[Recovery][I9505] *06.08.2018* TWRP Recovery v3.2.3-0
  • 618 Antworten
Sieht so aus, als wäre v.2.5 die aktuellste Version.Link
LG
So sieht es aus. 2.7.1.0 ist die aktuellste Version. 2.8.0.0 ist vermutlich in Arbeit. Aber offizielles gibt es dazu nicht. Also immer schön ruhig bleiben.:smile:
Reaktionen: abemann und beicuxhaven
2.8.0.0 ist da. (XDA Thread)​
Changelog:​
-Add MTP support to recovery thanks mostly to bigbiff with a little help from Dees_Troy
-Add command line capabilities - you can now execute various TWRP features via adb instead of the touchscreen
-Add support for color in the console and give error, warning, and highlight lines different colors
-Track backup and restore progress based on file sizes to provide a much more accurate indication of progress
-Improve handling of /misc thanks to mdmower
-Improve setting of time on Qualcomm devices thanks to [NUT]
-Allow using images on slidervalue GUI objects thanks to Tassadar
-Allow using variables and addition and subtraction in variables for easier theming
-Add support for 1440x2560, 280x280, and 320x320 resolutions and update 240x240
-Allow ui.xml file to include additional xml files to help break up the theme and make TWRP easier to maintain
-Other minor fixes and improvements
Over the course of the last year or so, bigbiff has worked to migrate various Java functions from Android's MTP implementation to bring you a fully C++ based MTP implementation that allows you to transfer files to both emulated storage and Micro SD cards. It's confirmed to work on various Nexus devices but we may have to make some changes on other devices to keep Windows happy. Windows is very picky about USB IDs and its drivers. We have tested it on Windows 7 and 8 as well as Ubuntu 14.04 Trusty. MTP is enabled by default, but we do toggle it off and on automatically during certain operations such as if you choose to wipe a storage partition. You can enable or disable MTP under the mount menu in TWRP. For more about what MTP is here.
Note: Due to a weird bug with our MTP setup, you cannot copy a zip file to the root of storage with Windows. You can change the .zip to something else like .txt and then copy it to the root and rename the file back to .zip once it's copied to the device. You can also copy the zip into any subfolder.
Command line support is also now available. You can perform various OpenRecoveryScript commands via the adb shell. Depending on what you are doing you may wish to do a "twrp set tw_mtp_enabled 0" and then reboot to prevent the MTP auto toggle from killing your adb interface. You can use this option to create and restore backups, wipe, install zips, and more. Via adb shell, type twrp followed by a space then enter the OpenRecoveryScript command and hit enter. Find more OpenRecoveryScript commands here.
Reaktionen: tobiasth
Hier meine flashbare Zip.
  • TWRP_2.8.0.0_GT-I9505(jfltexx).zip
Reaktionen: Mo Jito, Marillo, ernestorw40 und 4 andere
Cool danke dann werde ich auch mal schauen ob sich an den original theme was geändert hat. Wenn ja werden meine theme's angepasst
Also ich hatte TWRP 2.0.7.1 drauf mit den Google Play Theme und hab jetzt auf 2.0.8.0 geupdatet und der Google Play Theme funktioniert immer noch
Kann man mit der v 2.7.1.0 bzw. 2.8.0.0 in F2FS umwandeln oder geht dass nur mit der 2.7.0.5 von ktoonsez?
Die theme Struktur wurde verändert und ist soweit ich gesehen habe abwärtskompatibel. Das theme besteht jetzt aus zwei XML Dateien. ui. xml und portrait.xml. Die portrait. xml ist per include in der ui.xml eingebunden, wobei der meiste Teil jetzt in der portrait.xml ausgelagert ist. Ich werde die Tage mal meine Theme's auf die neue Struktur umstellen.
Nach der 2.8 wurde nun ganz schnell die 2.8.1 raus geschossen. Behebt Grafik / Touch Fehler!!
Hier noch der Link zum
OpenRecoveryScript was ja nun unterstützt wird.​
Reaktionen: hanspampel, abemann und tobiasth
Hier die Zip.
  • TWRP_2.8.0.1_GT-I9505.zip
Reaktionen: abemann, tobiasth und beicuxhaven
Hab heute auch mal die 2.8.0.1 getestet, Flash usw. kein Problem, erstes BackUp gemacht auch kein Problem...., dann Reboot..., aber leider wurde kein Backup auf die SD geschrieben WTF??? Noch 8 weitere Male probiert, aber es funktioniert nicht, TWRP macht zwar das Backup aber wird nicht geschrieben, sowas hatte ich noch nie!
Bin jetzt zuerst nal wieder auf 2.7 zurück. Sonst noch jemand das Problem?
Was hast du für einen Kernel?
Vielleicht mag der die SD-Karte nicht?:razz:
LG
Ist alles Official..., Android 4.3 Stockrom, Original Kernel, keine Mods..., nur Root.
Ging ja vorher mit TWRP alles ohne Probleme, auch mit CWM und PHILZ.
SD ist ne Original Samsung 64GB, denk net das es daran liegt ;-)
Alles klar, wenn es vorher ging...
Dann liegt es wohl doch an TWRP.
Dachte nur, da es oft vorkam, dass der Stock-Kernel nicht mit der SD-Karte zurecht kam, aber ein anderer Kernel das Problem behoben hat.
LG
Joa, is jetzt auch nicht soooo tragisch xD, die neuen Funktionen sind mir nicht so wichtig!
Die alten Versionen können das was ich brauch: "Wiederherstellen wenns sein muss!"
Is halt nur seltsam, das die neue TWRP (zumindest bei mir) so rumzickt! Vielleicht hat ja sonst noch jemand das Problem und ne passende Lösung.
@Smii
Vielleicht kannst DU beim Backup den Fehler bei Dir eingrenzen, Komprimierung an/aus, MD5 Generierung an/aus
Ich erstelle immer Backups mit deaktivierter MD5 Generierung und ohne Komprimierung, bisher keine Probleme, auch Wiederherstellung klappt.
Was Du auch noch testen kannst, unter TWRP Standardeinstellung wiederherstellen
Hab die MD5 Generierung testweise, um Zeit zu sparen, ausgeschaltet..., aber das selbe Ergebnis.
Komprimierung hab ich nicht verändert, ist aber ein Versuch wert.
Auf Standart zurückgesetzt hab ich auch noch nicht, da hätt ich auch selber draufkommen ķönnen, das mal zu versuchen :laugh:
Werds morgen nochmal versuchen, hab grad keinen Rechner hier.
Werd berichten obs geklappt hat.
würde mir jetzt auch nicht vorstellen das Du auf Simulationsmodus gestellt hast, erstens geht dann das Backup sauschnell und zweitens steht es im Ablauf das es simuliert wird
Wissentlich auf keinen Fall..., wobei ich ehrlich gesagt auch nicht wusste, daß TWRP so einen Modus hat!
Das Backup dauert so um die 600-700 Sekunden bei ner Größe von 2,7GB. Mit der v2.7 klappts ja, hab die 2.8.1 mit Odin geflasht direkt ins Recovery gebootet kurz umgeschaut, ob was neu ist und direkt ein Backup gemacht.
EDIT:
Hatte jetzt keine Ruhe.Habs nocheinmal versucht, hab mir Flashify geladen und wieder die 2.8.0.1 draufgemacht. Alles auf Standardeinstellungen zurückgesetzt, extra geschaut das nirgendwo ein Haken ist ausser bei Skip MD5 und losgelegt..., diesmal zuerst auf die interne SD, und siehe da es geht!
Okay dachte ich, löscht du das Backup grade von der Internen, dann neuer Versuch auf Extern! Da ist mir aufgefallen das TWRP eine neue Datei angelegt hat ".twrps"..., die gibts auf der externen gar nicht. Wieder ins Recovery und erneutes Backup auf extern..., funzt immer noch nicht!!! Keine Dateien vorhanden!
Hab dann den Ordner samt neuer Datei von intern auf extern kopiert, Backup gemacht, wieder nichts!
Dann alle TWRP Ordner gelöscht, Recovery neu geflasht, wieder Backup gemacht, jetzt wird der TWRP Ordner extern nicht mal mehr angelegt, nur noch intern!
Dann die 2.0.7.1 geflasht und alles funktioniert!!! Versteh das mal einer..., ich bleib jetzt bei der Version!
Wenn noch jemand ne Idee hat..., gerne..., ich gebs für heute auf^^
