanspampel"
Reaktionen: djfelix, Brickerl, Merlin76287 und 24 andere
Ich weiß ich bin grade Offtopic, aber wann wird es denn ungefähr CWM auf dem i9505 geben? :huh: Ich meine die tollste Custom Rom bringt uns nichts, solange man kein Recovery hat.. :tongue:
Ja für das I9500.
Octa Core ;)
Reaktionen: kotaro
und wie muss man die .img datei flashen?
Teste es wenn ich zu hause bin...
Gesendet von meinem GT-I9505 mit Tapatalk 2
Per "Terminal Emulator" oer "ADB Shell".
Select the latest .img file from here
You must be rooted to use this method. Download the above file. Using adb shell or terminal emulator:
su
dd if=/sdcard/recoveryfilename.img of=/dev/block/mmcblk0p21
Make certain that you get this command right. Typing the wrong number could result in a brick!
Edit: Soll wohl voll funktionsfähig sein.
GhostLeader schrieb:
Hi, TWRP updated the DL Techerrata Downloads - Browsing jfltexx
I noticed it, because the countdown was resetted and the date of the modification time has changed
TOUCH IS WORKING NOW!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! (my S4 -GT-I9505- is from mediamarkt germany, no branding, no simlock)
Good news
Quelle
Die Frage ist nur ob das S4 nicht bricked wenn man nen Fullwipe macht.
Question: When I do a complete wipe, will the S4 brick? A friend of mine said some kernels are not wipe-proofed, so they will brick.
Freiwillige vor.:)
Recovery online!
Startbeitrag aktualisiert.
~Reserviert für weitere Informationen~
Hey, bin ein kleiner Noob:D Also meine frage die sich echt bescheuert anhört:D
Was soll ich mit der .img Datei anfangen? Du könntest es ja vielleicht etwas erklären, wäre jedenfalls nett :)
Keine Bilderoder Ähnliches?
Ist ja mehr wie ne Katze im Sack.. .
Schon jemand versucht? Ich hab irgendwie angst um mein s4._.
Gesendet von meinem GT-I9505 mit der Android-Hilfe.de App
Indie der Omega ROM dev von den xdas testet es wohl gerade;)
Habs getestet. Es funktioniert :)
gerade mit odin geflashed und es funktioniert..
Reaktionen: GosyTX
